[libbsd 4/4] if_lpe.c: Use interface transmit
Sebastian Huber
Thu Jun 23 09:20:20 UTC 2022
This avoids the need for a transmit task and transmit interrupts.
rtemsbsd/sys/arm/lpc/if_lpe.c | 502 ++++++++++++++--------------------
1 file changed, 206 insertions(+), 296 deletions(-)
diff --git a/rtemsbsd/sys/arm/lpc/if_lpe.c b/rtemsbsd/sys/arm/lpc/if_lpe.c
index 0ae60884..8c58a58d 100755
--- a/rtemsbsd/sys/arm/lpc/if_lpe.c
+++ b/rtemsbsd/sys/arm/lpc/if_lpe.c
@@ -264,8 +264,6 @@ static volatile lpc_eth_controller *const lpc_eth =
#define LPC_ETH_EVENT_INIT_TX RTEMS_EVENT_1
-#define LPC_ETH_EVENT_TXSTART RTEMS_EVENT_2
#define LPC_ETH_EVENT_INTERRUPT RTEMS_EVENT_3
#define LPC_ETH_EVENT_STOP RTEMS_EVENT_4
@@ -275,9 +273,6 @@ static volatile lpc_eth_controller *const lpc_eth =
#define LPC_ETH_INTERRUPT_RECEIVE \
(ETH_INT_RX_ERROR | ETH_INT_RX_FINISHED | ETH_INT_RX_DONE)
-#define LPC_ETH_INTERRUPT_TRANSMIT \
- (ETH_INT_TX_DONE | ETH_INT_TX_FINISHED | ETH_INT_TX_ERROR)
#define LPC_ETH_RX_STAT_ERRORS \
(ETH_RX_STAT_CRC_ERROR \
| ETH_RX_STAT_SYMBOL_ERROR \
@@ -317,7 +312,6 @@ typedef struct {
uint32_t anlpar;
struct callout watchdog_callout;
rtems_id receive_task;
- rtems_id transmit_task;
unsigned rx_unit_count;
unsigned tx_unit_count;
volatile lpc_eth_transfer_descriptor *rx_desc_table;
@@ -331,7 +325,6 @@ typedef struct {
unsigned received_frames;
unsigned receive_interrupts;
unsigned transmitted_frames;
- unsigned transmit_interrupts;
unsigned receive_drop_errors;
unsigned receive_overrun_errors;
unsigned receive_fragment_errors;
@@ -435,26 +428,14 @@ static void lpc_eth_interrupt_handler(void *arg)
} else if ((is & LPC_ETH_INTERRUPT_RECEIVE) != 0) {
re = LPC_ETH_EVENT_INTERRUPT;
ie |= LPC_ETH_INTERRUPT_RECEIVE;
+ ++e->receive_interrupts;
/* Send events to receive task */
if (re != 0) {
- ++e->receive_interrupts;
(void) rtems_event_send(e->receive_task, re);
- /* Check transmit interrupts */
- if ((is & LPC_ETH_INTERRUPT_TRANSMIT) != 0) {
- te = LPC_ETH_EVENT_INTERRUPT;
- ie |= LPC_ETH_INTERRUPT_TRANSMIT;
- /* Send events to transmit task */
- if (te != 0) {
- ++e->transmit_interrupts;
- (void) rtems_event_send(e->transmit_task, te);
LPC_ETH_PRINTK("interrupt: rx = 0x%08x, tx = 0x%08x\n", re, te);
/* Update interrupt mask */
@@ -482,24 +463,6 @@ static void lpc_eth_disable_receive_interrupts(void)
rtems_interrupt_enable(level);
-static void lpc_eth_enable_transmit_interrupts(void)
- rtems_interrupt_level level;
- rtems_interrupt_disable(level);
- lpc_eth->intenable |= LPC_ETH_INTERRUPT_TRANSMIT;
- rtems_interrupt_enable(level);
-static void lpc_eth_disable_transmit_interrupts(void)
- lpc_eth->intenable &= ~LPC_ETH_INTERRUPT_TRANSMIT;
static void lpc_eth_initialize_transmit(lpc_eth_driver_entry *e)
volatile uint32_t *const status = e->tx_status_table;
@@ -512,9 +475,6 @@ static void lpc_eth_initialize_transmit(lpc_eth_driver_entry *e)
#endif
uint32_t produce_index;
- /* Disable transmit interrupts */
- lpc_eth_disable_transmit_interrupts();
/* Disable transmitter */
lpc_eth->command &= ~ETH_CMD_TX_ENABLE;
@@ -526,9 +486,6 @@ static void lpc_eth_initialize_transmit(lpc_eth_driver_entry *e)
/* Reset */
lpc_eth->command |= ETH_CMD_TX_RESET;
- /* Clear transmit interrupts */
- lpc_eth->intclear = LPC_ETH_INTERRUPT_TRANSMIT;
