[libbsd 09/22] Remove FreeBSD file descriptors
Sebastian Huber
Fri Jun 24 06:33:37 UTC 2022
Remove FreeBSD file descriptors due to performance and code complexity reasons.
Update #4475.
freebsd/sys/kern/kern_descrip.c | 58 +--
freebsd/sys/kern/kern_event.c | 121 ++---
freebsd/sys/kern/sys_generic.c | 136 ++++--
freebsd/sys/kern/uipc_socket.c | 24 +
freebsd/sys/kern/uipc_syscalls.c | 16 +
freebsd/sys/kern/vfs_cache.c | 2 +
freebsd/sys/kern/vfs_lookup.c | 4 +
freebsd/sys/kern/vfs_mount.c | 2 +
freebsd/sys/kern/vfs_subr.c | 4 +
freebsd/sys/kern/vfs_syscalls.c | 18 +
freebsd/sys/opencrypto/cryptodev.c | 11 +-
freebsd/sys/sys/file.h | 98 +++-
freebsd/sys/sys/filedesc.h | 89 +++-
freebsd/sys/sys/namei.h | 2 +
freebsd/sys/sys/proc.h | 2 +-
freebsd/sys/sys/socketvar.h | 15 +-
freebsd/sys/sys/syscallsubr.h | 5 +
libbsd.py | 1 +
.../machine/rtems-bsd-kernel-namespace.h | 18 -
.../include/machine/rtems-bsd-kernel-space.h | 5 -
rtemsbsd/include/machine/rtems-bsd-libio.h | 196 +-------
rtemsbsd/rtems/rtems-bsd-libio.c | 61 ---
rtemsbsd/rtems/rtems-bsd-syscall-api.c | 462 ++++++++----------
rtemsbsd/rtems/rtems-kernel-fget.c | 79 +++
rtemsbsd/rtems/rtems-kernel-init.c | 7 +-
25 files changed, 713 insertions(+), 723 deletions(-)
create mode 100644 rtemsbsd/rtems/rtems-kernel-fget.c
diff --git a/freebsd/sys/kern/kern_descrip.c b/freebsd/sys/kern/kern_descrip.c
index ddc50633..e32201c9 100644
--- a/freebsd/sys/kern/kern_descrip.c
+++ b/freebsd/sys/kern/kern_descrip.c
@@ -76,7 +76,7 @@ __FBSDID("$FreeBSD$");
#include <sys/syscallsubr.h>
#include <sys/sysctl.h>
#include <sys/sysproto.h>
-#include <rtems/bsd/sys/unistd.h>
+#include <sys/unistd.h>
#include <sys/user.h>
#include <sys/vnode.h>
#ifdef KTRACE
@@ -92,6 +92,7 @@ __FBSDID("$FreeBSD$");
#include <ddb/ddb.h>
+#ifndef __rtems__
static MALLOC_DEFINE(M_FILEDESC, "filedesc", "Open file descriptor table");
static MALLOC_DEFINE(M_FILEDESC_TO_LEADER, "filedesc_to_leader",
"file desc to leader structures");
@@ -362,7 +363,6 @@ sys_getdtablesize(struct thread *td, struct getdtablesize_args *uap)
return (0);
-#ifndef __rtems__
* Duplicate a file descriptor to a particular value.
@@ -526,7 +526,6 @@ kern_fcntl(struct thread *td, int fd, int cmd, intptr_t arg)
tmp = arg;
error = kern_dup(td, FDDUP_FIXED, FDDUP_FLAG_CLOEXEC, fd, tmp);
break;
-#endif /* __rtems__ */
case F_GETFD:
error = EBADF;
@@ -551,6 +550,7 @@ kern_fcntl(struct thread *td, int fd, int cmd, intptr_t arg)
FILEDESC_XUNLOCK(fdp);
break;
+#endif /* __rtems__ */
case F_GETFL:
error = fget_fcntl(td, fd, &cap_fcntl_rights, F_GETFL, &fp);
@@ -813,6 +813,7 @@ kern_fcntl(struct thread *td, int fd, int cmd, intptr_t arg)
return (error);
+#ifndef __rtems__
static int
getmaxfd(struct thread *td)
@@ -820,7 +821,6 @@ getmaxfd(struct thread *td)
return (min((int)lim_cur(td, RLIMIT_NOFILE), maxfilesperproc));
-#ifndef __rtems__
* Common code for dup, dup2, fcntl(F_DUPFD) and fcntl(F_DUP2FD).
@@ -1182,7 +1182,6 @@ fgetown(struct sigio **sigiop)
SIGIO_UNLOCK();
return (pgid);
* Function drops the filedesc lock on return.
@@ -1273,7 +1272,6 @@ kern_close(struct thread *td, int fd)
return (closefp(fdp, fd, fp, td, 1));
-#ifndef __rtems__
* Close open file descriptors.
@@ -1309,7 +1307,6 @@ sys_closefrom(struct thread *td, struct closefrom_args *uap)
FILEDESC_SUNLOCK(fdp);
return (0);
#if defined(COMPAT_43)
@@ -1436,7 +1433,6 @@ freebsd11_nfstat(struct thread *td, struct freebsd11_nfstat_args *uap)
#endif /* COMPAT_FREEBSD11 */
-#ifndef __rtems__
* Return pathconf information about a file descriptor.
@@ -1493,7 +1489,6 @@ out:
fdrop(fp, td);
return (error);
* Initialize filecaps structure.
@@ -1628,7 +1623,6 @@ static void
filecaps_validate(const struct filecaps *fcaps, const char *func)
-#ifndef __rtems__
KASSERT(cap_rights_is_valid(&fcaps->fc_rights),
("%s: invalid rights", func));
KASSERT((fcaps->fc_fcntls & ~CAP_FCNTL_ALL) == 0,
@@ -1642,7 +1636,6 @@ filecaps_validate(const struct filecaps *fcaps, const char *func)
KASSERT(fcaps->fc_nioctls == 0 ||
cap_rights_is_set(&fcaps->fc_rights, CAP_IOCTL),
("%s: ioctls without CAP_IOCTL", func));
static void
@@ -1891,12 +1884,10 @@ falloc_noinstall(struct thread *td, struct file **resultfp)
priv_check(td, PRIV_MAXFILES) != 0) ||
openfiles_new >= maxfiles) {
atomic_subtract_int(&openfiles, 1);
-#ifndef __rtems__
if (ppsratecheck(&lastfail, &curfail, 1)) {
printf("kern.maxfiles limit exceeded by uid %i, (%s) "
"please see tuning(7).\n", td->td_ucred->cr_ruid, td->td_proc->p_comm);
return (ENFILE);
fp = uma_zalloc(file_zone, M_WAITOK);
@@ -2050,7 +2041,6 @@ fdshare(struct filedesc *fdp)
return (fdp);
-#ifndef __rtems__
* Unshare a filedesc structure, if necessary by making a copy
@@ -2404,7 +2394,6 @@ fdsetugidsafety(struct thread *td)
* If a specific file object occupies a specific file descriptor, close the
@@ -2427,7 +2416,6 @@ fdclose(struct thread *td, struct file *fp, int idx)
-#ifndef __rtems__
* Close any files on exec?
@@ -2453,7 +2441,6 @@ fdcloseexec(struct thread *td)
* It is unsafe for set[ug]id processes to be started with file
@@ -2522,7 +2509,6 @@ closef(struct file *fp, struct thread *td)
if (fp->f_type == DTYPE_VNODE && td != NULL) {
vp = fp->f_vnode;
-#ifndef __rtems__
if ((td->td_proc->p_leader->p_flag & P_ADVLOCK) != 0) {
lf.l_whence = SEEK_SET;
lf.l_start = 0;
@@ -2531,7 +2517,6 @@ closef(struct file *fp, struct thread *td)
(void) VOP_ADVLOCK(vp, (caddr_t)td->td_proc->p_leader,
F_UNLCK, &lf, F_POSIX);
fdtol = td->td_proc->p_fdtol;
if (fdtol != NULL) {
@@ -2543,10 +2528,8 @@ closef(struct file *fp, struct thread *td)
for (fdtol = fdtol->fdl_next;
fdtol != td->td_proc->p_fdtol;
fdtol = fdtol->fdl_next) {
-#ifndef __rtems__
if ((fdtol->fdl_leader->p_flag &
P_ADVLOCK) == 0)
continue;
fdtol->fdl_holdcount++;
@@ -2746,18 +2729,6 @@ fget_unlocked(struct filedesc *fdp, int fd, cap_rights_t *needrightsp,
*seqp = seq;
#endif
-#ifdef __rtems__
- if (fp->f_io != NULL) {
- rtems_libio_iop_hold(fp->f_io);
- if (RTEMS_BSD_DESCRIP_TRACE)
- printf("bsd: fb: fget_unlocked: iop=%p %d (%d) fp=%p (%d) by %p\n",
- fp->f_io, fp->f_io->data0, fp->f_io->flags >> 12,
- fp, fp->f_count, __builtin_return_address(0));
- } else if (RTEMS_BSD_DESCRIP_TRACE) {
- printf("bsd: fb: fget_unlocked: iop=NULL -1 (0) fp=%p (%d) by %p\n",
return (0);
@@ -2802,13 +2773,11 @@ _fget(struct thread *td, int fd, struct file **fpp, int flags,
if ((fp->f_flag & flags) == 0)
error = EBADF;
break;
-#ifndef __rtems__
case FEXEC:
if ((fp->f_flag & (FREAD | FEXEC)) == 0 ||
((fp->f_flag & FWRITE) != 0))
error = EBADF;
break;
case 0:
break;
default:
@@ -2831,7 +2800,6 @@ fget(struct thread *td, int fd, cap_rights_t *rightsp, struct file **fpp)
return (_fget(td, fd, fpp, 0, rightsp, NULL));
-#ifndef __rtems__
int
fget_mmap(struct thread *td, int fd, cap_rights_t *rightsp, u_char *maxprotp,
struct file **fpp)
@@ -2866,7 +2834,6 @@ fget_mmap(struct thread *td, int fd, cap_rights_t *rightsp, u_char *maxprotp,
#endif
return (error);
int
fget_read(struct thread *td, int fd, cap_rights_t *rightsp, struct file **fpp)
@@ -2986,14 +2953,12 @@ fgetvp_read(struct thread *td, int fd, cap_rights_t *rightsp, struct vnode **vpp
return (_fgetvp(td, fd, FREAD, rightsp, vpp));
-#ifndef __rtems__
int
fgetvp_exec(struct thread *td, int fd, cap_rights_t *rightsp, struct vnode **vpp)
return (_fgetvp(td, fd, FEXEC, rightsp, vpp));
#ifdef notyet
int
@@ -3021,15 +2986,12 @@ _fdrop(struct file *fp, struct thread *td)
error = fo_close(fp, td);
crfree(fp->f_cred);
-#ifndef __rtems__
free(fp->f_advice, M_FADVISE);
uma_zfree(file_zone, fp);
return (error);
-#ifndef __rtems__
* Apply an advisory lock on a file descriptor.
