Fwd: [rtems-bsp-builder] 2022-06-18 06:34:41: Profile(s): everything
Chris Johns
chrisj at rtems.org
Sat Jun 18 23:22:02 UTC 2022
On 19/6/22 2:29 am, Joel Sherrill wrote:
> Looks like some tooling broke
Hmmm ....
> 1 debug arm/fvp_cortex_r52 build:
> configure: /home/tester/rtems-cron-6/rtems/waf configure\
> --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
> /rtems-cron-6/rtems --rtems-config=config-arm-\
> fvp_cortex_r52-debug.ini
> error: tmp/cc8SRrqY.s:1521 Error: selected processor does not support
> requested special purpose register -- `msr icc_IGRPEN1_el1,r2'
The r52 must not have that register? I assumed it was common to the GICv3 and it
is not conditional in FreeBSD. I will push a change to make this conditional on
the A72. I am not sure if there is a specific define for the r52?
Nice to see the CI picking up the error.
