[PATCH 1/3] score/cpu: Silence ARM and AARCH64 GCC 12 false trigger array warning
chrisj at rtems.org
chrisj at rtems.org
Tue Jun 14 01:24:06 UTC 2022
The false trigger is covered in:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=104657
GCC 11 and 12 has been patched for constant pointer casts above
4K. This code casts a constant pointer within the first 4K
page. As a result the patch disables the warning.
Updates #4662
cpukit/score/cpu/aarch64/cpu.c | 3 +++
cpukit/score/cpu/arm/cpu.c | 5 ++++-
2 files changed, 7 insertions(+), 1 deletion(-)
diff --git a/cpukit/score/cpu/aarch64/cpu.c b/cpukit/score/cpu/aarch64/cpu.c
index 88e7ad8a8c..f0062adf30 100644
--- a/cpukit/score/cpu/aarch64/cpu.c
+++ b/cpukit/score/cpu/aarch64/cpu.c
@@ -180,6 +180,8 @@ void _CPU_ISR_install_vector(
CPU_ISR_handler *old_handler
+#pragma GCC diagnostic push
+#pragma GCC diagnostic ignored "-Warray-bounds"
/* Redirection table starts at the end of the vector table */
CPU_ISR_handler *table = (CPU_ISR_handler *) (MAX_EXCEPTIONS * 4);
@@ -194,6 +196,7 @@ void _CPU_ISR_install_vector(
if (current_handler != new_handler) {
table [vector] = new_handler;
+#pragma GCC diagnostic pop
void _CPU_Initialize( void )
diff --git a/cpukit/score/cpu/arm/cpu.c b/cpukit/score/cpu/arm/cpu.c
index 5c5b253470..b2cc6039b0 100644
--- a/cpukit/score/cpu/arm/cpu.c
+++ b/cpukit/score/cpu/arm/cpu.c
@@ -167,8 +167,10 @@ void _CPU_ISR_install_vector(
- CPU_ISR_handler *table = (CPU_ISR_handler *) (MAX_EXCEPTIONS * 4);
+ CPU_ISR_handler volatile *table = (CPU_ISR_handler *) (MAX_EXCEPTIONS * 4);
CPU_ISR_handler current_handler = table [vector];
@@ -181,6 +183,7 @@ void _CPU_ISR_install_vector(
2.19.1