@@ -3248,7 +3210,6 @@ pwd_chroot(struct thread *td, struct vnode *vp)
vrele(oldvp);
return (0);
void
pwd_chdir(struct thread *td, struct vnode *vp)
@@ -3273,7 +3234,6 @@ pwd_chdir(struct thread *td, struct vnode *vp)
void
mountcheckdirs(struct vnode *olddp, struct vnode *newdp)
-#ifndef __rtems__
struct filedesc *fdp;
struct prison *pr;
struct proc *p;
@@ -3334,7 +3294,6 @@ mountcheckdirs(struct vnode *olddp, struct vnode *newdp)
sx_sunlock(&allprison_lock);
while (nrele--)
vrele(olddp);
struct filedesc_to_leader *
@@ -3362,7 +3321,6 @@ filedesc_to_leader_alloc(struct filedesc_to_leader *old, struct filedesc *fdp, s
return (fdtol);
-#ifndef __rtems__
static int
sysctl_kern_proc_nfds(SYSCTL_HANDLER_ARGS)
@@ -3861,7 +3819,6 @@ static SYSCTL_NODE(_kern_proc, KERN_PROC_OFILEDESC, ofiledesc,
CTLFLAG_RD|CTLFLAG_MPSAFE, sysctl_kern_proc_ofiledesc,
"Process ofiledesc entries");
#endif /* COMPAT_FREEBSD7 */
int
vntype_to_kinfo(int vtype)
@@ -3892,7 +3849,6 @@ vntype_to_kinfo(int vtype)
return (KF_VTYPE_UNKNOWN);
-#ifndef __rtems__
static SYSCTL_NODE(_kern_proc, KERN_PROC_FILEDESC, filedesc,
CTLFLAG_RD|CTLFLAG_MPSAFE, sysctl_kern_proc_filedesc,
"Process filedesc entries");
@@ -3964,7 +3920,6 @@ sysctl_kern_proc_cwd(SYSCTL_HANDLER_ARGS)
static SYSCTL_NODE(_kern_proc, KERN_PROC_CWD, cwd, CTLFLAG_RD|CTLFLAG_MPSAFE,
sysctl_kern_proc_cwd, "Process current working directory");
#ifdef DDB
@@ -4113,13 +4068,10 @@ filelistinit(void *dummy)
NULL, NULL, NULL, NULL, UMA_ALIGN_PTR, 0);
mtx_init(&sigio_lock, "sigio lock", NULL, MTX_DEF);
-#ifndef __rtems__
SYSINIT(select, SI_SUB_LOCK, SI_ORDER_FIRST, filelistinit, NULL);
-#else /* __rtems__ */
-SYSINIT(select_sub_lock, SI_SUB_LOCK, SI_ORDER_FIRST, filelistinit, NULL);
static int
badfo_readwrite(struct file *fp, struct uio *uio, struct ucred *active_cred,
diff --git a/freebsd/sys/kern/kern_event.c b/freebsd/sys/kern/kern_event.c
index 1c79ace8..f5682b03 100644
--- a/freebsd/sys/kern/kern_event.c
+++ b/freebsd/sys/kern/kern_event.c
@@ -396,12 +396,7 @@ filt_fileattach(struct knote *kn)
#ifndef __rtems__
return (fo_kqfilter(kn->kn_fp, kn));
- if ((kn->kn_status & KN_FP_IS_IOP) == 0) {
- return (fo_kqfilter(kn->kn_fp, kn));
- } else {
- rtems_libio_t* iop = (rtems_libio_t*) kn->kn_fp;
- return ((*iop->pathinfo.handlers->kqfilter_h)(iop, kn));
+ return ((*kn->kn_fp->pathinfo.handlers->kqfilter_h)(kn->kn_fp, kn));
@@ -412,7 +407,7 @@ kqueue_kqfilter(struct file *fp, struct knote *kn)
#ifndef __rtems__
struct kqueue *kq = kn->kn_fp->f_data;
- struct kqueue *kq = rtems_bsd_libio_knote_to_kq(kn);
+ struct kqueue *kq = rtems_bsd_knote_to_file(kn);
if (kn->kn_filter != EVFILT_READ)
@@ -431,7 +426,7 @@ filt_kqdetach(struct knote *kn)
#ifndef __rtems__
knlist_remove(&kq->kq_sel.si_note, kn, 0);
@@ -444,7 +439,7 @@ filt_kqueue(struct knote *kn, long hint)
#ifndef __rtems__
kn->kn_data = kq->kq_count;
@@ -1041,11 +1036,17 @@ kern_kqueue(struct thread *td, int flags, struct filecaps *fcaps)
kq->kq_cred = crhold(cred);
FILEDESC_XLOCK(fdp);
+#ifndef __rtems__
TAILQ_INSERT_HEAD(&fdp->fd_kqlist, kq, kq_list);
+#else /* __rtems__ */
+ TAILQ_INSERT_HEAD(&fd_kqlist, kq, kq_list);
finit(fp, FREAD | FWRITE, DTYPE_KQUEUE, kq, &kqueueops);
+#ifndef __rtems__
fdrop(fp, td);
td->td_retval[0] = fd;
return (0);
@@ -1425,9 +1426,11 @@ kqueue_register(struct kqueue *kq, struct kevent *kev, struct thread *td,
int mflag)
struct filterops *fops;
+#ifndef __rtems__
struct file *fp;
-#ifdef __rtems__
- rtems_libio_t* iop = NULL;
+ rtems_libio_t *fp;
+ struct file *bsd_fp;
struct knote *kn, *tkn;
struct knlist *knl;
@@ -1463,22 +1466,26 @@ kqueue_register(struct kqueue *kq, struct kevent *kev, struct thread *td,
findkn:
if (fops->f_isfd) {
KASSERT(td != NULL, ("td is NULL"));
+#ifndef __rtems__
if (kev->ident > INT_MAX)
error = EBADF;
else
-#ifndef __rtems__
error = fget(td, kev->ident, &cap_event_rights, &fp);
- int ffd = rtems_bsd_libio_iop_hold(kev->ident, &iop);
- if (ffd < 0)
+ if ((uint32_t)kev->ident < rtems_libio_number_iops) {
+ unsigned int flags;
+ fp = rtems_libio_iop((int)kev->ident);
+ flags = rtems_libio_iop_hold(fp);
+ if ((flags & LIBIO_FLAGS_OPEN) != 0) {
+ error = 0;
+ } else {
+ rtems_libio_iop_drop(fp);
error = EBADF;
- else {
- if (iop == NULL)
- error = fget(td, ffd, &cap_event_rights, &fp);
- else
- fp = NULL;
+ } else {
+ error = EBADF;
if (error)
@@ -1486,19 +1493,13 @@ findkn:
if ((kev->flags & EV_ADD) == EV_ADD && kqueue_expand(kq, fops,
kev->ident, M_NOWAIT) != 0) {
-#ifndef __rtems__
/* try again */
+#ifndef __rtems__
fdrop(fp, td);
- fp = NULL;
- if (fp != NULL) {
- fdrop(fp, td);
- fp = NULL;
- } else if (iop != NULL) {
- rtems_libio_iop_drop(iop);
- iop = NULL;
+ fp = NULL;
error = kqueue_expand(kq, fops, kev->ident, mflag);
if (error)
goto done;
@@ -1508,7 +1509,8 @@ findkn:
#ifndef __rtems__
if (fp->f_type == DTYPE_KQUEUE) {
- if (fp != NULL && fp->f_type == DTYPE_KQUEUE) {
+ bsd_fp = rtems_bsd_iop_to_file(fp);
+ if (bsd_fp != NULL && bsd_fp->f_type == DTYPE_KQUEUE) {
* If we add some intelligence about what we are doing,
@@ -1517,7 +1519,11 @@ findkn:
* getting both the knlist lock and the kq lock since
* they are the same thing.
+#ifndef __rtems__
if (fp->f_data == kq) {
+ if (bsd_fp->f_data == kq) {
error = EINVAL;
goto done;
@@ -1579,15 +1585,13 @@ findkn:
kq->kq_state |= KQ_FLUXWAIT;
msleep(kq, &kq->kq_lock, PSOCK | PDROP, "kqflxwt", 0);
if (fp != NULL) {
+#ifndef __rtems__
fdrop(fp, td);
fp = NULL;
-#ifdef __rtems__
- if (iop != NULL) {
- iop = NULL;
goto findkn;
@@ -1603,17 +1607,7 @@ findkn:
error = ENOMEM;
goto done;
-#ifndef __rtems__
kn->kn_fp = fp;
- if (fp != NULL) {
- kn->kn_fp = fp;
- kn->kn_status = 0;
- rtems_bsd_libio_iop_to_knote(kn, iop);
- kn->kn_status = KN_FP_IS_IOP;
kn->kn_kq = kq;
kn->kn_fop = fops;
@@ -1622,9 +1616,6 @@ findkn:
fops = NULL;
fp = NULL;
-#ifdef __rtems__
- iop = NULL;
kn->kn_sfflags = kev->fflags;
kn->kn_sdata = kev->data;
@@ -1633,11 +1624,7 @@ findkn:
kn->kn_kevent = *kev;
kn->kn_kevent.flags &= ~(EV_ADD | EV_DELETE |
EV_ENABLE | EV_DISABLE | EV_FORCEONESHOT);
-#ifndef __rtems__
kn->kn_status = KN_DETACHED;
- kn->kn_status |= KN_DETACHED;
if ((kev->flags & EV_DISABLE) != 0)
kn->kn_status |= KN_DISABLED;
kn_enter_flux(kn);
@@ -1729,10 +1716,10 @@ done:
if (filedesc_unlock)
FILEDESC_XUNLOCK(td->td_proc->p_fd);
if (fp != NULL)
+#ifndef __rtems__
fdrop(fp, td);
-#ifdef __rtems__
- if (iop != NULL)
knote_free(tkn);
if (fops != NULL)
@@ -2269,7 +2256,9 @@ static int
kqueue_close(struct file *fp, struct thread *td)
struct kqueue *kq = fp->f_data;
+#ifndef __rtems__
int error;
int filedesc_unlock;
@@ -2277,6 +2266,7 @@ kqueue_close(struct file *fp, struct thread *td)
return error;
kqueue_drain(kq, td);
+#ifndef __rtems__
* We could be called due to the knote_drop() doing fdrop(),
* called from kqueue_register(). In this case the global
@@ -2293,6 +2283,12 @@ kqueue_close(struct file *fp, struct thread *td)
TAILQ_REMOVE(&fdp->fd_kqlist, kq, kq_list);
+ (void)filedesc_unlock;
+ rtems_libio_lock();
+ TAILQ_REMOVE(&fd_kqlist, kq, kq_list);
+ rtems_libio_unlock();
kqueue_destroy(kq);
chgkqcnt(kq->kq_cred->cr_ruidinfo, -1, 0);
@@ -2674,18 +2670,26 @@ again: /* need to reacquire lock since we have dropped it */
void
knote_fdclose(struct thread *td, int fd)
+#ifndef __rtems__
struct filedesc *fdp = td->td_proc->p_fd;
struct kqueue *kq;
struct knote *kn;
int influx;
+#ifndef __rtems__
FILEDESC_XLOCK_ASSERT(fdp);
* We shouldn't have to worry about new kevents appearing on fd
* since filedesc is locked.
