[PATCH] testsuite: Fix gcc 12 warnings
Joel Sherrill
joel at rtems.org
Mon Jun 20 08:31:28 UTC 2022
Ok
On Sun, Jun 19, 2022, 9:10 PM <chrisj at rtems.org> wrote:
> From: Chris Johns <chrisj at rtems.org>
> testsuites/libtests/POSIX/readv.c | 2 +-
> testsuites/libtests/POSIX/sigismember.c | 2 +-
> testsuites/libtests/POSIX/sigprocmask.c | 3 ++-
> testsuites/libtests/POSIX/writev.c | 2 +-
> testsuites/psxtests/psxhdrs/arpa/inet/inet_ntop.c | 2 +-
> testsuites/psxtests/psxhdrs/fcntl/openat.c | 4 ++--
> testsuites/psxtests/psxhdrs/netdb/gethostbyaddr.c | 2 +-
> .../psxhdrs/pthread/pthread_attr_getdetachstate.c | 4 ++--
> .../psxtests/psxhdrs/pthread/pthread_attr_getguardsize.c | 4 ++--
> .../psxhdrs/pthread/pthread_attr_getinheritsched.c | 4 ++--
> .../psxtests/psxhdrs/pthread/pthread_attr_getschedparam.c | 4 ++--
> .../psxhdrs/pthread/pthread_attr_getschedpolicy.c | 4 ++--
> .../psxtests/psxhdrs/pthread/pthread_attr_getscope.c | 4 ++--
> .../psxtests/psxhdrs/pthread/pthread_attr_getstack.c | 2 +-
> .../psxtests/psxhdrs/pthread/pthread_attr_getstackaddr.c | 2 +-
> .../psxtests/psxhdrs/pthread/pthread_attr_getstacksize.c | 4 ++--
> .../psxtests/psxhdrs/pthread/pthread_attr_setschedparam.c | 4 ++--
> testsuites/psxtests/psxhdrs/pthread/pthread_cond_init.c | 2 +-
> .../psxtests/psxhdrs/pthread/pthread_cond_timedwait.c | 2 +-
> .../psxhdrs/pthread/pthread_condattr_getpshared.c | 2 +-
> testsuites/psxtests/psxhdrs/pthread/pthread_create.c | 2 +-
> .../psxhdrs/pthread/pthread_mutex_getprioceiling.c | 4 ++--
> testsuites/psxtests/psxhdrs/pthread/pthread_mutex_init.c | 2 +-
> .../psxtests/psxhdrs/pthread/pthread_mutex_timedlock.c | 2 +-
> .../psxhdrs/pthread/pthread_mutexattr_getprioceiling.c | 2 +-
> .../psxhdrs/pthread/pthread_mutexattr_getprotocol.c | 4 ++--
> .../psxhdrs/pthread/pthread_mutexattr_getpshared.c | 4 ++--
> testsuites/psxtests/psxhdrs/sys/select/pselect.c | 4 ++--
> testsuites/psxtests/psxhdrs/sys/socket/bind.c | 2 +-
> testsuites/psxtests/psxhdrs/sys/socket/connect.c | 6 +++---
> testsuites/psxtests/psxhdrs/sys/socket/getsockopt.c | 2 +-
> testsuites/psxtests/psxhdrs/sys/socket/send.c | 2 +-
> testsuites/psxtests/psxhdrs/sys/socket/sendmsg.c | 2 +-
> testsuites/psxtests/psxhdrs/sys/socket/sendto.c | 4 ++--
> testsuites/psxtests/psxhdrs/sys/socket/setsockopt.c | 2 +-
> testsuites/psxtests/psxhdrs/sys/stat/futimens.c | 4 ++--
> testsuites/psxtests/psxhdrs/sys/stat/utimensat.c | 4 ++--
> testsuites/psxtests/psxhdrs/sys/time/utimes.c | 8 ++++----
> testsuites/psxtests/psxhdrs/termios/cfgetispeed.c | 4 ++--
> testsuites/psxtests/psxhdrs/termios/cfgetospeed.c | 4 ++--
> testsuites/psxtests/psxhdrs/termios/cfsetispeed.c | 4 ++--
> testsuites/psxtests/psxhdrs/termios/cfsetospeed.c | 4 ++--
> testsuites/psxtests/psxhdrs/termios/tcgetattr.c | 4 ++--
> testsuites/psxtests/psxhdrs/termios/tcsetattr.c | 4 ++--
> testsuites/psxtests/psxhdrs/time/asctime.c | 2 +-
> testsuites/psxtests/psxhdrs/time/asctime_r.c | 2 +-
> testsuites/psxtests/psxhdrs/time/clock_settime.c | 2 +-
> testsuites/psxtests/psxhdrs/time/ctime.c | 2 +-
> testsuites/psxtests/psxhdrs/time/ctime_r.c | 2 +-
> testsuites/psxtests/psxhdrs/time/gmtime.c | 2 +-
> testsuites/psxtests/psxhdrs/time/gmtime_r.c | 2 +-
> testsuites/psxtests/psxhdrs/time/localtime.c | 2 +-
> testsuites/psxtests/psxhdrs/time/localtime_r.c | 2 +-
> testsuites/psxtests/psxhdrs/time/strftime.c | 2 +-
> testsuites/psxtests/psxhdrs/unistd/setgroups.c | 2 +-
> testsuites/psxtests/psxhdrs/utime/utime.c | 2 +-
> testsuites/psxtests/psxhdrs/wchar/mbsinit.c | 4 ++--
> testsuites/psxtests/psxkey07/init.c | 3 ++-
> testsuites/psxtests/psxkey08/init.c | 2 +-
> testsuites/psxtests/psxmsgq01/init.c | 2 +-
> testsuites/sptests/sp68/init.c | 2 +-
> testsuites/sptests/spfatal32/init.c | 5 +++++
> 62 files changed, 96 insertions(+), 89 deletions(-)
