[libbsd 20/22] Remove unused rtems_bsd_sysgen_imfsnodeops
Sebastian Huber
Fri Jun 24 06:33:48 UTC 2022
Update #4475.
rtemsbsd/include/machine/rtems-bsd-libio.h | 11 ----
rtemsbsd/rtems/rtems-bsd-syscall-api.c | 64 ----------------------
2 files changed, 75 deletions(-)
diff --git a/rtemsbsd/include/machine/rtems-bsd-libio.h b/rtemsbsd/include/machine/rtems-bsd-libio.h
index 3c3a8bbb..6dd75394 100644
--- a/rtemsbsd/include/machine/rtems-bsd-libio.h
+++ b/rtemsbsd/include/machine/rtems-bsd-libio.h
@@ -50,7 +50,6 @@
struct rtems_bsd_vfs_loc;
extern const rtems_filesystem_file_handlers_r rtems_bsd_sysgen_nodeops;
-extern const rtems_filesystem_file_handlers_r rtems_bsd_sysgen_imfsnodeops;
extern const rtems_filesystem_file_handlers_r rtems_bsd_sysgen_dirops;
extern const rtems_filesystem_file_handlers_r rtems_bsd_sysgen_fileops;
@@ -93,16 +92,6 @@ rtems_bsd_libio_loc_to_iop(const rtems_filesystem_location_info_t *loc)
->node_access;
-struct socket;
-static inline struct socket *
-rtems_bsd_libio_imfs_loc_to_so(const rtems_filesystem_location_info_t *loc)
- return (struct socket *)RTEMS_DECONST(
- rtems_filesystem_location_info_t *, loc)
- ->node_access_2;
static struct vnode *
rtems_bsd_libio_loc_to_vnode(const rtems_filesystem_location_info_t *loc)
diff --git a/rtemsbsd/rtems/rtems-bsd-syscall-api.c b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
index 7caeecf8..fc554fad 100644
--- a/rtemsbsd/rtems/rtems-bsd-syscall-api.c
+++ b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
@@ -146,25 +146,6 @@ const rtems_filesystem_file_handlers_r rtems_bsd_sysgen_nodeops = {
.mmap_h = rtems_filesystem_default_mmap
-const rtems_filesystem_file_handlers_r rtems_bsd_sysgen_imfsnodeops = {
- .open_h = rtems_bsd_sysgen_open_error,
- .close_h = rtems_bsd_sysgen_close,
- .read_h = rtems_bsd_sysgen_read,
- .write_h = rtems_bsd_sysgen_write,
- .ioctl_h = rtems_bsd_sysgen_ioctl,
- .lseek_h = rtems_filesystem_default_lseek,
- .fstat_h = rtems_bsd_sysgen_imfsfstat,
- .ftruncate_h = rtems_filesystem_default_ftruncate,
- .fsync_h = rtems_filesystem_default_fsync_or_fdatasync,
- .fdatasync_h = rtems_filesystem_default_fsync_or_fdatasync,
- .fcntl_h = rtems_bsd_sysgen_fcntl,
- .poll_h = rtems_bsd_sysgen_poll,
- .kqfilter_h = rtems_bsd_sysgen_kqfilter,
- .readv_h = rtems_bsd_sysgen_readv,
- .writev_h = rtems_bsd_sysgen_writev,
- .mmap_h = rtems_filesystem_default_mmap
struct file *
rtems_bsd_iop_to_file(const rtems_libio_t *iop)
@@ -712,51 +693,6 @@ rtems_bsd_sysgen_fstat(
return rtems_bsd_error_to_status_and_errno(error);
-int
-rtems_bsd_sysgen_imfsfstat(
- const rtems_filesystem_location_info_t *loc, struct stat *buf)
- struct thread *td = curthread;
- struct socket *so = rtems_bsd_libio_imfs_loc_to_so(loc);
- struct file *fp = NULL;
- int error;
- int fd;
- if (RTEMS_BSD_SYSCALL_TRACE) {
- printf("bsd: sys: imfsfstat: socket=%p\n", so);
- if (td == NULL) {
- printf("bsd: sys: fstat: no curthread\n");
- return rtems_bsd_error_to_status_and_errno(ENOMEM);
- rtems_libio_lock();
- for (fd = 0; fd < (int)rtems_libio_number_iops; ++fd) {
- rtems_libio_t *iop;
- iop = rtems_libio_iop(fd);
- if (iop->pathinfo.handlers == NULL) {
- continue;
- fp = rtems_bsd_iop_to_file(iop);
- if (fp != NULL && fp->f_data == so) {
- break;
- fp = NULL;
- rtems_libio_unlock();
- if (fp != NULL) {
- printf("bsd: sys: imfsfstat: %d\n", fd);
- error = fo_stat(fp, buf, NULL, td);
- } else {
- error = EBADF;
- return rtems_bsd_error_to_status_and_errno(error);
int
rtems_bsd_sysgen_ftruncate(rtems_libio_t *iop, off_t length)
2.35.3