+#ifndef __rtems__
TAILQ_FOREACH(kq, &fdp->fd_kqlist, kq_list) {
+ TAILQ_FOREACH(kq, &fd_kqlist, kq_list) {
KQ_LOCK(kq);
again:
@@ -2773,10 +2777,7 @@ knote_drop_detached(struct knote *kn, struct thread *td)
#ifndef __rtems__
fdrop(kn->kn_fp, td);
- fdrop(kn->kn_fp, td);
- else
- rtems_libio_iop_drop((rtems_libio_t*) kn->kn_fp);
+ rtems_libio_iop_drop(kn->kn_fp);
kn->kn_fp = NULL;
diff --git a/freebsd/sys/kern/sys_generic.c b/freebsd/sys/kern/sys_generic.c
index 827380ce..1e5351a7 100644
--- a/freebsd/sys/kern/sys_generic.c
+++ b/freebsd/sys/kern/sys_generic.c
@@ -805,12 +805,14 @@ kern_ioctl(struct thread *td, int fd, u_long com, caddr_t data)
switch (com) {
+#ifndef __rtems__
case FIONCLEX:
fdp->fd_ofiles[fd].fde_flags &= ~UF_EXCLOSE;
goto out;
case FIOCLEX:
fdp->fd_ofiles[fd].fde_flags |= UF_EXCLOSE;
goto out;
case FIONBIO:
if ((tmp = *(int *)data))
atomic_set_int(&fp->f_flag, FNONBLOCK);
@@ -1236,23 +1238,73 @@ selsetbits(fd_mask **ibits, fd_mask **obits, int idx, fd_mask bit, int events)
return (n);
+#ifndef __rtems__
static __inline int
getselfd_cap(struct filedesc *fdp, int fd, struct file **fpp)
-#ifdef __rtems__
+ return (fget_unlocked(fdp, fd, &cap_event_rights, fpp, NULL));
+static int
+getselfd_cap(struct filedesc *fdp, int fd, rtems_libio_t **fpp)
rtems_libio_t *iop;
- int ffd = rtems_bsd_libio_iop_hold(fd, &iop);
- if (ffd < 0)
- return EBADF;
- *fpp = NULL;
- return 0;
+ unsigned int actual_flags;
+ (void)fdp;
+ if ((uint32_t)fd >= rtems_libio_number_iops) {
+ return (EBADF);
- fd = ffd;
- return (fget_unlocked(fdp, fd, &cap_event_rights, fpp, NULL));
+ iop = rtems_libio_iop(fd);
+ actual_flags = rtems_libio_iop_hold(iop);
+ if ((actual_flags & LIBIO_FLAGS_OPEN) != LIBIO_FLAGS_OPEN) {
+ rtems_libio_iop_drop(iop);
+ return (EBADF);
+ *fpp = iop;
+ return (0);
+static inline rtems_libio_t *
+rtems_bsd_get_file_for_poll(int fd)
+ rtems_libio_t *iop;
+ return (NULL);
+ return (NULL);
+ return (iop);
+static inline int
+rtems_bsd_fo_poll(rtems_libio_t *iop, int events, struct ucred *active_cred,
+ struct thread *td)
+ int error;
+ (void)active_cred;
+ (void)td;
+ error = ((*iop->pathinfo.handlers->poll_h)(iop, events));
+ return (error);
* Traverse the list of fds attached to this thread's seltd and check for
@@ -1266,7 +1318,11 @@ selrescan(struct thread *td, fd_mask **ibits, fd_mask **obits)
struct seltd *stp;
struct selfd *sfp;
struct selfd *sfn;
+#ifndef __rtems__
struct file *fp;
fd_mask bit;
int fd, ev, n, idx;
int error;
@@ -1290,10 +1346,8 @@ selrescan(struct thread *td, fd_mask **ibits, fd_mask **obits)
ev = fo_poll(fp, selflags(ibits, idx, bit), td->td_ucred, td);
fdrop(fp, td);
- ev = rtems_bsd_libio_fo_poll(fd, fp, selflags(ibits, idx, bit),
- td->td_ucred, td);
- if (fp != NULL)
- fdrop(fp, td);
+ ev = rtems_bsd_fo_poll(fp, selflags(ibits, idx, bit),
+ td->td_ucred, td);
if (ev != 0)
n += selsetbits(ibits, obits, idx, bit, ev);
@@ -1311,7 +1365,11 @@ static int
selscan(struct thread *td, fd_mask **ibits, fd_mask **obits, int nfd)
+#ifndef __rtems__
struct file *fp;
fd_mask bit;
int ev, flags, end, fd;
int n, idx;
@@ -1334,11 +1392,8 @@ selscan(struct thread *td, fd_mask **ibits, fd_mask **obits, int nfd)
ev = fo_poll(fp, flags, td->td_ucred, td);
fdrop(fp, td);
- selflags(ibits, idx, bit),
- if (fp != NULL)
- fdrop(fp, td);
+ ev = rtems_bsd_fo_poll(fp, flags, td->td_ucred,
+ td);
if (ev != 0)
@@ -1507,7 +1562,11 @@ pollrescan(struct thread *td)
struct selfd *sfn;
struct selinfo *si;
+#ifndef __rtems__
struct file *fp;
struct pollfd *fd;
int n;
@@ -1524,24 +1583,15 @@ pollrescan(struct thread *td)
continue;
#ifndef __rtems__
fp = fdp->fd_ofiles[fd->fd].fde_file;
+ fp = rtems_bsd_get_file_for_poll(fd->fd);
#ifdef CAPABILITIES
if (fp == NULL ||
cap_check(cap_rights(fdp, fd->fd), &cap_event_rights) != 0)
#else
if (fp == NULL)
#endif
- rtems_libio_t* iop;
- int ffd = rtems_bsd_libio_iop_hold(fd->fd, &iop);
- if (ffd >= 0) {
- if (iop == NULL) {
- fp = fdp->fd_ofiles[ffd].fde_file;
- } else {
- fp = NULL;
- else
fd->revents = POLLNVAL;
n++;
@@ -1555,7 +1605,8 @@ pollrescan(struct thread *td)
#ifndef __rtems__
fd->revents = fo_poll(fp, fd->events, td->td_ucred, td);
- fd->revents = rtems_bsd_libio_fo_poll(ffd, fp, fd->events, td->td_ucred, td);
+ fd->revents = rtems_bsd_fo_poll(fp, fd->events, td->td_ucred,
+ td);
if (fd->revents != 0)
n++;
@@ -1592,7 +1643,11 @@ static int
pollscan(struct thread *td, struct pollfd *fds, u_int nfd)
+#ifndef __rtems__
struct file *fp;
int i, n = 0;
FILEDESC_SLOCK(fdp);
@@ -1609,24 +1664,15 @@ pollscan(struct thread *td, struct pollfd *fds, u_int nfd)
} else {
#ifndef __rtems__
fp = fdp->fd_ofiles[fds->fd].fde_file;
+ fp = rtems_bsd_get_file_for_poll(fds->fd);
#ifdef CAPABILITIES
if (fp == NULL ||
cap_check(cap_rights(fdp, fds->fd), &cap_event_rights) != 0)
#else
if (fp == NULL)
#endif
- int ffd = rtems_bsd_libio_iop_hold(fds->fd, &iop);
- if (ffd >= 0) {
- } else {
- fp = NULL;
- if (ffd < 0)
fds->revents = POLLNVAL;
n++;
@@ -1640,7 +1686,7 @@ pollscan(struct thread *td, struct pollfd *fds, u_int nfd)
fds->revents = fo_poll(fp, fds->events,
td->td_ucred, td);
- fds->revents = rtems_bsd_libio_fo_poll(ffd, fp, fds->events,
+ fds->revents = rtems_bsd_fo_poll(fp, fds->events,
td->td_ucred, td);
diff --git a/freebsd/sys/kern/uipc_socket.c b/freebsd/sys/kern/uipc_socket.c
index 60f9a69d..9c05a228 100644
--- a/freebsd/sys/kern/uipc_socket.c
+++ b/freebsd/sys/kern/uipc_socket.c
@@ -3384,7 +3384,11 @@ sopoll_generic(struct socket *so, int events, struct ucred *active_cred,
int
soo_kqfilter(struct file *fp, struct knote *kn)
+#ifndef __rtems__
struct socket *so = kn->kn_fp->f_data;
+ struct socket *so = rtems_bsd_knote_to_file(kn)->f_data;
struct sockbuf *sb;
struct knlist *knl;
@@ -3594,7 +3598,11 @@ pru_sopoll_notsupp(struct socket *so, int events, struct ucred *cred,
static void
filt_sordetach(struct knote *kn)
+#ifndef __rtems__
so_rdknl_lock(so);
knlist_remove(&so->so_rdsel.si_note, kn, 1);
@@ -3609,7 +3617,11 @@ filt_soread(struct knote *kn, long hint)
struct socket *so;
+#ifndef __rtems__
+ so = rtems_bsd_knote_to_file(kn)->f_data;
if (SOLISTENING(so)) {
SOCK_LOCK_ASSERT(so);
@@ -3645,7 +3657,11 @@ filt_soread(struct knote *kn, long hint)
static void
filt_sowdetach(struct knote *kn)
+#ifndef __rtems__
so_wrknl_lock(so);
knlist_remove(&so->so_wrsel.si_note, kn, 1);
@@ -3660,7 +3676,11 @@ filt_sowrite(struct knote *kn, long hint)
struct socket *so;
+#ifndef __rtems__
return (0);
@@ -3690,7 +3710,11 @@ filt_soempty(struct knote *kn, long hint)
struct socket *so;
+#ifndef __rtems__
return (1);
diff --git a/freebsd/sys/kern/uipc_syscalls.c b/freebsd/sys/kern/uipc_syscalls.c
index a2f7d6f8..50413091 100644
--- a/freebsd/sys/kern/uipc_syscalls.c
+++ b/freebsd/sys/kern/uipc_syscalls.c
@@ -113,6 +113,7 @@ getsockaddr_noalloc(struct sockaddr **namp, const struct sockaddr *uaddr, size_t
static int sockargs(struct mbuf **, char *, socklen_t, int);
+#ifndef __rtems__
* Convert a user file descriptor to a kernel file entry and check if required
* capability rights are present.
@@ -140,6 +141,7 @@ getsock_cap(struct thread *td, int fd, cap_rights_t *rightsp,
*fpp = fp;
return (0);
* System call interface to the socket abstraction.
@@ -193,7 +195,9 @@ kern_socket(struct thread *td, int domain, int type, int protocol)
(void) fo_ioctl(fp, FIONBIO, &fflag, td->td_ucred, td);
+#ifndef __rtems__
fdrop(fp, td);
return (error);
@@ -349,7 +353,9 @@ accept1(td, s, uname, anamelen, flags)
sizeof(namelen));
if (error != 0)
fdclose(td, fp, td->td_retval[0]);
+#ifndef __rtems__
fdrop(fp, td);
free(name, M_SONAME);
return (error);
@@ -472,8 +478,10 @@ done:
} else
*fp = NULL;
+#ifndef __rtems__
if (nfp != NULL)
fdrop(nfp, td);
fdrop(headfp, td);
return (error);
@@ -692,15 +700,21 @@ kern_socketpair(struct thread *td, int domain, int type, int protocol,
(void) fo_ioctl(fp1, FIONBIO, &fflag, td->td_ucred, td);
(void) fo_ioctl(fp2, FIONBIO, &fflag, td->td_ucred, td);
+#ifndef __rtems__
fdrop(fp1, td);
fdrop(fp2, td);
return (0);
free4:
fdclose(td, fp2, rsv[1]);
+#ifndef __rtems__
fdrop(fp2, td);
free3:
fdclose(td, fp1, rsv[0]);
+#ifndef __rtems__
fdrop(fp1, td);
free2:
if (so2 != NULL)
(void)soclose(so2);
@@ -1712,6 +1726,7 @@ getsockaddr(struct sockaddr **namp, caddr_t uaddr, size_t len)
void
m_dispose_extcontrolm(struct mbuf *m)
+#ifndef __rtems__
struct cmsghdr *cm;
struct file *fp;
struct thread *td;
@@ -1752,4 +1767,5 @@ m_dispose_extcontrolm(struct mbuf *m)
m_chtype(m, MT_CONTROL);
diff --git a/freebsd/sys/kern/vfs_cache.c b/freebsd/sys/kern/vfs_cache.c
index 7ae1de1d..3faf6188 100644
--- a/freebsd/sys/kern/vfs_cache.c
+++ b/freebsd/sys/kern/vfs_cache.c
@@ -2146,6 +2146,7 @@ static int __read_mostly disablecwd;
SYSCTL_INT(_debug, OID_AUTO, disablecwd, CTLFLAG_RW, &disablecwd, 0,
"Disable the getcwd syscall");
+#ifndef __rtems__
/* Implementation of the getcwd syscall. */
int
sys___getcwd(struct thread *td, struct __getcwd_args *uap)
@@ -2196,6 +2197,7 @@ kern___getcwd(struct thread *td, char *buf, enum uio_seg bufseg, size_t buflen,
free(tmpbuf, M_TEMP);
return (error);
* Thus begins the fullpath magic.
diff --git a/freebsd/sys/kern/vfs_lookup.c b/freebsd/sys/kern/vfs_lookup.c
index 656ec51d..83b9f713 100644
--- a/freebsd/sys/kern/vfs_lookup.c
+++ b/freebsd/sys/kern/vfs_lookup.c
@@ -381,7 +381,9 @@ namei(struct nameidata *ndp)
ndp->ni_rootdir = fdp->fd_rdir;
vrefact(ndp->ni_rootdir);
+#ifndef __rtems__
ndp->ni_topdir = fdp->fd_jdir;
* If we are auditing the kernel pathname, save the user pathname.