> diff --git a/testsuites/libtests/POSIX/readv.c
> b/testsuites/libtests/POSIX/readv.c
> index a980e9468c..6b0bf63f94 100644
> --- a/testsuites/libtests/POSIX/readv.c
> +++ b/testsuites/libtests/POSIX/readv.c
> @@ -14,7 +14,7 @@
> int main(void)
> - struct iovec iov;
> + struct iovec iov = { 0 };
> int count = 4;
> ssize_t ret;
> diff --git a/testsuites/libtests/POSIX/sigismember.c
> b/testsuites/libtests/POSIX/sigismember.c
> index ed980b70f0..f4c7d37cb2 100644
> --- a/testsuites/libtests/POSIX/sigismember.c
> +++ b/testsuites/libtests/POSIX/sigismember.c
> @@ -14,7 +14,7 @@
> int main(void)
> - sigset_t set;
> + sigset_t set = { 0 };
> int status;
> status = sigismember(&set, 21);
> diff --git a/testsuites/libtests/POSIX/sigprocmask.c
> b/testsuites/libtests/POSIX/sigprocmask.c
> index ba634e4660..25de0c28c7 100644
> --- a/testsuites/libtests/POSIX/sigprocmask.c
> +++ b/testsuites/libtests/POSIX/sigprocmask.c
> @@ -15,7 +15,8 @@
> int main(void)
> int rc;
> - sigset_t set1, set2;
> + sigset_t set1 = { 0 };
> + sigset_t set2 = { 0 };
> rc = sigprocmask(SIG_BLOCK, &set1, &set2);
> (void) rc;
> diff --git a/testsuites/libtests/POSIX/writev.c
> b/testsuites/libtests/POSIX/writev.c
> index 853b8a8ced..5b5068db65 100644
> --- a/testsuites/libtests/POSIX/writev.c
> +++ b/testsuites/libtests/POSIX/writev.c
> @@ -14,7 +14,7 @@
> int main(void)
> - struct iovec iov;
> int count = 4;
> ssize_t ret;
> diff --git a/testsuites/psxtests/psxhdrs/arpa/inet/inet_ntop.c
> b/testsuites/psxtests/psxhdrs/arpa/inet/inet_ntop.c
> index c3e3828b0b..5b64b565cc 100644
> --- a/testsuites/psxtests/psxhdrs/arpa/inet/inet_ntop.c
> +++ b/testsuites/psxtests/psxhdrs/arpa/inet/inet_ntop.c
> @@ -32,7 +32,7 @@ int test(void);
> int test(void)
> int af = 0;
> - struct in_addr addr;
> + struct in_addr addr = { 0 };
> char *dst = "string";
> const char *ret = inet_ntop(af, &addr, dst, sizeof(dst));
> diff --git a/testsuites/psxtests/psxhdrs/fcntl/openat.c
> b/testsuites/psxtests/psxhdrs/fcntl/openat.c
> index 927d56774b..1c15cd0867 100644
> --- a/testsuites/psxtests/psxhdrs/fcntl/openat.c
> +++ b/testsuites/psxtests/psxhdrs/fcntl/openat.c
> @@ -5,7 +5,7 @@
> * SPDX-License-Identifier: BSD-2-Clause
> * Copyright (C) 2018, Zenon
> * Redistribution and use in source and binary forms, with or without
> @@ -40,7 +40,7 @@ int test(void);
> int test(void){
> int i0, i1;
> - char c;
> + char c = '\0';
> i0 = 0;
> i1 = 0;
> diff --git a/testsuites/psxtests/psxhdrs/netdb/gethostbyaddr.c
> b/testsuites/psxtests/psxhdrs/netdb/gethostbyaddr.c
> index 07d734334b..cd2a271c37 100644
> --- a/testsuites/psxtests/psxhdrs/netdb/gethostbyaddr.c
> +++ b/testsuites/psxtests/psxhdrs/netdb/gethostbyaddr.c
> @@ -43,7 +43,7 @@
> int test( void )
> struct hostent *host;
> - struct in_addr ipv4addr;
> + struct in_addr ipv4addr = { 0 };
> host = gethostbyaddr( &ipv4addr, sizeof(ipv4addr), AF_INET );
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getdetachstate.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getdetachstate.c
> index 9bac990cd3..e2341a582d 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getdetachstate.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getdetachstate.c
> @@ -42,8 +42,8 @@ int test( void );
> int test( void )
> - pthread_attr_t attribute;
> - int state;
> + pthread_attr_t attribute = { 0 };
> + int state = 0;
> int result;
> result = pthread_attr_getdetachstate( &attribute, &state );
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getguardsize.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getguardsize.c
> index 6542efdf13..5a816d2115 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getguardsize.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getguardsize.c
> int test( void )
> - size_t size;
> + size_t size = 0;
> int result;
