[libbsd 04/22] Move setfib() back to route.c
Sebastian Huber
Fri Jun 24 06:33:32 UTC 2022
Collecting all system calls in a single translation unit is not good due to the
library initialization through linker sets.
Update #4475.
freebsd/sys/net/route.c | 18 ++++++++++++++++++
freebsd/sys/sys/sysproto.h | 2 --
.../machine/rtems-bsd-kernel-namespace.h | 1 -
rtemsbsd/rtems/rtems-bsd-syscall-api.c | 14 --------------
4 files changed, 18 insertions(+), 17 deletions(-)
diff --git a/freebsd/sys/net/route.c b/freebsd/sys/net/route.c
index 2e9883a1..adbf91bd 100644
--- a/freebsd/sys/net/route.c
+++ b/freebsd/sys/net/route.c
@@ -407,6 +407,9 @@ struct setfib_args {
int fibnum;
#endif
+#ifdef __rtems__
+static
+#endif /* __rtems__ */
int
sys_setfib(struct thread *td, struct setfib_args *uap)
@@ -420,6 +423,20 @@ sys_setfib(struct thread *td, struct setfib_args *uap)
return (0);
+#ifdef __rtems__
+int
+setfib(int fibnum)
+ struct setfib_args ua = {
+ .fibnum = fibnum
+ int error;
+ error = sys_setfib(NULL, &ua);
+ return rtems_bsd_error_to_status_and_errno(error);
* Packet routing routines.
@@ -2285,3 +2302,4 @@ rt_newaddrmsg_fib(int cmd, struct ifaddr *ifa, int error, struct rtentry *rt,
rt_addrmsg(cmd, ifa, fibnum);
diff --git a/freebsd/sys/sys/sysproto.h b/freebsd/sys/sys/sysproto.h
index a1ab7e44..1c1891de 100644
--- a/freebsd/sys/sys/sysproto.h
+++ b/freebsd/sys/sys/sysproto.h
@@ -2027,9 +2027,7 @@ int sys_rtprio(struct thread *, struct rtprio_args *);
int sys_semsys(struct thread *, struct semsys_args *);
int sys_msgsys(struct thread *, struct msgsys_args *);
int sys_shmsys(struct thread *, struct shmsys_args *);
-#endif /* __rtems__ */
int sys_setfib(struct thread *, struct setfib_args *);
-#ifndef __rtems__
int sys_ntp_adjtime(struct thread *, struct ntp_adjtime_args *);
int sys_setgid(struct thread *, struct setgid_args *);
int sys_setegid(struct thread *, struct setegid_args *);
diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
index 85f66912..a83334b5 100644
--- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
+++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
@@ -5872,7 +5872,6 @@
#define sys_select _bsd_sys_select
#define sys_sendmsg _bsd_sys_sendmsg
#define sys_sendto _bsd_sys_sendto
-#define sys_setfib _bsd_sys_setfib
#define sys_setsockopt _bsd_sys_setsockopt
#define sys_shutdown _bsd_sys_shutdown
#define sys_socket _bsd_sys_socket
diff --git a/rtemsbsd/rtems/rtems-bsd-syscall-api.c b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
index 76fc8ad7..1f659112 100644
--- a/rtemsbsd/rtems/rtems-bsd-syscall-api.c
+++ b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
@@ -644,20 +644,6 @@ sendmsg(int socket, const struct msghdr *message, int flags)
-int
-setfib(int fibnum)
- struct thread *td = rtems_bsd_get_curthread_or_null();
- int error;
- if (td != NULL) {
- struct setfib_args ua = { .fibnum = fibnum };
- error = sys_setfib(td, &ua);
- } else {
- error = ENOMEM;
- return rtems_bsd_error_to_status_and_errno(error);
int
setsockopt(int socket, int level, int option_name, const void *option_value,
socklen_t option_len)
2.35.3