@@ -837,7 +839,9 @@ dirloop:
pr = NULL;
if (dp == ndp->ni_rootdir ||
+#ifndef __rtems__
dp == ndp->ni_topdir ||
dp == rootvnode ||
pr != NULL ||
((dp->v_vflag & VV_ROOT) != 0 &&
diff --git a/freebsd/sys/kern/vfs_mount.c b/freebsd/sys/kern/vfs_mount.c
index 4635857e..2e122a98 100644
--- a/freebsd/sys/kern/vfs_mount.c
+++ b/freebsd/sys/kern/vfs_mount.c
@@ -950,7 +950,9 @@ vfs_domount_first(
VOP_UNLOCK(vp, 0);
EVENTHANDLER_DIRECT_INVOKE(vfs_mounted, mp, newdp, td);
VOP_UNLOCK(newdp, 0);
+#ifndef __rtems__
mountcheckdirs(vp, newdp);
vrele(newdp);
if ((mp->mnt_flag & MNT_RDONLY) == 0)
vfs_allocate_syncvnode(mp);
diff --git a/freebsd/sys/kern/vfs_subr.c b/freebsd/sys/kern/vfs_subr.c
index bc38e770..5f4d09da 100644
--- a/freebsd/sys/kern/vfs_subr.c
+++ b/freebsd/sys/kern/vfs_subr.c
@@ -5365,7 +5365,11 @@ filt_vfsread(struct knote *kn, long hint)
return (0);
VI_LOCK(vp);
+#ifndef __rtems__
kn->kn_data = va.va_size - kn->kn_fp->f_offset;
+ kn->kn_data = va.va_size - rtems_bsd_knote_to_file(kn)->f_offset;
res = (kn->kn_sfflags & NOTE_FILE_POLL) != 0 || kn->kn_data != 0;
VI_UNLOCK(vp);
return (res);
diff --git a/freebsd/sys/kern/vfs_syscalls.c b/freebsd/sys/kern/vfs_syscalls.c
index 0b7e054a..7e8e29e4 100644
--- a/freebsd/sys/kern/vfs_syscalls.c
+++ b/freebsd/sys/kern/vfs_syscalls.c
@@ -1050,12 +1050,19 @@ sys_openat(struct thread *td, struct openat_args *uap)
int
+#ifndef __rtems__
kern_openat(struct thread *td, int fd, char *path, enum uio_seg pathseg,
int flags, int mode)
+kern_openat(struct thread *td, int fd, char *path, enum uio_seg pathseg,
+ int flags, int mode, struct file *fp)
struct proc *p = td->td_proc;
struct filedesc *fdp = p->p_fd;
+#ifndef __rtems__
struct file *fp;
struct vnode *vp;
struct nameidata nd;
cap_rights_t rights;
@@ -1088,9 +1095,14 @@ kern_openat(struct thread *td, int fd, char *path, enum uio_seg pathseg,
* Allocate a file structure. The descriptor to reference it
* is allocated and set by finstall() below.
+#ifndef __rtems__
error = falloc_noinstall(td, &fp);
if (error != 0)
return (error);
+ rtems_libio_iop_hold(fp->f_io);
+ error = 0;
* An extra reference on `fp' has been held for us by
* falloc_noinstall().
@@ -1164,12 +1176,15 @@ kern_openat(struct thread *td, int fd, char *path, enum uio_seg pathseg,
VOP_UNLOCK(vp, 0);
+#ifndef __rtems__
if (flags & O_TRUNC) {
error = fo_truncate(fp, 0, td->td_ucred, td);
if (error != 0)
goto bad;
success:
+#ifndef __rtems__
* If we haven't already installed the FD (for dupfdopen), do so now.
@@ -1191,6 +1206,7 @@ success:
} else {
filecaps_free(&nd.ni_filecaps);
* Release our private reference, leaving the one associated with
@@ -4372,6 +4388,7 @@ sys_fhreadlink(struct thread *td, struct fhreadlink_args *uap)
return (error);
+#ifndef __rtems__
* syscall for the rpc.lockd to use to translate a NFS file handle into an
* open descriptor.
@@ -4459,6 +4476,7 @@ bad:
td->td_retval[0] = indx;
return (error);
* Stat an (NFS) file handle.
diff --git a/freebsd/sys/opencrypto/cryptodev.c b/freebsd/sys/opencrypto/cryptodev.c
index 71872532..97459559 100644
--- a/freebsd/sys/opencrypto/cryptodev.c
+++ b/freebsd/sys/opencrypto/cryptodev.c
@@ -1513,17 +1513,10 @@ cryptoioctl(struct cdev *dev, u_long cmd, caddr_t data, int flag, struct thread
/* falloc automatically provides an extra reference to 'f'. */
finit(f, FREAD | FWRITE, DTYPE_CRYPTO, fcr, &cryptofops);
-#ifdef __rtems__
- fd = rtems_bsd_libio_iop_allocate_with_file(td, fd, &rtems_bsd_sysgen_nodeops);
- if (fd < 0) {
- fdclose(td, f, fd);
- mtx_destroy(&fcr->lock);
- free(fcr, M_XDATA);
- return (error);
*(u_int32_t *)data = fd;
+#ifndef __rtems__
fdrop(f, td);
break;
case CRIOFINDDEV:
error = cryptodev_find((struct crypt_find_op *)data);
diff --git a/freebsd/sys/sys/file.h b/freebsd/sys/sys/file.h
index d48ca0e9..68c33299 100644
--- a/freebsd/sys/sys/file.h
+++ b/freebsd/sys/sys/file.h
@@ -247,6 +247,7 @@ extern int maxfiles; /* kernel limit on number of open files */
extern int maxfilesperproc; /* per process limit on number of open files */
extern volatile int openfiles; /* actual number of open files */
+#ifndef __rtems__
int fget(struct thread *td, int fd, cap_rights_t *rightsp, struct file **fpp);
int fget_mmap(struct thread *td, int fd, cap_rights_t *rightsp,
u_char *maxprotp, struct file **fpp);
@@ -257,6 +258,51 @@ int fget_write(struct thread *td, int fd, cap_rights_t *rightsp,
int fget_fcntl(struct thread *td, int fd, cap_rights_t *rightsp,
int needfcntl, struct file **fpp);
int _fdrop(struct file *fp, struct thread *td);
+int rtems_bsd_fget(int fd, struct file **fpp, int flags);
+static inline int
+fget(struct thread *td, int fd, cap_rights_t *rightsp, struct file **fpp)
+ struct file *fp;
+ (void)td;
+ (void)rightsp;
+ return (rtems_bsd_fget(fd, fpp, LIBIO_FLAGS_OPEN));
+static inline int
+fget_read(struct thread *td, int fd, cap_rights_t *rightsp, struct file **fpp)
+ struct file *fp;
+ (void)td;
+ (void)rightsp;
+ return (rtems_bsd_fget(fd, fpp, LIBIO_FLAGS_OPEN | LIBIO_FLAGS_READ));
+static inline int
+fget_write(struct thread *td, int fd, cap_rights_t *rightsp, struct file **fpp)
+ struct file *fp;
+ (void)td;
+ (void)rightsp;
+ return (rtems_bsd_fget(fd, fpp, LIBIO_FLAGS_OPEN | LIBIO_FLAGS_WRITE));
+static inline int
+fget_fcntl(struct thread *td, int fd, cap_rights_t *rightsp, int needfcntl,
+ struct file **fpp)
+ struct file *fp;
+ (void)td;
+ (void)needfcntl;
+ (void)rightsp;
fo_rdwr_t invfo_rdwr;
fo_truncate_t invfo_truncate;
@@ -274,7 +320,36 @@ fo_fill_kinfo_t vn_fill_kinfo;
int vn_fill_kinfo_vnode(struct vnode *vp, struct kinfo_file *kif);
+#ifndef __rtems__
void finit(struct file *, u_int, short, void *, struct fileops *);
+static inline void
+finit(struct file *fp, u_int flag, short type, void *data, struct fileops *ops)
+ uint32_t libio_flags;
+ fp->f_data = data;
+ fp->f_flag = flag;
+ fp->f_type = type;
+ fp->f_ops = ops;
+ libio_flags = LIBIO_FLAGS_OPEN;
+ if ((flag & FREAD) == FREAD) {
+ libio_flags |= LIBIO_FLAGS_READ;
+ if ((flag & FWRITE) == FWRITE) {
+ libio_flags |= LIBIO_FLAGS_WRITE;
+ if ((flag & FNONBLOCK) == FNONBLOCK) {
+ libio_flags |= LIBIO_FLAGS_NO_DELAY;
+ rtems_libio_iop_flags_set(fp->f_io, libio_flags);
int fgetvp(struct thread *td, int fd, cap_rights_t *rightsp,
struct vnode **vpp);
int fgetvp_exec(struct thread *td, int fd, cap_rights_t *rightsp,
@@ -286,6 +361,7 @@ int fgetvp_read(struct thread *td, int fd, cap_rights_t *rightsp,
int fgetvp_write(struct thread *td, int fd, cap_rights_t *rightsp,
+#ifndef __rtems__
static __inline int
_fnoop(void)
@@ -299,23 +375,19 @@ fhold(struct file *fp)
return (refcount_acquire_checked(&fp->f_count));
-#ifndef __rtems__
#define fdrop(fp, td) \
(refcount_release(&(fp)->f_count) ? _fdrop((fp), (td)) : _fnoop())
-static inline int fdrop(struct file *fp, struct thread *td)
+ * Must not be called after falloc_caps(). The file reference counting in
+ * RTEMS and FreeBSD work slightly different.
+static inline void
+fdrop(struct file *fp, struct thread *td)
- printf("bsd: fb: fdrop: iop=%p %d (%d) fp=%p (%d) by %p\n",
- rtems_libio_iop_drop(fp->f_io);
- printf("bsd: fb: fdrop: %d %p %d by %p\n",
- -1, fp, fp->f_count, __builtin_return_address(0));
- return (refcount_release(&(fp)->f_count) ? _fdrop((fp), (td)) : _fnoop());
+ (void)td;
+ rtems_libio_iop_drop(fp->f_io);
diff --git a/freebsd/sys/sys/filedesc.h b/freebsd/sys/sys/filedesc.h
index dc132677..634470fb 100644
--- a/freebsd/sys/sys/filedesc.h
+++ b/freebsd/sys/sys/filedesc.h
@@ -77,20 +77,26 @@ struct fdescenttbl {
#define NDSLOTTYPE u_long
struct filedesc {
+#ifndef __rtems__
struct fdescenttbl *fd_files; /* open files table */
struct vnode *fd_cdir; /* current directory */
struct vnode *fd_rdir; /* root directory */
+#ifndef __rtems__
struct vnode *fd_jdir; /* jail root directory */
NDSLOTTYPE *fd_map; /* bitmap of free fds */
int fd_lastfile; /* high-water mark of fd_ofiles */
int fd_freefile; /* approx. next free file */
u_short fd_cmask; /* mask for file creation */
+#ifndef __rtems__
int fd_refcnt; /* thread reference count */
int fd_holdcnt; /* hold count on structure + mutex */
struct sx fd_sx; /* protects members of this struct */
struct kqlist fd_kqlist; /* list of kqueues on this filedesc */
int fd_holdleaderscount; /* block fdfree() for shared close() */
int fd_holdleaderswakeup; /* fdfree() needs wakeup */
@@ -102,6 +108,7 @@ struct filedesc {
* fdl_refcount and fdl_holdcount are protected by struct filedesc mtx.
+#ifndef __rtems__
struct filedesc_to_leader {
int fdl_refcount; /* references from struct proc */
int fdl_holdcount; /* temporary hold during closef */
@@ -113,6 +120,9 @@ struct filedesc_to_leader {
#define fd_nfiles fd_files->fdt_nfiles
#define fd_ofiles fd_files->fdt_ofiles
+struct filedesc_to_leader;
* Per-process open flags.
