Runtime Loader Exported Symbols Address Size
Chris Johns
chrisj at rtems.org
Sat Jun 18 23:16:26 UTC 2022
On 19/6/22 5:21 am, Joel Sherrill wrote:
> On Fri, Jun 17, 2022 at 8:13 PM Chris Johns <chrisj at rtems.org
> <mailto:chrisj at rtems.org>> wrote:
> On 18/6/22 10:08 am, Joel Sherrill wrote:
> > On Fri, Jun 17, 2022, 2:28 PM Alex White <alex.white at oarcorp.com
> <mailto:alex.white at oarcorp.com>
> > <mailto:alex.white at oarcorp.com <mailto:alex.white at oarcorp.com>>> wrote:
> > Hi,
> > While testing libdl on AArch64 QEMU, we found a bug where the exported
> > symbol table appears to always use 32-bit values for addresses, but where
> > the exported symbols table is read in `rtems_rtl_symbol_global_add`, the
> > addresses are expected to be of size `sizeof(unsigned long)`.
> > This did not cause a problem on ARM since `sizeof(unsigned long)` is
> 4, but
> > with AArch64 `sizeof(unsigned long)` is 8. So it is trying to read the
> > address as 64 bits instead of 32.
> > The simple fix is to use an exact-width integer type - like
> > `sizeof(uint32_t)`. But this would not allow for 64-bit architectures
> to use
> > the full address space. It would also break on 64-bit RISC-V (see below).
> > Perhaps we could have an ifdef to choose a 32 or 64-bit type based on the
> > architecture rather than relying on `sizeof(unsigned long)`?
> > It looks like there is an exception in the rtems-syms tool for 64-bit
> RISC-V
> > to emit 64-bit addresses rather than 32-bit addresses. Is this the right
> > solution? Should we add another exception for AArch64?
> > After having given this some thought, I think the code that is generated
> and the
> > parsing code in rtl-sym.c should be conditionalized on the GCC CPP predefine
> > that indicates the size of a void *.
> Good idea. The symbol value is held as a `void*` in the symbol table so the key
> is the generated asm size in rtems-syms.cpp matches the runtime `void*` size.
> That code maybe conditional on the size selecting the correct variable size.
> > The code in rtl-sym.c should use a type definition for the type that the
> sizeof
> > is operating on. Using unsigned long is just not good enough. Both cases
> should
> > be fixed width types.
> Sure `unsigned long` may not be the best type to use. It was selected because it
> happened change size with the arch but I am sure there are types that are better
> suited. The type needs to be the size of a full address space pointer.
> Glad you hear you agree on the basic approach. The cpp predefine is
> __SIZEOF_POINTER__ and it should be 4 or 8. If both sides use that, then this
> should be permanently fixed.
> > There also should be a very good comment above the parsing method in rtl-sym.c
> > explaining where the file comes from that it is reading and why there is the
> > need for a type which varies by architecture.
> Sure, happy to see comments added. Is this something you would like me to
> handle?
> The generation and source of the symbols can be handled in a number of ways. I
> have provided a tool that should cover most use cases however I can imagine
> more, eg symbol filters for defined exported symbols. I documented things here:
> https://docs.rtems.org/branches/master/user/exe/loader.html#base-image-symbols
> <https://docs.rtems.org/branches/master/user/exe/loader.html#base-image-symbols>
> Does that documentation help cover what you are looking for?
> I'll let Ryan and Alex answer that since they are fixing this. I just was
> helping Ryan debug the parsing loop and realized it was chopping off the
> first four bytes of every symbol after the first one.
OK
> > Based on our current understanding, I think this address is everything and
> > leaves sufficient information and organization to cover all the cases in the
> > future. Very likely without anyone actively having to fix anything.
> Running into
> > this issue again and again as architectures are added is not a good long-term
> > solution.
> Agreed. Figuring out stable 64bit addressing in libdl is a good idea and
> welcome. I think the main requirement is for the full address range to be
> supported.
> > Chris.. is this a good path to you?
> Yes this sounds good.
> > Is there somewhere else in the dynamic loader system with a similar issue?
> This is the only external interface of this type where static checking does not
> help. The other is ELF which I hope is OK. I am not sure if other places may
> have a problem. All care was taken however only using the code with 64bits will
> determine this.
> The elftools libelf support was ported and tested with only 32bit targets. I am
> not sure if there are issues there.
> OK. Ryan and Alex will be fixing this as part of adding aarch64 libdl support.
> Just having you available to give insight is very helpful.
No problem and Alex knows he can ping me on Discord.