> result = pthread_attr_getguardsize( &attribute, &size );
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getinheritsched.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getinheritsched.c
> index a76172908b..86a4547164 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getinheritsched.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getinheritsched.c
> int test( void )
> - pthread_attr_t attr;
> - int inheritsched;
> + pthread_attr_t attr = { 0 };
> + int inheritsched = 0;
> int result;
> result = pthread_attr_getinheritsched( &attr, &inheritsched );
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedparam.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedparam.c
> index cc2dcb0198..743e2c4d21 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedparam.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedparam.c
> int test( void )
> - struct sched_param param;
> + struct sched_param param = { 0 };
> int result;
> result = pthread_attr_getschedparam( &attr, ¶m );
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedpolicy.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedpolicy.c
> index a341eeb337..60595d1a7a 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedpolicy.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getschedpolicy.c
> int test( void )
> - int policy;
> + int policy = 0;
> int result;
> result = pthread_attr_getschedpolicy( &attr, &policy );
> diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getscope.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getscope.c
> index 7023c29fce..7b97a7859c 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getscope.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getscope.c
> int test( void )
> - int contentionscope;
> + int contentionscope = 0;
> int result;
> result = pthread_attr_getscope( &attr, &contentionscope );
> diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstack.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstack.c
> index 177b775baf..f2d8a76362 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstack.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstack.c
> @@ -47,7 +47,7 @@ int test( void );
> int test( void )
> void *stackaddr;
> size_t stacksize;
> int result;
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstackaddr.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstackaddr.c
> index 4e7c17f40a..ed718c76d9 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstackaddr.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstackaddr.c
> int test( void )
> void *stackaddr;
> int result;
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstacksize.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstacksize.c
> index d9f8c4f718..ff9237a8eb 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstacksize.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_getstacksize.c
> @@ -46,8 +46,8 @@ int test( void );
> int test( void )
> - size_t size;
> + size_t size = 0;
> int result;
> result = pthread_attr_getstacksize( &attribute, &size );
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_setschedparam.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_setschedparam.c
> index 70f001fc67..643ccde907 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_attr_setschedparam.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_attr_setschedparam.c
> int test( void )
> int result;
> result = pthread_attr_setschedparam( &attr, ¶m );
> diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_cond_init.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_cond_init.c
> index 86f74d7cff..b7e2e2ad34 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_cond_init.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_cond_init.c
> @@ -43,7 +43,7 @@ int test( void );
> int test( void )
> pthread_cond_t cond = PTHREAD_COND_INITIALIZER;