/* Transmit descriptors */
lpc_eth->txdescriptornum = index_max;
lpc_eth->txdescriptor = (uint32_t) desc;
@@ -537,12 +494,8 @@ static void lpc_eth_initialize_transmit(lpc_eth_driver_entry *e)
#ifdef LPC_ETH_CONFIG_USE_TRANSMIT_DMA
/* Discard outstanding fragments (= data loss) */
for (produce_index = 0; produce_index <= index_max; ++produce_index) {
- struct mbuf *victim = mbufs [produce_index];
- if (victim != NULL) {
- m_free(victim);
- mbufs [produce_index] = NULL;
+ m_freem(mbufs [produce_index]);
+ mbufs [produce_index] = NULL;
#else
/* Initialize descriptor table */
@@ -815,20 +768,10 @@ static struct mbuf *lpc_eth_next_fragment(
uint32_t *ctrl
- struct mbuf *n = NULL;
- int size = 0;
+ struct mbuf *n;
+ int size;
while (true) {
- if (m == NULL) {
- /* Dequeue first fragment of the next frame */
- IF_DEQUEUE(&ifp->if_snd, m);
- /* Empty queue? */
- if (m == NULL) {
- return m;
/* Get fragment size */
size = m->m_len;
@@ -836,8 +779,12 @@ static struct mbuf *lpc_eth_next_fragment(
/* Now we have a not empty fragment */
break;
} else {
- /* Discard empty fragments */
- m = m_free(m);
+ /* Skip empty fragments */
+ m = m->m_next;
+ if (m == NULL) {
+ return NULL;
@@ -859,266 +806,224 @@ static struct mbuf *lpc_eth_next_fragment(
return m;
-static void lpc_eth_transmit_task(rtems_task_argument arg)
+static void lpc_eth_tx_reclaim(lpc_eth_driver_entry *e, struct ifnet *ifp)
- rtems_status_code sc = RTEMS_SUCCESSFUL;
- rtems_event_set events = 0;
- lpc_eth_driver_entry *e = (lpc_eth_driver_entry *) arg;
- struct ifnet *ifp = e->ifp;
- volatile lpc_eth_transfer_descriptor *const desc = e->tx_desc_table;
+ volatile lpc_eth_transfer_descriptor *const desc = e->tx_desc_table;
struct mbuf **const mbufs = e->tx_buf_table;
#else
char *const buf = e->tx_buf_table;
#endif
- struct mbuf *m = NULL;
uint32_t const index_max = e->tx_unit_count - 1;
- uint32_t ctrl = 0;
+ uint32_t consume_index = e->tx_consume_index;
- LPC_ETH_PRINTF("%s\n", __func__);
- /* Main event loop */
+ /* Free consumed fragments */
while (true) {
- uint32_t produce_index;
- uint32_t consume_index;
- #ifndef LPC_ETH_CONFIG_USE_TRANSMIT_DMA
- uint32_t frame_length;
- char *frame_buffer;
- #endif
- /* Wait for events */
- sc = rtems_event_receive(
- LPC_ETH_EVENT_STOP
- | LPC_ETH_EVENT_TXSTART
- | LPC_ETH_EVENT_INTERRUPT,
- RTEMS_EVENT_ANY | RTEMS_WAIT,
- RTEMS_NO_TIMEOUT,
- &events
- BSD_ASSERT(sc == RTEMS_SUCCESSFUL);
- LPC_ETH_PRINTF("tx: wake up: 0x%08" PRIx32 "\n", events);
+ /* Save last known consume index */
+ uint32_t c = consume_index;
- /* Stop transmitter? */
- if ((events & LPC_ETH_EVENT_STOP) != 0) {
- lpc_eth_control_request_complete(e);
+ /* Get new consume index */
+ consume_index = lpc_eth->txconsumeindex;
- continue;
+ /* Nothing consumed in the meantime? */
+ if (c == consume_index) {
+ break;
- LPE_LOCK(e);
+ while (c != consume_index) {
+ uint32_t s = status [c];
- /* Get indices */
- produce_index = e->tx_produce_index;
- consume_index = e->tx_consume_index;
- /* Fresh frame length and buffer start */
- frame_length = 0;
- frame_buffer = (char *) desc [produce_index].start;
- #endif
+ /* Update error counters */
+ if ((s & (ETH_TX_STAT_ERROR | ETH_TX_STAT_NO_DESCRIPTOR)) != 0) {
+ if ((s & ETH_TX_STAT_UNDERRUN) != 0) {
