[PATCH 3/5] bsps/stm32h7: allow config and usage of QSPI memory on stm32h757i-eval BSP
Wed Jun 15 15:05:38 UTC 2022
On Wed, Jun 15, 2022 at 9:00 AM Gedare Bloom <gedare at rtems.org> wrote:
> On Fri, Jun 10, 2022 at 6:49 AM Karel Gardas <karel at functional.vision> wrote:
> > The QSPI memory is initialized and used only when the BSP configure file
> > sets QSPI memory size to non-zero value. Currently QSPI is run in memory
> > mapped mode which allows future RTEMS binary linkage and upload into QSPI
> > memory.
> > Sponsored-By:   Precidata
> >  .../stm/stm32h757i-eval/stm32h7-bspstarthooks.c | 17 +++++++++++++++++
> >  bsps/arm/stm32h7/include/bsp.h                  |  1 +
> >  .../bsps/arm/stm32h7/bspstm32h757i-eval.yml     |  5 ++++-
> >  spec/build/bsps/arm/stm32h7/optmemquadspisz.yml |  1 +
> >  4 files changed, 23 insertions(+), 1 deletion(-)
> > diff --git a/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c
> > index 8d34e357ee..9916b740ce 100644
> > --- a/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c
> > +++ b/bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c
> > @@ -36,6 +36,22 @@
> >  #include <string.h>
> > +#if defined(STM32H7_MEMORY_QUADSPI_SIZE) && STM32H7_MEMORY_QUADSPI_SIZE > 0
> > +#include <stm32h747i_eval_qspi.h>
> > +BSP_QSPI_Init_t QSPinit;
> Do you need this variable to be in the global namespace? Can it be a
> static variable here?
> > +#endif
> > +void stm32h7_init_qspi(void)
Also, is this function declared somewhere?
Probably what you should do is to add this function declaration to
stm32h747i_eval_qspi.h, and include that file here always?
> > +    /* let's initialize Quad SPI memory here for memory mapped mode */
> > +    memset((void*)&(QSPI_Ctx[0]), 0, sizeof(QSPI_Ctx[0]));
> > +    memset((void*)&QSPinit, 0, sizeof(BSP_QSPI_Init_t));
> > +    BSP_QSPI_Init(0, &QSPinit);
> > +    BSP_QSPI_EnableMemoryMappedMode(0);
> > +#endif
> >  void bsp_start_hook_0(void)
> >    if ((RCC->AHB3ENR & RCC_AHB3ENR_FMCEN) == 0) {
> > @@ -52,6 +68,7 @@ void bsp_start_hook_0(void)
> >      HAL_RCC_MCOConfig(RCC_MCO1, RCC_MCO1SOURCE_HSI, RCC_MCODIV_1);
> >      HAL_Init();
> >      SystemInit_ExtMemCtl();
> > +    stm32h7_init_qspi();
> >  #if __CORTEX_M == 0x07U
> > diff --git a/bsps/arm/stm32h7/include/bsp.h b/bsps/arm/stm32h7/include/bsp.h
> > index 08311bf51e..cd4d25c069 100644
> > --- a/bsps/arm/stm32h7/include/bsp.h
> > +++ b/bsps/arm/stm32h7/include/bsp.h
> > @@ -62,6 +62,7 @@ void stm32h7_init_power(void);
> >  void stm32h7_init_oscillator(void);
> >  void stm32h7_init_clocks(void);
> >  void stm32h7_init_peripheral_clocks(void);
> > +void stm32h7_init_qspi(void);
> > diff --git a/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml b/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml
> > index 5d7ee1348d..7516e55a3f 100644
> > --- a/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml
> > +++ b/spec/build/bsps/arm/stm32h7/bspstm32h757i-eval.yml
> > @@ -8,7 +8,8 @@ copyrights:
> >  cppflags: []
> >  enabled-by: true
> >  family: stm32h7
> > -includes: []
> > +includes:
> > +- bsps/arm/stm32h7/boards/stm/stm32h757i-eval
> >  install: []
> >  links:
> >  - role: build-dependency
> > @@ -16,6 +17,8 @@ links:
> >    uid: tststm32h757i-eval
> >  source:
> > +- bsps/arm/stm32h7/boards/stm/Components/mt25tl01g/mt25tl01g.c
> > +- bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h747i_eval_qspi.c
> >  - bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-bspstarthooks.c
> >  - bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-config-clk.c
> >  - bsps/arm/stm32h7/boards/stm/stm32h757i-eval/stm32h7-config-osc.c
> > diff --git a/spec/build/bsps/arm/stm32h7/optmemquadspisz.yml b/spec/build/bsps/arm/stm32h7/optmemquadspisz.yml
> > index 11e5f943e0..9337610b45 100644
> > --- a/spec/build/bsps/arm/stm32h7/optmemquadspisz.yml
> > +++ b/spec/build/bsps/arm/stm32h7/optmemquadspisz.yml
> > @@ -1,6 +1,7 @@
> >  actions:
> >  - get-integer: null
> >  - env-assign: null
> > +- define-unquoted: null
> >  build-type: option
> >  default: 0
> >  default-by-variant: []
> > 2.25.1
> > devel mailing list
> > devel at rtems.org
