Fwd: New Defects reported by Coverity Scan for RTEMS
Joel Sherrill
joel at rtems.org
Wed Jun 22 10:27:56 UTC 2022
---------- Forwarded message ---------
Date: Wed, Jun 22, 2022, 1:54 AM
Subject: New Defects reported by Coverity Scan for RTEMS
To: <build at rtems.org>
Hi,
Please find the latest report on new defect(s) introduced to RTEMS found
with Coverity Scan.
2 new defect(s) introduced to RTEMS found with Coverity Scan.
2 defect(s), reported by Coverity Scan earlier, were marked fixed in the
recent build analyzed by Coverity Scan.
New defect(s) Reported-by: Coverity Scan
Showing 2 of 2 defect(s)
** CID 1506523: Error handling issues (CHECKED_RETURN)
/cpukit/libfs/src/ftpfs/tftpDriver.c: 727 in process_data_packet()
________________________________________________________________________________________________________
*** CID 1506523: Error handling issues (CHECKED_RETURN)
721 if (tp->at_eof) {
722 plen = prepare_ack_packet_for_sending (tp, true, &send_buf,
NULL, NULL);
723
724 /*
725 * Send it. Errors during send will not matter for this
last ACK.
726 */
>>> Calling "sendto(tp->socket, send_buf, plen, 0, (struct sockaddr
*)&tp->farAddress, 16U)" without checking return value. This library
function may fail and return an error code.
727 sendto (
728 tp->socket,
729 send_buf,
730 plen,
731 0,
732 (struct sockaddr *) &tp->farAddress,
** CID 1506522: Error handling issues (CHECKED_RETURN)
/cpukit/libfs/src/ftpfs/tftpDriver.c: 529 in send_error()
*** CID 1506522: Error handling issues (CHECKED_RETURN)
523 }
524 len += sizeof (msg.opcode) + sizeof (msg.errorCode) + 1;
525
526 /*
527 * Send it
528 */
>>> Calling "sendto(tp->socket, (char *)&msg, len, 0, (struct sockaddr
*)to, 16U)" without checking return value. This library function may fail
529 sendto (tp->socket, (char *)&msg, len, 0, (struct sockaddr
*)to, sizeof *to);
530 }
531
532 /*
533 * Send a message to make the other end shut up
534 */
To view the defects in Coverity Scan visit,
https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3DYDHO_EU3W9teASMK00lBXX9WT4lsogDrkCcNZLvg-2FVxwAXMrH8dAzPlWwiDYV1U-2F8xymjxfhXw64FmQzC9v0sejwWoxbemyTlKty07VAeUEneYgIIfMdwjCEXcgn0Re6oeOSfglcSXS8UfePUftOOg0aPvHZGZ-2FivjJ4qNrmfe53lCcuzTJT3zjQOLsqCN9TcK7sxd1vR1mMgE-2BjmivxhPcovrA-3D-3D
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20220622/b92dd52d/attachment-0001.htm>