+ ++e->transmit_underrun_errors;
+ if ((s & ETH_TX_STAT_LATE_COLLISION) != 0) {
+ ++e->transmit_late_collision_errors;
+ if ((s & ETH_TX_STAT_EXCESSIVE_COLLISION) != 0) {
+ ++e->transmit_excessive_collision_errors;
+ if ((s & ETH_TX_STAT_EXCESSIVE_DEFER) != 0) {
+ ++e->transmit_excessive_defer_errors;
+ if ((s & ETH_TX_STAT_NO_DESCRIPTOR) != 0) {
+ ++e->transmit_no_descriptor_errors;
- /* Free consumed fragments */
- while (true) {
- /* Save last known consume index */
- uint32_t c = consume_index;
+ #ifdef LPC_ETH_CONFIG_USE_TRANSMIT_DMA
+ /* Release mbuf */
+ m_freem(mbufs [c]);
+ mbufs [c] = NULL;
+ #endif
- /* Clear transmit interrupt status */
+ /* Next consume index */
+ c = lpc_eth_increment(c, index_max);
- /* Get new consume index */
- consume_index = lpc_eth->txconsumeindex;
+ e->tx_consume_index = consume_index;
- /* Nothing consumed in the meantime? */
- if (c == consume_index) {
- break;
+static int lpc_eth_tx_enqueue(
+ lpc_eth_driver_entry *e,
+ struct ifnet *ifp,
+ struct mbuf *m0
+ struct mbuf **const mbufs = e->tx_buf_table;
+ #else
+ char *const buf = e->tx_buf_table;
+ uint32_t frame_length;
+ char *frame_buffer;
+ #endif
+ uint32_t const index_max = e->tx_unit_count - 1;
+ uint32_t produce_index = e->tx_produce_index;
+ struct mbuf *m = m0;
- while (c != consume_index) {
- uint32_t s = status [c];
+ while (true) {
+ uint32_t ctrl;
- /* Update error counters */
- if ((s & (ETH_TX_STAT_ERROR | ETH_TX_STAT_NO_DESCRIPTOR)) != 0) {
- if ((s & ETH_TX_STAT_UNDERRUN) != 0) {
- ++e->transmit_underrun_errors;
- if ((s & ETH_TX_STAT_LATE_COLLISION) != 0) {
- ++e->transmit_late_collision_errors;
- if ((s & ETH_TX_STAT_EXCESSIVE_COLLISION) != 0) {
- ++e->transmit_excessive_collision_errors;
- if ((s & ETH_TX_STAT_EXCESSIVE_DEFER) != 0) {
- ++e->transmit_excessive_defer_errors;
- if ((s & ETH_TX_STAT_NO_DESCRIPTOR) != 0) {
- ++e->transmit_no_descriptor_errors;
+ /* Compute next produce index */
+ uint32_t p = lpc_eth_increment(produce_index, index_max);
- #ifdef LPC_ETH_CONFIG_USE_TRANSMIT_DMA
- /* Release mbuf */
- m_free(mbufs [c]);
- mbufs [c] = NULL;
- #endif
+ /* Queue full? */
+ if (p == consume_index) {
+ LPC_ETH_PRINTF("tx: full queue: 0x%08x\n", m);
- /* Next consume index */
- c = lpc_eth_increment(c, index_max);
+ /* The queue is full */
+ return ENOBUFS;
- /* Transmit new fragments */
- while (true) {
- /* Compute next produce index */
- uint32_t p = lpc_eth_increment(produce_index, index_max);
+ /* Get next fragment and control value */
+ m = lpc_eth_next_fragment(ifp, m, &ctrl);
- /* Get next fragment and control value */
- m = lpc_eth_next_fragment(ifp, m, &ctrl);
+ /* New fragment? */
+ if (m != NULL) {
+ /* Set the transfer data */
+ rtems_cache_flush_multiple_data_lines(
+ mtod(m, const void *),
+ (size_t) m->m_len
+ desc [produce_index].start = mtod(m, uint32_t);
+ desc [produce_index].control = ctrl;
+ (void *) &desc [produce_index],
+ sizeof(desc [0])
+ LPC_ETH_PRINTF(
+ "tx: %02" PRIu32 ": %u %s\n",
+ produce_index, m->m_len,
+ (ctrl & ETH_TX_CTRL_LAST) != 0 ? "L" : ""
- /* Queue full? */
- if (p == consume_index) {
- LPC_ETH_PRINTF("tx: full queue: 0x%08x\n", m);
+ /* Next produce index */
+ produce_index = p;
- /* The queue is full, wait for transmit interrupt */