@@ -120,15 +130,26 @@ struct filedesc_to_leader {
#define UF_EXCLOSE 0x01 /* auto-close on exec */
#ifdef _KERNEL
+#ifdef __rtems__
+#include <sys/file.h>
+#include <rtems/libio_.h>
/* Lock a file descriptor table. */
#define FILEDESC_LOCK_INIT(fdp) sx_init(&(fdp)->fd_sx, "filedesc structure")
#define FILEDESC_LOCK_DESTROY(fdp) sx_destroy(&(fdp)->fd_sx)
#define FILEDESC_LOCK(fdp) (&(fdp)->fd_sx)
+#ifndef __rtems__
#define FILEDESC_XLOCK(fdp) sx_xlock(&(fdp)->fd_sx)
#define FILEDESC_XUNLOCK(fdp) sx_xunlock(&(fdp)->fd_sx)
#define FILEDESC_SLOCK(fdp) sx_slock(&(fdp)->fd_sx)
#define FILEDESC_SUNLOCK(fdp) sx_sunlock(&(fdp)->fd_sx)
+#define FILEDESC_XLOCK(fdp) rtems_libio_lock()
+#define FILEDESC_XUNLOCK(fdp) rtems_libio_unlock()
+#define FILEDESC_SLOCK(fdp) rtems_libio_lock()
+#define FILEDESC_SUNLOCK(fdp) rtems_libio_unlock()
#define FILEDESC_LOCK_ASSERT(fdp) sx_assert(&(fdp)->fd_sx, SX_LOCKED | \
SX_NOTRECURSED)
@@ -154,17 +175,42 @@ enum {
struct thread;
-void filecaps_init(struct filecaps *fcaps);
+static __inline void
+filecaps_init(struct filecaps *fcaps)
+ bzero(fcaps, sizeof(*fcaps));
+ fcaps->fc_nioctls = -1;
bool filecaps_copy(const struct filecaps *src, struct filecaps *dst,
bool locked);
void filecaps_move(struct filecaps *src, struct filecaps *dst);
+#ifndef __rtems__
void filecaps_free(struct filecaps *fcaps);
+#define filecaps_free(fcaps) do { } while (0)
int closef(struct file *fp, struct thread *td);
int dupfdopen(struct thread *td, struct filedesc *fdp, int dfd, int mode,
int openerror, int *indxp);
+#ifndef __rtems__
int falloc_caps(struct thread *td, struct file **resultfp, int *resultfd,
int flags, struct filecaps *fcaps);
+int rtems_bsd_falloc(struct file **resultfp, int *resultfd);
+static inline int
+falloc_caps(struct thread *td, struct file **resultfp, int *resultfd,
+ int flags, struct filecaps *fcaps)
+ (void)td;
+ (void)flags;
+ (void)fcaps;
+ return (rtems_bsd_falloc(resultfp, resultfd));
int falloc_noinstall(struct thread *td, struct file **resultfp);
void _finstall(struct filedesc *fdp, struct file *fp, int fd, int flags,
@@ -173,7 +219,20 @@ int finstall(struct thread *td, struct file *fp, int *resultfd, int flags,
int fdalloc(struct thread *td, int minfd, int *result);
int fdallocn(struct thread *td, int minfd, int *fds, int n);
int fdcheckstd(struct thread *td);
+#ifndef __rtems__
void fdclose(struct thread *td, struct file *fp, int idx);
+void rtems_bsd_fdclose(struct file *fp);
+static inline void
+fdclose(struct thread *td, struct file *fp, int idx)
+ (void)td;
+ (void)idx;
+ rtems_bsd_fdclose(fp);
void fdcloseexec(struct thread *td);
void fdsetugidsafety(struct thread *td);
struct filedesc *fdcopy(struct filedesc *fdp);
@@ -192,6 +251,7 @@ int getvnode(struct thread *td, int fd, cap_rights_t *rightsp,
struct file **fpp);
void mountcheckdirs(struct vnode *olddp, struct vnode *newdp);
+#ifndef __rtems__
int fget_cap_locked(struct filedesc *fdp, int fd, cap_rights_t *needrightsp,
struct file **fpp, struct filecaps *havecapsp);
int fget_cap(struct thread *td, int fd, cap_rights_t *needrightsp,
@@ -245,7 +305,32 @@ void pwd_chdir(struct thread *td, struct vnode *vp);
int pwd_chroot(struct thread *td, struct vnode *vp);
void pwd_ensure_dirs(void);
-#ifdef __rtems__
+static inline int
+fget_cap(struct thread *td, int fd, cap_rights_t *needrightsp,
+ struct file **fpp, struct filecaps *havecapsp)
+ (void)td;
+ (void)needrightsp;
+ (void)havecapsp;
+#define fget_cap_locked(fdp, fd, needrightsp, fpp, havecapsp) \
+ fget_cap(NULL, fd, needrightsp, fpp, havecapsp)
+static inline int
+rtems_bsd_fget_unlocked(int fd, struct file **fpp, seq_t *seqp)
+ (void)seqp;
+#define fget_unlocked(fdp, fd, needrightsp, fpp, seqp) \
+ rtems_bsd_fget_unlocked(fd, fpp, seqp)
#include <machine/rtems-bsd-libio.h>
#endif /* _KERNEL */
diff --git a/freebsd/sys/sys/namei.h b/freebsd/sys/sys/namei.h
index 53814117..500024de 100644
--- a/freebsd/sys/sys/namei.h
+++ b/freebsd/sys/sys/namei.h
@@ -75,7 +75,9 @@ struct nameidata {
struct vnode *ni_startdir; /* starting directory */
struct vnode *ni_rootdir; /* logical root directory */
+#ifndef __rtems__
struct vnode *ni_topdir; /* logical top directory */
int ni_dirfd; /* starting directory for *at functions */
int ni_lcf; /* local call flags */
diff --git a/freebsd/sys/sys/proc.h b/freebsd/sys/sys/proc.h
index 6ac1025d..4e061de8 100644
--- a/freebsd/sys/sys/proc.h
+++ b/freebsd/sys/sys/proc.h
@@ -633,8 +633,8 @@ struct proc {
struct ucred *p_ucred; /* (c) Process owner's identity. */
struct filedesc *p_fd; /* (b) Open files. */
- struct filedesc_to_leader *p_fdtol; /* (b) Tracking node */
#ifndef __rtems__
+ struct filedesc_to_leader *p_fdtol; /* (b) Tracking node */
struct pstats *p_stats; /* (b) Accounting/statistics (CPU). */
struct plimit *p_limit; /* (c) Resource limits. */
struct callout p_limco; /* (c) Limit callout handle */
diff --git a/freebsd/sys/sys/socketvar.h b/freebsd/sys/sys/socketvar.h
index 96ba4a01..ad57730a 100644
--- a/freebsd/sys/sys/socketvar.h
+++ b/freebsd/sys/sys/socketvar.h
@@ -381,9 +381,22 @@ struct uio;
#ifndef __rtems__
int getsockaddr(struct sockaddr **namp, caddr_t uaddr, size_t len);
int getsock_cap(struct thread *td, int fd, cap_rights_t *rightsp,
struct file **fpp, u_int *fflagp, struct filecaps *havecaps);
+int rtems_bsd_getsock(int fd, struct file **fpp, u_int *fflagp);
+static inline int
+getsock_cap(struct thread *td, int fd, cap_rights_t *rightsp,
+ struct file **fpp, u_int *fflagp, struct filecaps *havecaps)
+ (void)td;
+ (void)rightsp;
+ (void)havecaps;
+ return (rtems_bsd_getsock(fd, fpp, fflagp));
void soabort(struct socket *so);
int soaccept(struct socket *so, struct sockaddr **nam);
void soaio_enqueue(struct task *task);
diff --git a/freebsd/sys/sys/syscallsubr.h b/freebsd/sys/sys/syscallsubr.h
index 677afdd6..f150d7f9 100644
--- a/freebsd/sys/sys/syscallsubr.h
+++ b/freebsd/sys/sys/syscallsubr.h
@@ -191,8 +191,13 @@ int kern_nanosleep(struct thread *td, struct timespec *rqt,
struct timespec *rmt);
int kern_ogetdirentries(struct thread *td, struct ogetdirentries_args *uap,
long *ploff);
+#ifndef __rtems__
int kern_openat(struct thread *td, int fd, char *path,
enum uio_seg pathseg, int flags, int mode);
+int kern_openat(struct thread *td, int fd, char *path,
+ enum uio_seg pathseg, int flags, int mode, struct file *fp);
int kern_pathconf(struct thread *td, char *path, enum uio_seg pathseg,
int name, u_long flags, long *valuep);
int kern_pipe(struct thread *td, int fildes[2], int flags,
diff --git a/libbsd.py b/libbsd.py
index 983f41a1..ec72b3e2 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -203,6 +203,7 @@ class rtems(builder.Module):
'rtems/rtems-kernel-dev.c',
'rtems/rtems-kernel-dirent.c',
'rtems/rtems-kernel-epoch.c',
+ 'rtems/rtems-kernel-fget.c',
'rtems/rtems-kernel-get-file.c',
'rtems/rtems-kernel-init.c',
'rtems/rtems-kernel-irqs.c',
diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
index a83334b5..dc19c7c2 100644
--- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
+++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
@@ -1765,8 +1765,6 @@
#define eventhandler_prune_list _bsd_eventhandler_prune_list
#define eventhandler_register _bsd_eventhandler_register
#define extattr_check_cred _bsd_extattr_check_cred
-#define falloc_caps _bsd_falloc_caps
-#define falloc_noinstall _bsd_falloc_noinstall
#define fb_commonioctl _bsd_fb_commonioctl
#define fb_dump_adp_info _bsd_fb_dump_adp_info
#define fb_dump_mode_info _bsd_fb_dump_mode_info
@@ -1806,16 +1804,6 @@
#define fdt_pinctrl_configure_tree _bsd_fdt_pinctrl_configure_tree
#define fdt_pinctrl_register _bsd_fdt_pinctrl_register
#define fdt_regsize _bsd_fdt_regsize
-#define fget _bsd_fget
-#define fget_cap _bsd_fget_cap
-#define fget_cap_locked _bsd_fget_cap_locked
-#define fget_fcntl _bsd_fget_fcntl
-#define fget_read _bsd_fget_read
-#define fget_unlocked _bsd_fget_unlocked
-#define fget_write _bsd_fget_write
-#define fgetvp _bsd_fgetvp
-#define fgetvp_read _bsd_fgetvp_read
-#define fgetvp_rights _bsd_fgetvp_rights
#define fha_assign _bsd_fha_assign
#define fha_init _bsd_fha_init
#define fha_nd_complete _bsd_fha_nd_complete
@@ -1827,15 +1815,9 @@
#define fib6_free_nh_ext _bsd_fib6_free_nh_ext
#define fib6_lookup_nh_basic _bsd_fib6_lookup_nh_basic
#define fib6_lookup_nh_ext _bsd_fib6_lookup_nh_ext
-#define filecaps_copy _bsd_filecaps_copy
-#define filecaps_free _bsd_filecaps_free
-#define filecaps_init _bsd_filecaps_init
-#define filecaps_move _bsd_filecaps_move
-#define filedesc_to_leader_alloc _bsd_filedesc_to_leader_alloc
#define find_and_ref_tcp_fb _bsd_find_and_ref_tcp_fb
#define find_and_ref_tcp_functions _bsd_find_and_ref_tcp_functions
#define find_handler _bsd_find_handler
-#define finit _bsd_finit
#define finstall _bsd_finstall
#define firewire_broadcastaddr _bsd_firewire_broadcastaddr
#define firewire_busreset _bsd_firewire_busreset
diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-space.h b/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
index 37bd701d..7b766538 100644
--- a/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
+++ b/rtemsbsd/include/machine/rtems-bsd-kernel-space.h
@@ -233,11 +233,6 @@ dev_t rtems_bsd__makedev(int _M, int _m);
#define SIGISMEMBER(set, signo) (0)
- * Special knote status bit to indicate the kn_fp is an iop.
