[libbsd 11/22] Add struct file wrapper
Sebastian Huber
Fri Jun 24 06:33:39 UTC 2022
Add a struct file wrapper in <rtems/bsd/sys/file.h> as an alternative to the
full FreeBSD struct file in <sys/file.h>. This allows using <sys/file.h> for
FreeBSD file systems (VFS) and the wrapper for other areas such as devfs,
cryptodev, sockets, kqueue, poll, and select which do not need the VFS support.
Update #4475.
rtemsbsd/include/rtems/bsd/sys/file.h | 248 +++++++++++++++++++++++++
rtemsbsd/rtems/rtems-kernel-get-file.c | 9 +-
2 files changed, 252 insertions(+), 5 deletions(-)
create mode 100644 rtemsbsd/include/rtems/bsd/sys/file.h
diff --git a/rtemsbsd/include/rtems/bsd/sys/file.h b/rtemsbsd/include/rtems/bsd/sys/file.h
new file mode 100644
index 00000000..04898677
--- /dev/null
+++ b/rtemsbsd/include/rtems/bsd/sys/file.h
@@ -0,0 +1,248 @@
+ * @file
+ * @ingroup rtems_bsd_rtems
+ * @brief This header file provides a alternative implementation for interfaces
+ * normally provided via <sys/file.h>.
+ * Copyright (C) 2013, 2022 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifndef _SYS_FILE_H_
+#define _SYS_FILE_H_
+#define _SYS_FILEDESC_H_
+#include <rtems/libio_.h>
+#include <sys/fcntl.h>
+#include <sys/refcount.h>
+#include <sys/seq.h>
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+struct filecaps;
+struct filedesc;
+struct ucred;
+extern const rtems_filesystem_file_handlers_r socketops;
+#define file rtems_libio_tt
+#define f_data pathinfo.node_access_2
+#define maxfiles rtems_libio_number_iops
+typedef int fo_kqfilter_t(struct file *, struct knote *);
+static inline void *
+rtems_bsd_loc_to_f_data(const rtems_filesystem_location_info_t *loc)
+ return loc->node_access_2;
+static inline uint32_t
+rtems_bsd_fflag_to_libio_flags(u_int fflag)
+ uint32_t libio_flags = 0;
+ if ((fflag & FREAD) == FREAD) {
+ libio_flags |= LIBIO_FLAGS_READ;
+ if ((fflag & FWRITE) == FWRITE) {
+ libio_flags |= LIBIO_FLAGS_WRITE;
+ if ((fflag & FNONBLOCK) == FNONBLOCK) {
+ libio_flags |= LIBIO_FLAGS_NO_DELAY;
+ return (libio_flags);
+static inline u_int
+rtems_bsd_libio_flags_to_fflag(uint32_t libio_flags)
+ u_int fflag = 0;
+ if ((libio_flags & LIBIO_FLAGS_READ) == LIBIO_FLAGS_READ) {
+ fflag |= FREAD;
+ if ((libio_flags & LIBIO_FLAGS_WRITE) == LIBIO_FLAGS_WRITE) {
+ fflag |= FWRITE;
+ if ((libio_flags & LIBIO_FLAGS_NO_DELAY) == LIBIO_FLAGS_NO_DELAY) {
+ fflag |= FNONBLOCK;
+ return (fflag);
+static int inline
+rtems_bsd_error_to_status_and_errno(int error)
+ if (error == 0) {
+ return 0;
+ } else {
+ rtems_set_errno_and_return_minus_one(error);
+struct file *rtems_bsd_get_file(int fd);
+static inline int
+rtems_bsd_do_fget(int fd, struct file **fpp)
+ struct file *fp;
+ fp = rtems_bsd_get_file(fd);
+ *fpp = fp;
+ return (fp != NULL ? 0 : EBADF);
+#undef fget
+#define fget(td, fd, rights, fpp) rtems_bsd_do_fget(fd, fpp)
+static inline void
+rtems_bsd_finit(struct file *fp, u_int fflag, void *data,
+ const rtems_filesystem_file_handlers_r *ops)
+ fp->f_data = data;
+ fp->pathinfo.handlers = ops;
+ rtems_libio_iop_flags_set(fp, LIBIO_FLAGS_OPEN |
+ rtems_bsd_fflag_to_libio_flags(fflag));
+#undef finit
+#define finit(fp, fflag, type, data, ops) rtems_bsd_finit(fp, fflag, data, ops)
+ * WARNING: fdalloc() and falloc_caps() do not increment the reference count of
+ * the file descriptor in contrast to FreeBSD. We must not call the fdrop()
+ * corresponding to a fdalloc() or falloc_caps(). The reason for this is that
+ * FreeBSD performs a lazy cleanup once the reference count reaches zero.