- break;
+ /* Last fragment of a frame? */
+ if ((ctrl & ETH_TX_CTRL_LAST) != 0) {
+ /* Update the produce index */
+ lpc_eth->txproduceindex = produce_index;
+ e->tx_produce_index = produce_index;
- /* New fragment? */
- if (m != NULL) {
- /* Set the transfer data */
- rtems_cache_flush_multiple_data_lines(
- mtod(m, const void *),
- (size_t) m->m_len
- desc [produce_index].start = mtod(m, uint32_t);
- desc [produce_index].control = ctrl;
- (void *) &desc [produce_index],
- sizeof(desc [0])
- mbufs [produce_index] = m;
+ mbufs [produce_index] = m0;
- LPC_ETH_PRINTF(
- "tx: %02" PRIu32 ": %u %s\n",
- produce_index, m->m_len,
- (ctrl & ETH_TX_CTRL_LAST) != 0 ? "L" : ""
+ /* Increment transmitted frames counter */
+ ++e->transmitted_frames;
- /* Next produce index */
- produce_index = p;
+ return 0;
- /* Last fragment of a frame? */
- if ((ctrl & ETH_TX_CTRL_LAST) != 0) {
- /* Update the produce index */
- lpc_eth->txproduceindex = produce_index;
+ /* Next fragment of the frame */
+ m = m->m_next;
+ #else
+ size_t fragment_length = (size_t) m->m_len;
+ void *fragment_start = mtod(m, void *);
+ uint32_t new_frame_length = frame_length + fragment_length;
- /* Increment transmitted frames counter */
- ++e->transmitted_frames;
+ /* Check buffer size */
+ if (new_frame_length > LPC_ETH_CONFIG_TX_BUF_SIZE) {
+ LPC_ETH_PRINTF("tx: overflow\n");
- /* Next fragment of the frame */
- m = m->m_next;
- #else
- size_t fragment_length = (size_t) m->m_len;
- void *fragment_start = mtod(m, void *);
- uint32_t new_frame_length = frame_length + fragment_length;
+ /* Discard overflow data */
+ new_frame_length = LPC_ETH_CONFIG_TX_BUF_SIZE;
+ fragment_length = new_frame_length - frame_length;
- /* Check buffer size */
- if (new_frame_length > LPC_ETH_CONFIG_TX_BUF_SIZE) {
- LPC_ETH_PRINTF("tx: overflow\n");
+ /* Finalize frame */
+ ctrl |= LPC_ETH_LAST_FRAGMENT_FLAGS;
+ /* Update error counter */
+ ++e->transmit_overflow_errors;
- /* Discard overflow data */
- new_frame_length = LPC_ETH_CONFIG_TX_BUF_SIZE;
- fragment_length = new_frame_length - frame_length;
+ LPC_ETH_PRINTF(
+ "tx: copy: %" PRIu32 "%s%s\n",
+ fragment_length,
+ (m->m_flags & M_EXT) != 0 ? ", E" : "",
+ (m->m_flags & M_PKTHDR) != 0 ? ", H" : ""
- /* Finalize frame */
- ctrl |= LPC_ETH_LAST_FRAGMENT_FLAGS;
+ /* Copy fragment to buffer in Ethernet RAM */
+ memcpy(frame_buffer, fragment_start, fragment_length);
- /* Update error counter */
- ++e->transmit_overflow_errors;
+ /* Finalize descriptor */
+ desc [produce_index].control = (ctrl & ~ETH_TX_CTRL_SIZE_MASK)
+ | (new_frame_length - 1);
LPC_ETH_PRINTF(
- "tx: copy: %" PRIu32 "%s%s\n",
- fragment_length,
- (m->m_flags & M_EXT) != 0 ? ", E" : "",
- (m->m_flags & M_PKTHDR) != 0 ? ", H" : ""
+ "tx: %02" PRIu32 ": %" PRIu32 "\n",
+ produce_index,
+ new_frame_length
- /* Copy fragment to buffer in Ethernet RAM */
- memcpy(frame_buffer, fragment_start, fragment_length);
- /* Finalize descriptor */
- desc [produce_index].control = (ctrl & ~ETH_TX_CTRL_SIZE_MASK)
- | (new_frame_length - 1);
- LPC_ETH_PRINTF(
- "tx: %02" PRIu32 ": %" PRIu32 "\n",
- produce_index,
- new_frame_length
- /* Cache flush of data */
- (const void *) desc [produce_index].start,
- new_frame_length
- /* Cache flush of descriptor */