> - pthread_condattr_t attribute;
> + pthread_condattr_t attribute = { 0 };
> int result;
> result = pthread_cond_init( &cond, &attribute );
> diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_cond_timedwait.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_cond_timedwait.c
> index 1c38af0067..72427266c1 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_cond_timedwait.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_cond_timedwait.c
> @@ -44,7 +44,7 @@ int test( void )
> pthread_mutex_t mutex = PTHREAD_MUTEX_INITIALIZER;
> - struct timespec abstime;
> + struct timespec abstime = { 0 };
> int result;
> result = pthread_cond_timedwait( &cond, &mutex, &abstime );
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_condattr_getpshared.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_condattr_getpshared.c
> index b37f1c00b9..21af201c65 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_condattr_getpshared.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_condattr_getpshared.c
> @@ -45,7 +45,7 @@ int test( void );
> int test( void )
> int pshared;
> int result;
> diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_create.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_create.c
> index bde6105933..de4f6b0bec 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_create.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_create.c
> @@ -53,7 +53,7 @@ void *test_task(
> int test( void )
> pthread_t thread;
> void *arg = NULL;
> int result;
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_getprioceiling.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_getprioceiling.c
> index 4f652283df..65b44fa779 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_getprioceiling.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_getprioceiling.c
> @@ -45,8 +45,8 @@ int test( void );
> int test( void )
> - pthread_mutex_t mutex;
> - int prioceiling;
> + pthread_mutex_t mutex = { 0 };
> + int prioceiling = 0;
> int result;
> result = pthread_mutex_getprioceiling( &mutex, &prioceiling );
> diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_init.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_init.c
> index 085d6f9835..1b42dbc0f3 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_init.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_init.c
> int test( void )
> - pthread_mutexattr_t attribute;
> + pthread_mutexattr_t attribute = { 0 };
> int result;
> result = pthread_mutex_init( &mutex, &attribute );
> diff --git a/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_timedlock.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_timedlock.c
> index c402d17a57..02f864493d 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_timedlock.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_mutex_timedlock.c
> @@ -46,7 +46,7 @@ int test( void );
> int test( void )
> - struct timespec timeout;
> + struct timespec timeout = { 0 };
> int result;
> result = pthread_mutex_timedlock( &mutex, &timeout );
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprioceiling.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprioceiling.c
> index a53535881c..675ef02d38 100644
> int test( void )
> int result;
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprotocol.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprotocol.c
> index 99cd093b17..da16c786b0 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprotocol.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getprotocol.c
> int test( void )
> - int protocol;
> + int protocol = 0;
> int result;
> result = pthread_mutexattr_getprotocol( &attribute, &protocol );
> diff --git
> a/testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getpshared.c
> b/testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getpshared.c
> index 3735b76b41..d8e8eaabeb 100644