+ * RTEMS uses the reference count to determine if a cleanup is allowed.
+#define fdrop(fp, td) rtems_libio_iop_drop(fp)
+static inline int
+fo_ioctl(struct file *fp, u_long com, void *data, struct ucred *active_cred,
+ struct thread *td)
+ int rv;
+ (void)active_cred;
+ (void)td;
+ errno = 0;
+ rv = ((*fp->pathinfo.handlers->ioctl_h)(fp, com, data));
+ if (rv == 0) {
+ return (0);
+ } else {
+ return (errno);
+#define FILEDESC_XLOCK(fdp) rtems_libio_lock()
+#define FILEDESC_XUNLOCK(fdp) rtems_libio_unlock()
+#define FILEDESC_SLOCK(fdp) rtems_libio_lock()
+#define FILEDESC_SUNLOCK(fdp) rtems_libio_unlock()
+#undef filecaps_free
+#define filecaps_free(fcaps) do { } while (0)
+static inline int
+rtems_bsd_falloc(struct thread *td, struct file **resultfp, int *resultfd,
+ int flags)
+ rtems_libio_t *iop;
+ (void)td;
+ (void)flags;
+ iop = rtems_libio_allocate();
+ *resultfp = iop;
+ *resultfd = rtems_libio_iop_to_descriptor(iop);
+ if (iop != NULL) {
+ iop->pathinfo.mt_entry = &rtems_filesystem_null_mt_entry;
+ rtems_filesystem_location_add_to_mt_entry(&iop->pathinfo);
+ return (0);
+ } else {
+ return (ENFILE);
+#define falloc_caps(td, resultfp, resultfd, flags, fcaps) \
+ rtems_bsd_falloc(td, resultfp, resultfd, flags)
+#define falloc(td, resultfp, resultfd, flags) \
+static inline int
+rtems_bsd_fget_unlocked(struct filedesc *fdp, int fd, struct file **fpp,
+ seq_t *seqp)
+ struct file *fp;
+ (void)fdp;
+ (void)seqp;
+ *fpp = fp;
+#undef fget_unlocked
+#define fget_unlocked(fdp, fd, needrightsp, fpp, seqp) \
+ rtems_bsd_fget_unlocked(fdp, fd, fpp, seqp)
+ * WARNING: Use of fdrop() after fclose() corrupts the file descriptor. See
+ * fdrop() comment.
+static inline void
+fdclose(struct thread *td, struct file *fp, int idx)
+ (void)td;
+ (void)idx;
+ rtems_libio_free(fp);
+#ifdef __cplusplus
+#endif /* _SYS_FILE_H_ */
diff --git a/rtemsbsd/rtems/rtems-kernel-get-file.c b/rtemsbsd/rtems/rtems-kernel-get-file.c
index 143af6a2..2b4edef3 100644
--- a/rtemsbsd/rtems/rtems-kernel-get-file.c
+++ b/rtemsbsd/rtems/rtems-kernel-get-file.c
@@ -39,8 +39,7 @@
#include <machine/rtems-bsd-kernel-space.h>
-#include <sys/types.h>
-#include <sys/file.h>
+#include <rtems/bsd/sys/file.h>
struct file *
@@ -50,11 +49,11 @@ rtems_bsd_get_file(int fd)
if ((uint32_t) fd < rtems_libio_number_iops) {
unsigned int flags;
- fp = rtems_bsd_fd_to_fp(fd);
- flags = rtems_libio_iop_hold(&fp->f_io);
+ fp = &rtems_libio_iops[fd];
+ flags = rtems_libio_iop_hold(fp);
if ((flags & LIBIO_FLAGS_OPEN) == 0) {
- rtems_libio_iop_drop(&fp->f_io);
+ rtems_libio_iop_drop(fp);
fp = NULL;
} else {
2.35.3
