[newlib 20/22] sys/_bitset.h: Fix fall-out from commit 5e04571cf3c
Sebastian Huber
Wed Jun 22 08:24:43 UTC 2022
The changes to the bitset macros allowed sched.h to be included
into userland programs without name space pollution due to BIT_*
and BITSET_* macros.
The definition of a "struct bitset" had been overlooked. This name
space pollution caused the build of port print/miktex to fail.
This commit makes the definition of struct bitset depend on the
same condition as the visibility of the BIT_* and BITSET_* macros,
i.e. needs _KERNEL or _WANT_FREEBSD_BITSET to be defined before
including sys/_bitset.h.
It has been tested with "make universe" since a prior attempt to
fix the issue broke the PowerPC64 kernel build.
This commit shall be MFCed together with commit 5e04571cf3c.
Reported by: arrowd
MFC after: 1 month
newlib/libc/sys/rtems/include/sys/_bitset.h | 7 ++++---
1 file changed, 4 insertions(+), 3 deletions(-)
diff --git a/newlib/libc/sys/rtems/include/sys/_bitset.h b/newlib/libc/sys/rtems/include/sys/_bitset.h
index 1c167daf3..70b9713ff 100644
--- a/newlib/libc/sys/rtems/include/sys/_bitset.h
+++ b/newlib/libc/sys/rtems/include/sys/_bitset.h
@@ -52,7 +52,7 @@ struct _t { \
* Helper to declare a bitset without it's size being a constant.
- * Sadly we cannot declare a bitset struct with '__bits[]', because it's
+ * Sadly we cannot declare a bitset struct with 'bits[]', because it's
* the only member of the struct and the compiler complains.
#define __BITSET_DEFINE_VAR(_t) __BITSET_DEFINE(_t, 1)
@@ -61,11 +61,12 @@ struct _t { \
* Define a default type that can be used while manually specifying size
* to every call.
-__BITSET_DEFINE(bitset, 1);
#if defined(_KERNEL) || defined(_WANT_FREEBSD_BITSET)
+__BITSET_DEFINE(bitset, 1);
#define BITSET_DEFINE(_t, _s) __BITSET_DEFINE(_t, _s)
#define BITSET_DEFINE_VAR(_t) __BITSET_DEFINE_VAR(_t)
-#endif
+#endif /* defined(_KERNEL) || defined(_WANT_FREEBSD_BITSET) */
#endif /* !_SYS__BITSET_H_ */
2.35.3