> --- a/testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getpshared.c
> +++ b/testsuites/psxtests/psxhdrs/pthread/pthread_mutexattr_getpshared.c
> int test( void )
> - int pshared;
> + int pshared = 0;
> int result;
> result = pthread_mutexattr_getpshared( &attribute, &pshared );
> diff --git a/testsuites/psxtests/psxhdrs/sys/select/pselect.c
> b/testsuites/psxtests/psxhdrs/sys/select/pselect.c
> index d35a0d0921..ad96dda686 100644
> --- a/testsuites/psxtests/psxhdrs/sys/select/pselect.c
> +++ b/testsuites/psxtests/psxhdrs/sys/select/pselect.c
> fd_set readfds;
> fd_set writefds;
> fd_set errorfds;
> - sigset_t sigmask;
> + sigset_t sigmask = { 0 };
> return_value = pselect(nfds, &readfds, &writefds, &errorfds, &timeout,
> &sigmask);
> return return_value;
> diff --git a/testsuites/psxtests/psxhdrs/sys/socket/bind.c
> b/testsuites/psxtests/psxhdrs/sys/socket/bind.c
> index 3da39b31ff..2fa19f2c26 100644
> --- a/testsuites/psxtests/psxhdrs/sys/socket/bind.c
> +++ b/testsuites/psxtests/psxhdrs/sys/socket/bind.c
> @@ -44,7 +44,7 @@ int test(void);
> int test(void)
> int sockfd = 4;
> - struct sockaddr addr;
> + struct sockaddr addr = { 0 };
> socklen_t addrlen = sizeof(addr);
> return bind(sockfd, &addr, addrlen);
> diff --git a/testsuites/psxtests/psxhdrs/sys/socket/connect.c
> b/testsuites/psxtests/psxhdrs/sys/socket/connect.c
> index 1b8f5b9001..afb560ff52 100644
> --- a/testsuites/psxtests/psxhdrs/sys/socket/connect.c
> +++ b/testsuites/psxtests/psxhdrs/sys/socket/connect.c
> @@ -43,9 +43,9 @@ int test(void);
> int test(void)
> - int sockfd = 4;
> - socklen_t addrlen = sizeof(addr);
> + int sockfd = 4;
> + socklen_t addrlen = sizeof(addr);
> return connect(sockfd, &addr, addrlen);
> diff --git a/testsuites/psxtests/psxhdrs/sys/socket/getsockopt.c
> b/testsuites/psxtests/psxhdrs/sys/socket/getsockopt.c
> index 0ecf27dda5..e0cd442441 100644
> --- a/testsuites/psxtests/psxhdrs/sys/socket/getsockopt.c
> +++ b/testsuites/psxtests/psxhdrs/sys/socket/getsockopt.c
> @@ -48,7 +48,7 @@ int test(void)
> int optname = 67;
> int value;
> void *optval = &value;
> - socklen_t optlen;
> + socklen_t optlen = { 0 };
> return getsockopt(sockfd, level, optname, optval, &optlen);
> diff --git a/testsuites/psxtests/psxhdrs/sys/socket/send.c
> b/testsuites/psxtests/psxhdrs/sys/socket/send.c
> index b93a87f482..de2ad3ba5a 100644
> --- a/testsuites/psxtests/psxhdrs/sys/socket/send.c
> +++ b/testsuites/psxtests/psxhdrs/sys/socket/send.c
> @@ -44,7 +44,7 @@ ssize_t test(void);
> ssize_t test(void)
> int sockfd = 4;
> - int buffer;
> + int buffer = 0;
> void *buf = &buffer;
> size_t len = sizeof(buffer);
> int flags = 7;
> diff --git a/testsuites/psxtests/psxhdrs/sys/socket/sendmsg.c
> b/testsuites/psxtests/psxhdrs/sys/socket/sendmsg.c
> index 3205271572..a14b8ff8d4 100644
> --- a/testsuites/psxtests/psxhdrs/sys/socket/sendmsg.c
> +++ b/testsuites/psxtests/psxhdrs/sys/socket/sendmsg.c
> ssize_t test(void)
> int sockfd = 4;
> - struct msghdr msg;
> + struct msghdr msg = { 0 };
> int flags = 7;
> diff --git a/testsuites/psxtests/psxhdrs/sys/socket/sendto.c
> b/testsuites/psxtests/psxhdrs/sys/socket/sendto.c
> index 298d17f4ec..5050f1a0a5 100644
> --- a/testsuites/psxtests/psxhdrs/sys/socket/sendto.c
> +++ b/testsuites/psxtests/psxhdrs/sys/socket/sendto.c
> @@ -44,11 +44,11 @@ ssize_t test(void);
> ssize_t test(void)
> int sockfd = 4;
> - int buffer;
> + int buffer = 0;
> const void *buf = &buffer;
> int flags = 7;
> - struct sockaddr dest_addr;
> + struct sockaddr dest_addr = { 0 };
> socklen_t addrlen = sizeof(dest_addr);
> return sendto(sockfd, buf, len, flags, &dest_addr, addrlen);
> diff --git a/testsuites/psxtests/psxhdrs/sys/socket/setsockopt.c
> b/testsuites/psxtests/psxhdrs/sys/socket/setsockopt.c
> index d373add6de..e4d21d3837 100644
> --- a/testsuites/psxtests/psxhdrs/sys/socket/setsockopt.c
