[PATCH] libstdc++: testsuite: fs rename to self may fail
Sebastian Huber
Wed Jun 22 06:33:57 UTC 2022
On 22/06/2022 08:24, Alexandre Oliva via Libstdc++ wrote:
> rtems6's rename() implementation errors with EEXIST when the rename-to
> filename exists, even when renaming a file to itself or when renaming
> a nonexisting file. Adjust expectations.
> Regstrapped on x86_64-linux-gnu, also tested with a cross to
> aarch64-rtems6. Ok to install?
> PS:https://devel.rtems.org/ticket/2169 doesn't seem to suggest plans to
> change behavior so as to comply with POSIX.
I would not adjust the test case to cope with systems which are not in
line with POSIX. In the past RTEMS used the GCC tests to check that the
implementation is in line with other systems. The RTEMS ticket is still
open. There just needs to be someone who thinks this bug is important
enough to fix.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