-#define KN_FP_IS_IOP 0x10000000
* Ensure that padding bytes are zeroed and that the name is NUL-terminated.
diff --git a/rtemsbsd/include/machine/rtems-bsd-libio.h b/rtemsbsd/include/machine/rtems-bsd-libio.h
index e662a9ec..3c3a8bbb 100644
--- a/rtemsbsd/include/machine/rtems-bsd-libio.h
+++ b/rtemsbsd/include/machine/rtems-bsd-libio.h
@@ -54,6 +54,8 @@ extern const rtems_filesystem_file_handlers_r rtems_bsd_sysgen_imfsnodeops;
extern const rtems_filesystem_file_handlers_r rtems_bsd_sysgen_dirops;
extern const rtems_filesystem_file_handlers_r rtems_bsd_sysgen_fileops;
+int rtems_bsd_sysgen_close(rtems_libio_t *iop);
static int inline rtems_bsd_error_to_status_and_errno(int error)
if (error == 0) {
@@ -63,26 +65,6 @@ static int inline rtems_bsd_error_to_status_and_errno(int error)
-static inline uint32_t
-rtems_bsd_libio_fflag_to_flags(u_int fflag)
- uint32_t libio_flags = 0;
- if ((fflag & FREAD) == FREAD) {
- libio_flags |= LIBIO_FLAGS_READ;
- if ((fflag & FWRITE) == FWRITE) {
- libio_flags |= LIBIO_FLAGS_WRITE;
- if ((fflag & FNONBLOCK) == FNONBLOCK) {
- libio_flags |= LIBIO_FLAGS_NO_DELAY;
- return (libio_flags);
static inline u_int
rtems_bsd_libio_flags_to_fflag(uint32_t libio_flags)
@@ -103,20 +85,6 @@ rtems_bsd_libio_flags_to_fflag(uint32_t libio_flags)
return (fflag);
-static inline bool
-rtems_bsd_is_libbsd_nvops(rtems_libio_t *iop)
- return (iop->pathinfo.handlers == &rtems_bsd_sysgen_dirops ||
- iop->pathinfo.handlers == &rtems_bsd_sysgen_fileops);
-static inline bool
-rtems_bsd_is_libbsd_descriptor(rtems_libio_t *iop)
- return (iop->pathinfo.handlers == &rtems_bsd_sysgen_nodeops ||
- rtems_bsd_is_libbsd_nvops(iop));
rtems_bsd_libio_loc_to_iop(const rtems_filesystem_location_info_t *loc)
@@ -151,173 +119,19 @@ rtems_bsd_libio_loc_to_vnode_dir(const rtems_filesystem_location_info_t *loc)
->node_access_2;
-static inline void
-rtems_bsd_libio_iop_free(rtems_libio_t *iop)
- rtems_libio_free(iop);
-static int
-rtems_bsd_libio_iop_to_descriptor(rtems_libio_t *iop)
- return (int)iop->data0;
static struct vnode *
rtems_bsd_libio_iop_to_vnode(rtems_libio_t *iop)
return rtems_bsd_libio_loc_to_vnode(&iop->pathinfo);
-static int
-rtems_bsd_libio_fd_to_descriptor(int fd)
- return rtems_bsd_libio_iop_to_descriptor(rtems_libio_iop(fd));
static inline struct file *
-rtems_bsd_libio_iop_to_file_hold(rtems_libio_t *iop, struct thread *td)
- struct file *fp;
- int error = fget_unlocked(td->td_proc->p_fd,
- rtems_bsd_libio_iop_to_descriptor(iop), NULL, &fp, NULL);
- if (error != 0) {
- fp = NULL;
- return fp;
-static inline int
-rtems_bsd_file_to_libio_fd(struct file *fp)
- return fp->f_io - rtems_libio_iops;
-static inline void
-rtems_bsd_libio_iop_set_bsd_descriptor(rtems_libio_t *iop, int fd)
- iop->data0 = fd;
- /* if not vnops the fstat passes a loc, need to get the iop to get the
- * fp */
- if (!rtems_bsd_is_libbsd_nvops(iop)) {
- iop->pathinfo.node_access = iop;
-static inline void
-rtems_bsd_libio_iop_set_bsd_file(rtems_libio_t *iop, struct file *fp)
- fp->f_io = iop;
- * The fd is a libio file descriptor.
- * Return -1 if the descriptor is closed or not valid. The descriptor is not
- * held.
- * If open hold the descriptor. If the descriptor referneces a BSD
- * descriptor return the BSD descriptor else return the libio descriptor.
- * Optionally return the iop in *iopp if the descriptor if a libio descriptor
- * else return NULL.
-static inline int
-rtems_bsd_libio_iop_hold(int fd, rtems_libio_t **iopp)
+rtems_bsd_knote_to_file(const struct knote *kn)
- rtems_libio_t *iop = NULL;
- unsigned int flags = 0;
- int ffd = -1;
- if (fd < rtems_libio_number_iops) {
- iop = rtems_libio_iop(fd);
- flags = rtems_libio_iop_hold(iop);
- if ((flags & LIBIO_FLAGS_OPEN) != 0) {
- if (rtems_bsd_is_libbsd_descriptor(iop)) {
- ffd = rtems_bsd_libio_iop_to_descriptor(iop);
- if (iopp != NULL) {
- *iopp = NULL;
- } else {
- ffd = fd;
- *iopp = iop;
- } else {
- flags = iop->flags;
- } else {
- *iopp = NULL;
- printf("bsd: iop: hold: fd=%d ffd=%d refs=%d iop=%p by %p\n",
- fd, ffd, flags >> 12, iop, __builtin_return_address(0));
- return ffd;
+ return (kn->kn_fp->data1);
-static inline int
-rtems_bsd_libio_iop_drop(int fd)
- printf("bsd: iop: drop: fd=%d refs=%d by %p\n", fd,
- rtems_libio_iop(fd)->flags >> 12,
- __builtin_return_address(0));
- rtems_libio_iop_drop(rtems_libio_iop(fd));
- return 0;
-static inline int
-rtems_bsd_libio_fo_poll(int fd, struct file *fp, int events,
- struct ucred *active_cred, struct thread *td)
- int error;
- if (fp == NULL) {
- rtems_libio_t *iop = rtems_libio_iop(fd);
- error = (*iop->pathinfo.handlers->poll_h)(iop, events);
- } else {
- error = (*fp->f_ops->fo_poll)(fp, events, active_cred, td);
- fd = rtems_bsd_file_to_libio_fd(fp);
- rtems_bsd_libio_iop_drop(fd);
- return error;
-static inline void
-rtems_bsd_libio_iop_to_knote(struct knote *kn, rtems_libio_t *iop)
- kn->kn_fp = (struct file *)iop;
-static inline struct kqueue *
-rtems_bsd_libio_knote_to_kq(struct knote *kn)
- struct kqueue *kq = kn->kn_kq;
- if (kq != kn->kn_fp->f_data)
- panic("libio kq wrong\n");
- return kq;
- * Returns an iop with null file system mount or NULL is ENFILE.
-rtems_libio_t *rtems_bsd_libio_iop_allocate(void);
- * Returns the libio descriptor or -1 if ENFILE.
-int rtems_bsd_libio_iop_allocate_with_file(
- struct thread *td, int fd, const rtems_filesystem_file_handlers_r *ops);
- * Set the BSD file descriptor in the iop. Returns 0 if successful or an error
- * number,
-int rtems_bsd_libio_iop_set_bsd_fd(struct thread *td, int fd,
- rtems_libio_t *iop, const rtems_filesystem_file_handlers_r *ops);
+struct file *rtems_bsd_iop_to_file(const rtems_libio_t *iop);
* Set the vnode in the libio location.
diff --git a/rtemsbsd/rtems/rtems-bsd-libio.c b/rtemsbsd/rtems/rtems-bsd-libio.c
index fba82831..59f22feb 100644
--- a/rtemsbsd/rtems/rtems-bsd-libio.c
+++ b/rtemsbsd/rtems/rtems-bsd-libio.c
@@ -45,67 +45,6 @@
#include <rtems/libio.h>
-rtems_libio_t *
-rtems_bsd_libio_iop_allocate(void)
- rtems_libio_t *iop = rtems_libio_allocate();
- iop->pathinfo.mt_entry = &rtems_filesystem_null_mt_entry;
- rtems_filesystem_location_add_to_mt_entry(&iop->pathinfo);
- return iop;
-int
-rtems_bsd_libio_iop_allocate_with_file(
- rtems_libio_t *iop = rtems_bsd_libio_iop_allocate();
- int iofd = -1;
- int error = rtems_bsd_libio_iop_set_bsd_fd(td, fd, iop, ops);
- * The fp is held and needs to be dropped and that drops the
- * iop.