> +++ b/testsuites/psxtests/psxhdrs/sys/socket/setsockopt.c
> @@ -46,7 +46,7 @@ int test(void)
> int sockfd = 4;
> int level = SOL_SOCKET;
> int optname = 67;
> - int value;
> + int value = 0;
> socklen_t optlen = sizeof(value);
> diff --git a/testsuites/psxtests/psxhdrs/sys/stat/futimens.c
> b/testsuites/psxtests/psxhdrs/sys/stat/futimens.c
> index 75fa0ce0e6..9892352b71 100644
> --- a/testsuites/psxtests/psxhdrs/sys/stat/futimens.c
> +++ b/testsuites/psxtests/psxhdrs/sys/stat/futimens.c
> @@ -42,9 +42,9 @@ int test( void )
> int return_value;
> int fd = 1;
> - struct timespec times[2];
> + struct timespec times[2] = { 0 };
> return_value = futimens(fd, times);
> return (return_value != -1);
> \ No newline at end of file
> diff --git a/testsuites/psxtests/psxhdrs/sys/stat/utimensat.c
> b/testsuites/psxtests/psxhdrs/sys/stat/utimensat.c
> index c8c0767ce3..b74cc1a44b 100644
> --- a/testsuites/psxtests/psxhdrs/sys/stat/utimensat.c
> +++ b/testsuites/psxtests/psxhdrs/sys/stat/utimensat.c
> @@ -44,9 +44,9 @@ int test( void )
> int return_value;
> int fd = 1;
> char *path = "/";
> int flag = AT_SYMLINK_NOFOLLOW;
> return_value = utimensat(fd, path, times, flag);
> diff --git a/testsuites/psxtests/psxhdrs/sys/time/utimes.c
> b/testsuites/psxtests/psxhdrs/sys/time/utimes.c
> index ae69eb5ded..bebc7a77b4 100644
> --- a/testsuites/psxtests/psxhdrs/sys/time/utimes.c
> +++ b/testsuites/psxtests/psxhdrs/sys/time/utimes.c
> @@ -5,7 +5,7 @@
> @@ -41,8 +41,8 @@ int test(void);
> int test(void)
> int callback;
> - struct timeval tv;
> - callback = utimes(NULL, &tv);
> + struct timeval tv[2] = { 0 };
> + callback = utimes(NULL, &tv[0]);
> return (callback == -1);
> diff --git a/testsuites/psxtests/psxhdrs/termios/cfgetispeed.c
> b/testsuites/psxtests/psxhdrs/termios/cfgetispeed.c
> index e98a28179e..0c8d304a71 100644
> --- a/testsuites/psxtests/psxhdrs/termios/cfgetispeed.c
> +++ b/testsuites/psxtests/psxhdrs/termios/cfgetispeed.c
> @@ -40,11 +40,11 @@ int test( void );
> int test( void )
> - struct termios term;
> + struct termios term = { 0 };
> speed_t rate;
> rate = cfgetispeed(&term);
> (void) rate;
> return 0;
> diff --git a/testsuites/psxtests/psxhdrs/termios/cfgetospeed.c
> b/testsuites/psxtests/psxhdrs/termios/cfgetospeed.c
> index b326a78378..4d2e23ed50 100644
> --- a/testsuites/psxtests/psxhdrs/termios/cfgetospeed.c
> +++ b/testsuites/psxtests/psxhdrs/termios/cfgetospeed.c
> int test( void )
> speed_t rate;
> rate = cfgetospeed(&term);
> (void) rate;
> return 0;
> diff --git a/testsuites/psxtests/psxhdrs/termios/cfsetispeed.c
> b/testsuites/psxtests/psxhdrs/termios/cfsetispeed.c
> index b73dbffce1..0f8ddfff57 100644
> --- a/testsuites/psxtests/psxhdrs/termios/cfsetispeed.c
> +++ b/testsuites/psxtests/psxhdrs/termios/cfsetispeed.c
> @@ -41,10 +41,10 @@ int test( void );
> int test( void )
> int result;
> speed_t speed = B0;
> result = cfsetispeed(&term, speed);
> return result;
> diff --git a/testsuites/psxtests/psxhdrs/termios/cfsetospeed.c
> b/testsuites/psxtests/psxhdrs/termios/cfsetospeed.c
> index 8377fc6e26..8d5404c954 100644
> --- a/testsuites/psxtests/psxhdrs/termios/cfsetospeed.c
> +++ b/testsuites/psxtests/psxhdrs/termios/cfsetospeed.c
> int test( void )
> int result;
> speed_t speed = B0;
> result = cfsetospeed(&term, speed);
> return result;
> diff --git a/testsuites/psxtests/psxhdrs/termios/tcgetattr.c
> b/testsuites/psxtests/psxhdrs/termios/tcgetattr.c
> index d00336b214..843b7c8281 100644
> --- a/testsuites/psxtests/psxhdrs/termios/tcgetattr.c
> +++ b/testsuites/psxtests/psxhdrs/termios/tcgetattr.c
> int result;
> int fildes = 0;
> result = tcgetattr(fildes, &term);
> return result;
> diff --git a/testsuites/psxtests/psxhdrs/termios/tcsetattr.c
> b/testsuites/psxtests/psxhdrs/termios/tcsetattr.c
> index e2bd6980a9..da0e0ea62d 100644