- sizeof(desc [0])
+ /* Cache flush of data */
+ (const void *) desc [produce_index].start,
+ new_frame_length
+ /* Cache flush of descriptor */
+ sizeof(desc [0])
- frame_length = 0;
- } else {
- /* New frame length */
- frame_length = new_frame_length;
- /* Update current frame buffer start */
- frame_buffer += fragment_length;
+ /* Fresh frame length and buffer start */
+ frame_length = 0;
+ frame_buffer = (char *) desc [produce_index].start;
- /* Free mbuf and get next */
- m = m_free(m);
- #endif
- } else {
- /* Nothing to transmit */
- break;
+ } else {
+ /* New frame length */
+ frame_length = new_frame_length;
- /* Save indices */
- e->tx_produce_index = produce_index;
- e->tx_consume_index = consume_index;
+ /* Update current frame buffer start */
+ frame_buffer += fragment_length;
- /* No more fragments? */
- if (m == NULL) {
- /* Interface is now inactive */
- ifp->if_drv_flags &= ~IFF_DRV_OACTIVE;
+ /* Free mbuf and get next */
+ m = m_free(m);
+ #endif
} else {
- LPC_ETH_PRINTF("tx: enable interrupts\n");
- /* Enable transmit interrupts */
- lpc_eth_enable_transmit_interrupts();
+ /* Nothing to transmit */
+ m_freem(m0);
+ return 0;
- LPE_UNLOCK(e);
@@ -1489,9 +1394,8 @@ static int lpc_eth_up_or_down(lpc_eth_driver_entry *e, bool up)
- /* Stop tasks */
+ /* Stop task */
lpc_eth_control_request(e, e->receive_task, LPC_ETH_EVENT_STOP);
- lpc_eth_control_request(e, e->transmit_task, LPC_ETH_EVENT_STOP);
lpc_eth_soft_reset();
lpc_eth_phy_down(e);
@@ -1607,17 +1511,38 @@ static int lpc_eth_interface_ioctl(
return eno;
-static void lpc_eth_interface_start(struct ifnet *ifp)
+static int lpc_eth_interface_transmit(struct ifnet *ifp, struct mbuf *m)
lpc_eth_driver_entry *e = (lpc_eth_driver_entry *) ifp->if_softc;
+ int eno;
- ifp->if_drv_flags |= IFF_DRV_OACTIVE;
+ LPE_LOCK(e);
if (e->state == LPC_ETH_STATE_UP) {
- sc = rtems_event_send(e->transmit_task, LPC_ETH_EVENT_TXSTART);
+ eno = lpc_eth_tx_enqueue(e, ifp, m);
+ lpc_eth_tx_reclaim(e, ifp);
+ if (__predict_false(eno != 0)) {
+ struct mbuf *n;
+ n = m_defrag(m, M_NOWAIT);
+ if (n != NULL) {
+ m = n;
+ } else {
+ eno = ENETDOWN;
+ if (eno != 0) {
+ m_freem(m);
+ if_inc_counter(ifp, IFCOUNTER_OQDROPS, 1);
+ LPE_UNLOCK(e);
+ return eno;
static void lpc_eth_interface_watchdog(void *arg)
@@ -1775,7 +1700,7 @@ static int lpc_eth_attach(device_t dev)
if_initname(ifp, device_get_name(dev), device_get_unit(dev));
ifp->if_init = lpc_eth_interface_init;
ifp->if_ioctl = lpc_eth_interface_ioctl;
- ifp->if_start = lpc_eth_interface_start;
+ ifp->if_transmit = lpc_eth_interface_transmit;
ifp->if_qflush = if_qflush;
ifp->if_flags = IFF_BROADCAST | IFF_MULTICAST | IFF_SIMPLEX;
IFQ_SET_MAXLEN(&ifp->if_snd, LPC_ETH_CONFIG_TX_UNIT_COUNT_MAX - 1);
@@ -1801,21 +1726,6 @@ static int lpc_eth_attach(device_t dev)
(rtems_task_argument)e
BSD_ASSERT(status == RTEMS_SUCCESSFUL);
- status = rtems_task_create(
- rtems_build_name('n', 't', 't', 'x'),
- rtems_bsd_get_task_priority(device_get_name(e->dev)),
- 4096,
- RTEMS_DEFAULT_MODES,
- RTEMS_DEFAULT_ATTRIBUTES,
- &e->transmit_task
- BSD_ASSERT(status == RTEMS_SUCCESSFUL);
- status = rtems_task_start(
- e->transmit_task,
- lpc_eth_transmit_task,
- (rtems_task_argument)e
if_link_state_change(e->ifp, LINK_STATE_UP);
2.35.3