- if (error == 0) {
- rtems_libio_iop_hold(iop);
- iofd = rtems_libio_iop_to_descriptor(iop);
- } else {
- return iofd;
-int
-rtems_bsd_libio_iop_set_bsd_fd(struct thread *td, int fd, rtems_libio_t *iop,
- const rtems_filesystem_file_handlers_r *ops)
- struct filedesc *fdp = td->td_proc->p_fd;
- int error;
- FILEDESC_XLOCK(fdp);
- if (fd < fdp->fd_nfiles) {
- struct file *fp = fget_locked(fdp, fd);
- if (fp != NULL) {
- rtems_bsd_libio_iop_set_bsd_file(iop, fp);
- rtems_libio_iop_flags_set(iop,
- LIBIO_FLAGS_OPEN |
- rtems_bsd_libio_fflag_to_flags(fp->f_flag));
- if (ops != NULL)
- iop->pathinfo.handlers = ops;
- rtems_bsd_libio_iop_set_bsd_descriptor(iop, fd);
- error = 0;
- } else {
- error = EBADF;
- } else {
- error = EBADF;
- FILEDESC_XUNLOCK(fdp);
- return error;
void
rtems_bsd_libio_loc_set_vnode(
rtems_filesystem_location_info_t *loc, struct vnode *vp)
diff --git a/rtemsbsd/rtems/rtems-bsd-syscall-api.c b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
index 5c45d88a..ba8a6b60 100644
--- a/rtemsbsd/rtems/rtems-bsd-syscall-api.c
+++ b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
@@ -43,6 +43,7 @@
#include <sys/filedesc.h>
#include <sys/proc.h>
+#include <sys/socketvar.h>
@@ -63,7 +64,6 @@ static int rtems_bsd_sysgen_opendir(
rtems_libio_t *iop, const char *path, int oflag, mode_t mode);
static int rtems_bsd_sysgen_open(
-static int rtems_bsd_sysgen_close(rtems_libio_t *iop);
static ssize_t rtems_bsd_sysgen_read(
rtems_libio_t *iop, void *buffer, size_t count);
static ssize_t rtems_bsd_sysgen_readv(
@@ -165,6 +165,98 @@ const rtems_filesystem_file_handlers_r rtems_bsd_sysgen_imfsnodeops = {
.mmap_h = rtems_filesystem_default_mmap
+int
+rtems_bsd_getsock(int fd, struct file **fpp, u_int *fflagp)
+ int error;
+ struct file *fp;
+ error = EBADF;
+ goto bad;
+ error = EBADF;
+ goto drop;
+ if (iop->pathinfo.handlers->close_h != rtems_bsd_sysgen_close) {
+ error = ENOTSOCK;
+ goto drop;
+ fp = iop->data1;
+ if (fp->f_type != DTYPE_SOCKET) {
+ error = ENOTSOCK;
+ goto drop;
+ if (fflagp != NULL)
+ *fflagp = fp->f_flag;
+ *fpp = fp;
+ return (0);
+drop:
+bad:
+ *fpp = NULL;
+ return (error);
+struct file *
+rtems_bsd_iop_to_file(const rtems_libio_t *iop)
+ return (NULL);
+ return (iop->data1);
+int
+rtems_bsd_falloc(struct file **resultfp, int *resultfd)
+ struct file *fp;
+ fp = malloc(sizeof(*fp), M_TEMP, M_ZERO | M_NOWAIT);
+ *resultfp = fp;
+ if (fp == NULL) {
+ return (ENOMEM);
+ iop = rtems_libio_allocate();
+ if (iop == NULL) {
+ return (ENFILE);
+ fp->f_io = iop;
+ iop->data1 = fp;
+ iop->pathinfo.node_access = iop;
+ iop->pathinfo.handlers = &rtems_bsd_sysgen_nodeops;
+ iop->pathinfo.mt_entry = &rtems_filesystem_null_mt_entry;
+ rtems_filesystem_location_add_to_mt_entry(&iop->pathinfo);
+ *resultfd = rtems_libio_iop_to_descriptor(iop);
+ return (0);
+void
+rtems_bsd_fdclose(struct file *fp)
+ rtems_libio_free(fp->f_io);
+ free(fp, M_TEMP);
int
accept(int socket, struct sockaddr *__restrict address,
socklen_t *__restrict address_len)
@@ -181,37 +273,14 @@ accept(int socket, struct sockaddr *__restrict address,
if (td == NULL) {
return rtems_bsd_error_to_status_and_errno(ENOMEM);
- int ffd = rtems_bsd_libio_iop_hold(socket, NULL);
- if (ffd < 0) {
- return rtems_bsd_error_to_status_and_errno(EBADF);
- ua.s = ffd;
+ ua.s = socket;
ua.name = address;
ua.anamelen = address_len;
error = sys_accept(td, &ua);
- rtems_bsd_libio_iop_drop(socket);
- if (error != 0) {
- return rtems_bsd_error_to_status_and_errno(error);
- iop = rtems_bsd_libio_iop_allocate();
- afd = td->td_retval[0];
- kern_close(td, afd);
- return rtems_bsd_error_to_status_and_errno(ENFILE);
- error = rtems_bsd_libio_iop_set_bsd_fd(
- td, afd, iop, &rtems_bsd_sysgen_nodeops);
if (error != 0) {
- rtems_bsd_libio_iop_free(iop);
- if (RTEMS_BSD_SYSCALL_TRACE) {
- printf("bsd: sys: accept: %d (%d) => %d -> %d\n", socket, ffd,
- rtems_libio_iop_to_descriptor(iop),
- rtems_bsd_libio_iop_to_descriptor(iop));
- return rtems_libio_iop_to_descriptor(iop);
+ return (td->td_retval[0]);
int
@@ -219,7 +288,6 @@ bind(int socket, const struct sockaddr *address, socklen_t address_len)
struct thread *td = rtems_bsd_get_curthread_or_null();
struct bind_args ua;
- int ffd;
int error;
printf("bsd: sys: bind: %d\n", socket);
@@ -227,15 +295,10 @@ bind(int socket, const struct sockaddr *address, socklen_t address_len)
if (td == NULL) {
- ffd = rtems_bsd_libio_iop_hold(socket, NULL);
- if (ffd == -1) {
- ua.s = ffd;
+ ua.s = socket;
ua.name = address;
ua.namelen = address_len;
error = sys_bind(td, &ua);
@@ -244,7 +307,6 @@ connect(int socket, const struct sockaddr *address, socklen_t address_len)
struct connect_args ua;
- int ffd;
int error;
printf("bsd: sys: connect: %d\n", socket);
@@ -252,15 +314,10 @@ connect(int socket, const struct sockaddr *address, socklen_t address_len)
if (td == NULL) {
- if (ffd < 0) {
- ua.s = ffd;
+ ua.s = socket;
ua.name = address;
error = sys_connect(td, &ua);
@@ -270,7 +327,6 @@ getpeername(int socket, struct sockaddr *__restrict address,
struct getpeername_args ua;
- int ffd;
int error;
printf("bsd: sys: getpeername: %d\n", socket);
@@ -278,15 +334,10 @@ getpeername(int socket, struct sockaddr *__restrict address,
if (td == NULL) {
- if (ffd < 0) {
- ua.fdes = ffd;
+ ua.fdes = socket;
ua.asa = address;
ua.alen = address_len;
error = sys_getpeername(td, &ua);
@@ -296,7 +347,6 @@ getsockname(int socket, struct sockaddr *__restrict address,
struct getsockname_args ua;
- int ffd;
int error;
printf("bsd: sys: getsockname: %d\n", socket);
@@ -304,15 +354,10 @@ getsockname(int socket, struct sockaddr *__restrict address,
if (td == NULL) {
- if (ffd < 0) {
- ua.fdes = ffd;
+ ua.fdes = socket;
ua.asa = address;
error = sys_getsockname(td, &ua);
@@ -322,7 +367,6 @@ getsockopt(int socket, int level, int option_name,
struct getsockopt_args ua;
- int ffd;
int error;
printf("bsd: sys: getsockopt: %d\n", socket);
@@ -330,17 +374,12 @@ getsockopt(int socket, int level, int option_name,
if (td == NULL) {
- if (ffd < 0) {
- ua.s = ffd;
+ ua.s = socket;
ua.level = level;
ua.name = option_name;
ua.val = (caddr_t)option_value;
ua.avalsize = option_len;
error = sys_getsockopt(td, &ua);
@@ -349,7 +388,6 @@ kqueue(void)
struct kqueue_args ua = {};
- rtems_libio_t *iop;
int error;
printf("bsd: sys: kqueue:\n");
@@ -357,28 +395,11 @@ kqueue(void)
if (td == NULL) {
error = sys_kqueue(td, &ua);
if (error != 0) {
- goto out;
- td, td->td_retval[0], iop, &rtems_bsd_sysgen_nodeops);
- if (error == 0) {
- printf("bsd: sys: kqueue: %d -> %d\n",
+ return rtems_bsd_error_to_status_and_errno(error);
- kern_close(td, rtems_libio_iop_to_descriptor(iop));
-out:
__weak_reference(kevent, _kevent);
@@ -397,18 +418,13 @@ kevent(int kq, const struct kevent *changelist, int nchanges,
if (td == NULL) {
- ffd = rtems_bsd_libio_iop_hold(kq, NULL);
- if (ffd < 0) {
- ua.fd = ffd;
+ ua.fd = kq;
ua.changelist = changelist;
ua.nchanges = nchanges;
ua.eventlist = eventlist;
ua.nevents = nevents;
ua.timeout = timeout;
error = sys_kevent(td, &ua);
- rtems_bsd_libio_iop_drop(kq);
if (error != 0) {
@@ -420,7 +436,6 @@ listen(int socket, int backlog)
struct listen_args ua;
- int ffd;
int error;
printf("bsd: sys: listen: %d\n", socket);
@@ -428,14 +443,9 @@ listen(int socket, int backlog)
if (td == NULL) {
- if (ffd < 0) {
- ua.s = ffd;
+ ua.s = socket;
ua.backlog = backlog;
error = sys_listen(td, &ua);
@@ -507,7 +517,6 @@ recvfrom(int socket, void *__restrict buffer, size_t length, int flags,
struct recvfrom_args ua;
- int ffd;
int error;
printf("bsd: sys: recvfrom: %d\n", socket);
@@ -515,18 +524,13 @@ recvfrom(int socket, void *__restrict buffer, size_t length, int flags,
if (td == NULL) {
- if (ffd < 0) {
- ua.s = ffd;
+ ua.s = socket;
ua.buf = buffer;
ua.len = length;
ua.flags = flags;
ua.from = address;
ua.fromlenaddr = address_len;
error = sys_recvfrom(td, &ua);
if (error != 0) {
@@ -538,7 +542,6 @@ recvmsg(int socket, struct msghdr *message, int flags)
struct recvmsg_args ua;
- int ffd;
int error;
printf("bsd: sys: recvmsg: %d\n", socket);
@@ -546,15 +549,10 @@ recvmsg(int socket, struct msghdr *message, int flags)
if (td == NULL) {
- if (ffd < 0) {
- ua.s = ffd;
+ ua.s = socket;
ua.msg = message;
ua.flags = flags;
error = sys_recvmsg(td, &ua);
if (error != 0) {
@@ -591,7 +589,6 @@ sendto(int socket, const void *message, size_t length, int flags,
struct sendto_args ua;
- int ffd;
int error;
printf("bsd: sys: sendto: %d\n", socket);
@@ -599,18 +596,13 @@ sendto(int socket, const void *message, size_t length, int flags,
if (td == NULL) {
- if (ffd < 0) {
- ua.s = ffd;
+ ua.s = socket;
ua.buf = (caddr_t)message;
ua.len = length;
ua.flags = flags;
ua.to = dest_addr;
ua.tolen = dest_len;
error = sys_sendto(td, &ua);
if (error != 0) {
@@ -622,7 +614,6 @@ sendmsg(int socket, const struct msghdr *message, int flags)
struct sendmsg_args ua;
- int ffd;
int error;
printf("bsd: sys: sendmsg: %d\n", socket);
@@ -630,15 +621,10 @@ sendmsg(int socket, const struct msghdr *message, int flags)
if (td == NULL) {
- if (ffd < 0) {
- ua.s = ffd;
+ ua.s = socket;
ua.msg = message;
ua.flags = flags;
error = sys_sendmsg(td, &ua);
@@ -648,7 +634,6 @@ setsockopt(int socket, int level, int option_name, const void *option_value,
struct setsockopt_args ua;
- int ffd;
int error;
printf("bsd: sys: setsockopt: %d\n", socket);
@@ -656,17 +641,12 @@ setsockopt(int socket, int level, int option_name, const void *option_value,
if (td == NULL) {
- if (ffd < 0) {
- ua.s = ffd;
+ ua.s = socket;
ua.level = level;
ua.val = __DECONST(void *, option_value);
ua.valsize = option_len;
error = sys_setsockopt(td, &ua);
@@ -674,7 +654,6 @@ int
shutdown(int socket, int how)
- int ffd;
int error;
printf("bsd: sys: shutdown: %d\n", socket);
@@ -682,17 +661,8 @@ shutdown(int socket, int how)
if (td == NULL) {
- if (ffd < 0) {