> --- a/testsuites/psxtests/psxhdrs/termios/tcsetattr.c
> +++ b/testsuites/psxtests/psxhdrs/termios/tcsetattr.c
> @@ -43,9 +43,9 @@ int test( void )
> int result;
> int fildes = 0;
> int optional_actions = 0;
> result = tcsetattr(fildes, optional_actions, &term);
> return result;
> diff --git a/testsuites/psxtests/psxhdrs/time/asctime.c
> b/testsuites/psxtests/psxhdrs/time/asctime.c
> index c02a543d6b..400dbf5258 100644
> --- a/testsuites/psxtests/psxhdrs/time/asctime.c
> +++ b/testsuites/psxtests/psxhdrs/time/asctime.c
> @@ -42,7 +42,7 @@ int test( void );
> int test( void )
> char *buffer;
> - struct tm timestruct;
> + struct tm timestruct = { 0 };
> buffer = asctime( ×truct );
> diff --git a/testsuites/psxtests/psxhdrs/time/asctime_r.c
> b/testsuites/psxtests/psxhdrs/time/asctime_r.c
> index 231ea14dfb..c0a22b7d6b 100644
> --- a/testsuites/psxtests/psxhdrs/time/asctime_r.c
> +++ b/testsuites/psxtests/psxhdrs/time/asctime_r.c
> int test( void )
> char *buffer_pointer;
> char buffer[ 80 ];
> buffer_pointer = asctime_r( ×truct, buffer );
> diff --git a/testsuites/psxtests/psxhdrs/time/clock_settime.c
> b/testsuites/psxtests/psxhdrs/time/clock_settime.c
> index 8a4d88c37f..8584e1c61f 100644
> --- a/testsuites/psxtests/psxhdrs/time/clock_settime.c
> +++ b/testsuites/psxtests/psxhdrs/time/clock_settime.c
> int test( void )
> clockid_t clock_id = 0;
> - struct timespec tp;
> + struct timespec tp = { 0 };
> int result;
> result = clock_settime( clock_id, &tp );
> diff --git a/testsuites/psxtests/psxhdrs/time/ctime.c
> b/testsuites/psxtests/psxhdrs/time/ctime.c
> index f778e726a9..67dddf21ca 100644
> --- a/testsuites/psxtests/psxhdrs/time/ctime.c
> +++ b/testsuites/psxtests/psxhdrs/time/ctime.c
> int test( void )
> char *buffer;
> - time_t time;
> + time_t time = { 0 };
> buffer = ctime( &time );
> diff --git a/testsuites/psxtests/psxhdrs/time/ctime_r.c
> b/testsuites/psxtests/psxhdrs/time/ctime_r.c
> index b973a504ae..30f1285d0a 100644
> --- a/testsuites/psxtests/psxhdrs/time/ctime_r.c
> +++ b/testsuites/psxtests/psxhdrs/time/ctime_r.c
> char buffer[ 80 ];
> - time_t time;
> buffer_pointer = ctime_r( &time, buffer );
> diff --git a/testsuites/psxtests/psxhdrs/time/gmtime.c
> b/testsuites/psxtests/psxhdrs/time/gmtime.c
> index 7118162c84..d7c08726ad 100644
> --- a/testsuites/psxtests/psxhdrs/time/gmtime.c
> +++ b/testsuites/psxtests/psxhdrs/time/gmtime.c
> @@ -41,7 +41,7 @@ int test( void );
> int test( void )
> - time_t time;
> struct tm *timestruct;
> timestruct = gmtime( &time );
> diff --git a/testsuites/psxtests/psxhdrs/time/gmtime_r.c
> b/testsuites/psxtests/psxhdrs/time/gmtime_r.c
> index 58f6a3212a..128e5107e0 100644
> --- a/testsuites/psxtests/psxhdrs/time/gmtime_r.c
> +++ b/testsuites/psxtests/psxhdrs/time/gmtime_r.c
> int test( void )
> - time_t time;
> struct tm *timestruct_pointer;
> diff --git a/testsuites/psxtests/psxhdrs/time/localtime.c
> b/testsuites/psxtests/psxhdrs/time/localtime.c
> index 674d8e43c2..7f1b4e481d 100644
> --- a/testsuites/psxtests/psxhdrs/time/localtime.c
> +++ b/testsuites/psxtests/psxhdrs/time/localtime.c
> int test( void )
> - time_t time;
> timestruct = localtime( &time );
> diff --git a/testsuites/psxtests/psxhdrs/time/localtime_r.c
> b/testsuites/psxtests/psxhdrs/time/localtime_r.c
> index be85af36c5..10338db9fe 100644
> --- a/testsuites/psxtests/psxhdrs/time/localtime_r.c
> +++ b/testsuites/psxtests/psxhdrs/time/localtime_r.c
> int test( void )
> - time_t time;
> diff --git a/testsuites/psxtests/psxhdrs/time/strftime.c
> b/testsuites/psxtests/psxhdrs/time/strftime.c
> index ee27e7b8d4..6b75cdac1e 100644
> --- a/testsuites/psxtests/psxhdrs/time/strftime.c
> +++ b/testsuites/psxtests/psxhdrs/time/strftime.c
> size_t length;
> size_t max_length;
> char buffer[ 80 ];
> max_length = sizeof( buffer );
