[PATCH] kern_tc.c: Provide a weak hardpps() implementation
Tue Jun 21 10:28:04 UTC 2022
The real implementation of hardpps() is defined in kern_ntptime.c.  Use it only
if the NTP support is needed by the application.
Update #2349.
 cpukit/score/src/kern_tc.c | 12 ++++++++++++
 1 file changed, 12 insertions(+)
diff --git a/cpukit/score/src/kern_tc.c b/cpukit/score/src/kern_tc.c
index 78d7fa1e3f..449c830905 100644
--- a/cpukit/score/src/kern_tc.c
+++ b/cpukit/score/src/kern_tc.c
@@ -2079,6 +2079,18 @@ pps_ioctl(u_long cmd, caddr_t data, struct pps_state *pps)
 #ifdef __rtems__
+ * The real implementation of hardpps() is defined in kern_ntptime.c.  Use it
+ * only if the NTP support is needed by the application.
+RTEMS_WEAK void
+hardpps(struct timespec *tsp, long nsec);
+	(void)tps;
+	(void)nsec;
 static int
 default_wait(struct pps_state *pps, struct timespec timeout)
2.35.3