- if (rtems_bsd_is_libbsd_descriptor(rtems_libio_iop(socket))) {
- struct shutdown_args ua = { .s = ffd, .how = how };
- error = sys_shutdown(td, &ua);
- } else {
- error = ENOTSOCK;
+ struct shutdown_args ua = { .s = socket, .how = how };
+ error = sys_shutdown(td, &ua);
@@ -700,45 +670,26 @@ int
socket(int domain, int type, int protocol)
struct thread *td;
struct socket_args ua;
int error;
if (td == NULL) {
ua.domain = domain;
ua.type = type;
ua.protocol = protocol;
error = sys_socket(td, &ua);
if (error != 0) {
- if (error != 0) {
- kern_close(td, td->td_retval[0]);
- printf("bsd: sys: socket: %d -> %d\n",
int
socketpair(int domain, int type, int protocol, int *socket_vector)
struct thread *td;
- rtems_libio_t *iop[2];
struct socketpair_args ua;
int error;
@@ -748,48 +699,15 @@ socketpair(int domain, int type, int protocol, int *socket_vector)
if (td == NULL) {
- iop[0] = rtems_bsd_libio_iop_allocate();
- if (iop[0] == NULL) {
- iop[1] = rtems_bsd_libio_iop_allocate();
- if (iop[1] == NULL) {
- rtems_bsd_libio_iop_free(iop[0]);
ua.domain = domain;
ua.type = type;
ua.rsv = socket_vector;
error = sys_socketpair(td, &ua);
if (error != 0) {
- goto out;
- td, socket_vector[0], iop[0], &rtems_bsd_sysgen_nodeops);
- if (error != 0) {
- goto out;
- td, socket_vector[1], iop[1], &rtems_bsd_sysgen_nodeops);
- if (error == 0) {
- socket_vector[0] = rtems_libio_iop_to_descriptor(iop[0]);
- socket_vector[1] = rtems_libio_iop_to_descriptor(iop[1]);
- printf("bsd: sys: socketpair: %d -> %d, %d -> %d\n",
- socket_vector[0],
- rtems_bsd_libio_iop_to_descriptor(iop[0]),
- socket_vector[1],
- rtems_bsd_libio_iop_to_descriptor(iop[1]));
- return 0;
-out:
- kern_close(td, rtems_bsd_libio_iop_to_descriptor(iop[0]));
- kern_close(td, rtems_bsd_libio_iop_to_descriptor(iop[1]));
- rtems_bsd_libio_iop_free(iop[1]);
+ return (0);
@@ -814,6 +732,7 @@ rtems_bsd_sysgen_open_node(
int opathlen;
int fd;
int error;
+ struct vnode *vn;
if (td == NULL) {
@@ -822,6 +741,18 @@ rtems_bsd_sysgen_open_node(
+ if (fp == NULL) {
+ return rtems_bsd_error_to_status_and_errno(ENOMEM);
+ refcount_init(&fp->f_count, 1);
+ fp->f_cred = crhold(td->td_ucred);
+ fp->f_ops = &badfileops;
+ fp->f_io = iop;
+ iop->data1 = fp;
@@ -890,7 +821,7 @@ rtems_bsd_sysgen_open_node(
VREF(fdp->fd_cdir);
error = kern_openat(td, AT_FDCWD, RTEMS_DECONST(char *, opath),
- UIO_USERSPACE, oflag, mode);
+ UIO_USERSPACE, oflag, mode, fp);
vrele(fdp->fd_cdir);
@@ -907,19 +838,10 @@ rtems_bsd_sysgen_open_node(
fdp->fd_cdir = cdir;
fdp->fd_rdir = rdir;
- struct vnode *vn;
- fp = fget_locked(fdp, fd);
- if (fp != NULL) {
- vn = fp->f_vnode;
- } else {
- vn = NULL;
- rtems_bsd_libio_loc_set_vnode(&iop->pathinfo, vn);
+ rtems_bsd_libio_loc_set_vnode(&iop->pathinfo, fp->f_vnode);
- rtems_bsd_libio_iop_set_bsd_fd(td, fd, iop, &rtems_bsd_sysgen_fileops);
+ iop->pathinfo.handlers = &rtems_bsd_sysgen_fileops;
printf("bsd: sys: open: fd = %d vn=%p\n", fd,
@@ -946,28 +868,42 @@ rtems_bsd_sysgen_open(
int
- struct thread *td = curthread;
+ struct thread *td;
+ struct file *fp;
int error;
- int ffd = rtems_bsd_libio_iop_to_descriptor(iop);
- printf("bsd: sys: close: %d -> %d\n",
- rtems_libio_iop_to_descriptor(iop), ffd);
- if (td != NULL) {
- if (ffd >= 0) {
- error = kern_close(td, ffd);
- } else {
- error = EBADF;
+ printf("bsd: sys: close: %d\n",
+ rtems_libio_iop_to_descriptor(iop));
+ td = rtems_bsd_get_curthread_or_null();
+ if (td == NULL) {
+ if (RTEMS_BSD_SYSCALL_TRACE) {
+ printf("bsd: sys: close: no curthread\n");
- } else {
- error = ENOMEM;
+ return (rtems_bsd_error_to_status_and_errno(ENOMEM));
- printf("bsd: sys: close: %d: %d: %s\n",
- rtems_libio_iop_to_descriptor(iop), error, strerror(error));
+ fp = iop->data1;
+ BSD_ASSERT(fp->f_count == 1);
+ error = (fo_close(fp, td));
+ if (error != 0) {
+ printf("bsd: sys: close: error = %d\n", error);
+ return (rtems_bsd_error_to_status_and_errno(error));
+ printf("bsd: sys: close: success\n");
+ FILEDESC_XLOCK(NULL);
+ knote_fdclose(td, rtems_libio_iop_to_descriptor(iop));
+ FILEDESC_XUNLOCK(NULL);
+ crfree(fp->f_cred);
+ free(fp, M_TEMP);
+ return (0);
ssize_t
@@ -975,7 +911,7 @@ rtems_bsd_sysgen_read(rtems_libio_t *iop, void *buffer, size_t count)
struct vnode *vp = rtems_bsd_libio_iop_to_vnode(iop);
- int fd = rtems_bsd_libio_iop_to_descriptor(iop);
+ int fd = rtems_libio_iop_to_descriptor(iop);
int error;
ssize_t size = 0;
@@ -1046,7 +982,7 @@ rtems_bsd_sysgen_read(rtems_libio_t *iop, void *buffer, size_t count)
.uio_rw = UIO_READ,
.uio_td = td };
error = kern_readv(
- td, rtems_bsd_libio_iop_to_descriptor(iop), &auio);
+ td, rtems_libio_iop_to_descriptor(iop), &auio);
if (error == 0)
size = td->td_retval[0];
@@ -1091,7 +1027,7 @@ rtems_bsd_sysgen_readv(
auio.uio_resid = total;
auio.uio_segflg = UIO_USERSPACE;
- error = kern_readv(td, rtems_bsd_libio_iop_to_descriptor(iop), &auio);
+ error = kern_readv(td, rtems_libio_iop_to_descriptor(iop), &auio);
if (error != 0)
@@ -1129,7 +1065,7 @@ rtems_bsd_sysgen_write(rtems_libio_t *iop, const void *buffer, size_t count)
auio.uio_resid = count;
- error = kern_writev(td, rtems_bsd_libio_iop_to_descriptor(iop), &auio);
+ error = kern_writev(td, rtems_libio_iop_to_descriptor(iop), &auio);
if (error != 0)
@@ -1165,7 +1101,7 @@ rtems_bsd_sysgen_writev(
if (error != 0)
@@ -1191,7 +1127,7 @@ rtems_bsd_sysgen_ioctl(
error = kern_ioctl(
- td, rtems_bsd_libio_iop_to_descriptor(iop), com, buffer);
+ td, rtems_libio_iop_to_descriptor(iop), com, buffer);
@@ -1211,7 +1147,7 @@ rtems_bsd_sysgen_lseek(rtems_libio_t *iop, off_t offset, int whence)
error = kern_lseek(
- td, rtems_bsd_libio_iop_to_descriptor(iop), offset, whence);
+ td, rtems_libio_iop_to_descriptor(iop), offset, whence);
if (error != 0) {
@@ -1253,9 +1189,7 @@ rtems_bsd_sysgen_fstat(
rtems_libio_t *iop = rtems_bsd_libio_loc_to_iop(loc);
- struct filedesc *fdp;
struct file *fp = NULL;
- int fd;
int error;
if (iop == NULL) {
@@ -1263,22 +1197,13 @@ rtems_bsd_sysgen_fstat(
return rtems_bsd_error_to_status_and_errno(ENXIO);
- fd = rtems_bsd_libio_iop_to_descriptor(iop);
- printf("bsd: sys: fstat: %d\n", fd);
if (td == NULL) {
printf("bsd: sys: fstat: no curthread\n");
- fdp = td->td_proc->p_fd;
+ fp = rtems_bsd_iop_to_file(iop);
if (fp != NULL) {
error = fo_stat(fp, buf, NULL, td);
} else {
@@ -1293,11 +1218,9 @@ rtems_bsd_sysgen_imfsfstat(
struct socket *so = rtems_bsd_libio_imfs_loc_to_so(loc);
- struct socket *fd_so = NULL;
- int fd;
int error;
+ int fd;
printf("bsd: sys: imfsfstat: socket=%p\n", so);
@@ -1307,17 +1230,22 @@ rtems_bsd_sysgen_imfsfstat(
- for (fd = 0; fd < fdp->fd_nfiles; fd++) {
- fd_so = fp->f_data;
- if (so == fd_so) {
+ for (fd = 0; fd < (int)rtems_libio_number_iops; ++fd) {
+ if (iop->pathinfo.handlers == NULL) {
+ continue;
+ if (fp != NULL && fp->f_data == so) {
break;
fp = NULL;
if (fp != NULL) {
printf("bsd: sys: imfsfstat: %d\n", fd);
@@ -1344,7 +1272,7 @@ rtems_bsd_sysgen_ftruncate(rtems_libio_t *iop, off_t length)
error = kern_ftruncate(
- td, rtems_bsd_libio_iop_to_descriptor(iop), length);
+ td, rtems_libio_iop_to_descriptor(iop), length);
@@ -1362,7 +1290,7 @@ rtems_bsd_sysgen_fsync(rtems_libio_t *iop)
- error = kern_fsync(td, rtems_bsd_libio_iop_to_descriptor(iop), true);
+ error = kern_fsync(td, rtems_libio_iop_to_descriptor(iop), true);
@@ -1380,7 +1308,7 @@ rtems_bsd_sysgen_fdatasync(rtems_libio_t *iop)
- error = kern_fsync(td, rtems_bsd_libio_iop_to_descriptor(iop), false);
+ error = kern_fsync(td, rtems_libio_iop_to_descriptor(iop), false);
@@ -1416,7 +1344,7 @@ rtems_bsd_sysgen_fcntl(rtems_libio_t *iop, int cmd)
if (arg >= 0) {
error = kern_fcntl(
- td, rtems_bsd_libio_iop_to_descriptor(iop), cmd, arg);
+ td, rtems_libio_iop_to_descriptor(iop), cmd, arg);
/* no return path with the RTEMS API for get calls */
@@ -1425,13 +1353,23 @@ rtems_bsd_sysgen_fcntl(rtems_libio_t *iop, int cmd)
int
rtems_bsd_sysgen_poll(rtems_libio_t *iop, int events)
- printf("rtems_bsd_sysgen_poll called!\n");
- return rtems_bsd_error_to_status_and_errno(EOPNOTSUPP);
+ struct file *fp;
+ if (td == NULL) {
+ return (ENOMEM);
+ fp = iop->data1;
+ return (fo_poll(fp, events, td->td_ucred, td));
int
rtems_bsd_sysgen_kqfilter(rtems_libio_t *iop, struct knote *kn)
- printf("rtems_bsd_sysgen_kqfilter called!\n");
+ struct file *fp;
+ fp = iop->data1;
+ return (fo_kqfilter(fp, kn));
diff --git a/rtemsbsd/rtems/rtems-kernel-fget.c b/rtemsbsd/rtems/rtems-kernel-fget.c
new file mode 100644
index 00000000..e51ddb57
--- /dev/null
+++ b/rtemsbsd/rtems/rtems-kernel-fget.c
@@ -0,0 +1,79 @@
+ * @file
+ * @ingroup rtems_bsd_rtems
+ * @brief TODO.
+ * Copyright (C) 2022 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#include <machine/rtems-bsd-kernel-space.h>
+/* Avoid referencing the VFS only through rtems_bsd_fget() */
+__weak_symbol int
+rtems_bsd_sysgen_close(rtems_libio_t *iop)
+ (void)iop;
+ return (-1);
+int
+rtems_bsd_fget(int fd, struct file **fpp, int flags)
+ goto bad;
+ if ((actual_flags & flags) != flags) {
+ goto drop;
+ goto drop;
+ *fpp = iop->data1;
+ return (0);
+drop:
+bad:
+ *fpp = NULL;
+ return (EBADF);
diff --git a/rtemsbsd/rtems/rtems-kernel-init.c b/rtemsbsd/rtems/rtems-kernel-init.c
index 90a9c809..454943b3 100644
--- a/rtemsbsd/rtems/rtems-kernel-init.c
+++ b/rtemsbsd/rtems/rtems-kernel-init.c
@@ -141,6 +141,10 @@ cpu_startup(void *dummy)
SYSINIT(cpu, SI_SUB_CPU, SI_ORDER_FIRST, cpu_startup, NULL);
+static struct filedesc p_fd = {
+ .fd_cmask = CMASK
* Create a single process. RTEMS is a single address, single process OS.
@@ -166,8 +170,7 @@ proc0_init(void *dummy)
newcred->cr_ruidinfo = uifind(0);
p->p_ucred = newcred;
p->p_pid = getpid();
- p->p_fd = fdinit(NULL, false);
- p->p_fdtol = NULL;
+ p->p_fd = &p_fd;
rtems_sysvec.sv_flags = SV_ABI_FREEBSD;
#ifdef __LP64__
rtems_sysvec.sv_flags |= SV_LP64;
2.35.3