> diff --git a/testsuites/psxtests/psxhdrs/unistd/setgroups.c
> b/testsuites/psxtests/psxhdrs/unistd/setgroups.c
> index b40547a5e8..a29cb05978 100644
> --- a/testsuites/psxtests/psxhdrs/unistd/setgroups.c
> +++ b/testsuites/psxtests/psxhdrs/unistd/setgroups.c
> int test( void )
> - gid_t grouplist[ 20 ];
> + gid_t grouplist[ 20 ] = { 0 } ;
> int gidsetsize;
> int result;
> diff --git a/testsuites/psxtests/psxhdrs/utime/utime.c
> b/testsuites/psxtests/psxhdrs/utime/utime.c
> index 6236a84637..db619baecc 100644
> --- a/testsuites/psxtests/psxhdrs/utime/utime.c
> +++ b/testsuites/psxtests/psxhdrs/utime/utime.c
> int test( void )
> int result;
> - const struct utimbuf buff;
> + const struct utimbuf buff = { 0 };
> const char *path = "/tmp/myfile";
> result = utime(path, &buff);
> diff --git a/testsuites/psxtests/psxhdrs/wchar/mbsinit.c
> b/testsuites/psxtests/psxhdrs/wchar/mbsinit.c
> index 21a39ee2ce..5432520f86 100644
> --- a/testsuites/psxtests/psxhdrs/wchar/mbsinit.c
> +++ b/testsuites/psxtests/psxhdrs/wchar/mbsinit.c
> @@ -5,7 +5,7 @@
> int test(void)
> - const mbstate_t state;
> + const mbstate_t state = { 0 };
> return mbsinit(&state);
> diff --git a/testsuites/psxtests/psxkey07/init.c
> b/testsuites/psxtests/psxkey07/init.c
> index d9696a0e28..593df739db 100644
> --- a/testsuites/psxtests/psxkey07/init.c
> +++ b/testsuites/psxtests/psxkey07/init.c
> @@ -55,6 +55,7 @@ rtems_task Test_Thread(rtems_task_argument argument)
> int *value_p, *value_p2;
> value_p = malloc( sizeof( int ) );
> + rtems_test_assert(value_p != NULL);
> sc = pthread_setspecific( Key, value_p );
> rtems_test_assert( !sc );
> @@ -119,7 +120,7 @@ rtems_task Init(rtems_task_argument argument)
> pthread_mutex_lock( &mutex1 );
> rc = rtems_task_create(
> - rtems_build_name( 'T', 'E', 'S', 'T' ),
> + rtems_build_name( 'T', 'E', 'S', 'T' ),
> 1,
> RTEMS_MINIMUM_STACK_SIZE,
> RTEMS_DEFAULT_MODES,
> diff --git a/testsuites/psxtests/psxkey08/init.c
> b/testsuites/psxtests/psxkey08/init.c
> index 2bd00bc53d..ed0b6e8554 100644
> --- a/testsuites/psxtests/psxkey08/init.c
> +++ b/testsuites/psxtests/psxkey08/init.c
> @@ -51,7 +51,7 @@ static rtems_name name1, name2;
> static rtems_task test_task(rtems_task_argument arg)
> - rtems_status_code sc;
> + rtems_status_code sc = 0;
> const void *value_p;
> const void *value_p2;
> diff --git a/testsuites/psxtests/psxmsgq01/init.c
> b/testsuites/psxtests/psxmsgq01/init.c
> index 3c77beb038..c6b3d92464 100644
> --- a/testsuites/psxtests/psxmsgq01/init.c
> +++ b/testsuites/psxtests/psxmsgq01/init.c
> @@ -1133,7 +1133,7 @@ void verify_with_threads(void)
> void validate_mq_setattr(void)
> - struct mq_attr attr;
> + struct mq_attr attr = { 0 };
> struct mq_attr save_attr[ NUMBER_OF_TEST_QUEUES ];
> int status;
> int i;
> diff --git a/testsuites/sptests/sp68/init.c
> b/testsuites/sptests/sp68/init.c
> index 5443dfbb5e..8e0bd1c8c8 100644
> --- a/testsuites/sptests/sp68/init.c
> +++ b/testsuites/sptests/sp68/init.c
> @@ -166,7 +166,7 @@ static void obtain_callback(rtems_id timer_id, void
> *arg)
> static void release_callback(rtems_id timer_id, void *arg)
> rtems_status_code sc = RTEMS_SUCCESSFUL;
> - char buf [1];
> + char buf [1] = { 0 };
> size_t size = sizeof(buf);
> uint32_t released = 0;
> diff --git a/testsuites/sptests/spfatal32/init.c
> b/testsuites/sptests/spfatal32/init.c
> index 78dcfeb669..1a1e0bee79 100644
> --- a/testsuites/sptests/spfatal32/init.c
> +++ b/testsuites/sptests/spfatal32/init.c
> @@ -39,6 +39,11 @@
> #define FATAL_ERROR_EXPECTED_SOURCE RTEMS_FATAL_SOURCE_INVALID_HEAP_FREE
> #define FATAL_ERROR_EXPECTED_ERROR 1
> + * Disable for the specific test case.
> +#pragma GCC diagnostic ignored "-Wfree-nonheap-object"
> static void force_error(void)
> uintptr_t invalid = 1;
> 2.24.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220620/0f197bc6/attachment-0001.htm>
