[libbsd 14/22] Move select(), pselect(), and poll(), avoid VFS
Fri Jun 24 06:33:42 UTC 2022
Collecting all system calls in a single translation unit is not good due to the
library initialization through linker sets.
Partly revert commit 6514d561587fd1527fe6a26cb43e6b5742c8c779 in
"freebsd/sys/kern/sys_generic.c".  The goal is to use USB, network, PCI, and
NVMe support without the VFS to reduce the memory and runtime overhead
introduced by VFS.
Avoid the VFS by providing a weak bwillwrite() implementation.
Update #4475.
 freebsd/sys/kern/sys_generic.c                | 111 +++++++++++++++++-
 freebsd/sys/sys/sysproto.h                    |   4 +-
 .../machine/rtems-bsd-kernel-namespace.h      |   3 -
 rtemsbsd/rtems/rtems-bsd-syscall-api.c        |  86 --------------
 4 files changed, 108 insertions(+), 96 deletions(-)
diff --git a/freebsd/sys/kern/sys_generic.c b/freebsd/sys/kern/sys_generic.c
index 1e5351a7..1c3bb714 100644
--- a/freebsd/sys/kern/sys_generic.c
+++ b/freebsd/sys/kern/sys_generic.c
@@ -77,6 +77,19 @@ __FBSDID("$FreeBSD$");
 #endif
 #include <security/audit/audit.h>
+#ifdef __rtems__
+#include <machine/rtems-bsd-syscall-api.h>
+static int kern_select(struct thread *, int, fd_set *, fd_set *,
+    fd_set *, struct timeval *, int);
+__weak_symbol void
+bwillwrite(void)
+	/* Do not pull in the VFS support only through this translation unit */
+#endif /* __rtems__ */
  * The following macro defines how many bytes will be allocated from
@@ -259,7 +272,6 @@ freebsd6_pread(struct thread *td, struct freebsd6_pread_args *uap)
 	return (kern_pread(td, uap->fd, uap->buf, uap->nbyte, uap->offset));
 #endif
-#endif /* __rtems__ */
  * Scatter read system call.
@@ -284,6 +296,7 @@ sys_readv(struct thread *td, struct readv_args *uap)
 	free(auio, M_IOV);
 	return (error);
 int
 kern_readv(struct thread *td, int fd, struct uio *auio)
@@ -465,7 +478,6 @@ freebsd6_pwrite(struct thread *td, struct freebsd6_pwrite_args *uap)
 	return (kern_pwrite(td, uap->fd, uap->buf, uap->nbyte, uap->offset));
 #endif
  * Gather write system call.
@@ -490,6 +502,7 @@ sys_writev(struct thread *td, struct writev_args *uap)
 	free(auio, M_IOV);
 	return (error);
 int
 kern_writev(struct thread *td, int fd, struct uio *auio)
@@ -865,6 +878,7 @@ poll_no_poll(int events)
 	return (events & (POLLIN | POLLOUT | POLLRDNORM | POLLWRNORM));
+#ifndef __rtems__
 int
 sys_pselect(struct thread *td, struct pselect_args *uap)
@@ -898,7 +912,6 @@ kern_pselect(struct thread *td, int nd, fd_set *in, fd_set *ou, fd_set *ex,
 	int error;
-#ifndef __rtems__
 	if (uset != NULL) {
 		error = kern_sigprocmask(td, SIG_SETMASK, uset,
 		    &td->td_oldsigmask, 0);
@@ -914,7 +927,6 @@ kern_pselect(struct thread *td, int nd, fd_set *in, fd_set *ou, fd_set *ex,
 		td->td_flags |= TDF_ASTPENDING;
 		thread_unlock(td);
 	error = kern_select(td, nd, in, ou, ex, tvp, abi_nfdbits);
 	return (error);
@@ -943,6 +955,7 @@ sys_select(struct thread *td, struct select_args *uap)
 	return (kern_select(td, uap->nd, uap->in, uap->ou, uap->ex, tvp,
 	    NFDBITS));
  * In the unlikely case when user specified n greater then the last
@@ -1171,6 +1184,65 @@ done:
 	return (error);
+#ifdef __rtems__
+int
+select(int nfds, fd_set *readfds, fd_set *writefds, fd_set *errorfds,
+    struct timeval *timeout)
+	struct thread *td = rtems_bsd_get_curthread_or_null();
+	int error;
+	if (td != NULL) {
+		error = kern_select(td, nfds, readfds, writefds, errorfds,
+		    timeout, NFDBITS);
+	} else {
+		error = ENOMEM;
+	if (error == 0) {
+		return td->td_retval[0];
+	} else {
+		rtems_set_errno_and_return_minus_one(error);
+int
+pselect(int nfds, fd_set *readfds, fd_set *writefds, fd_set *errorfds,
+    const struct timespec *timeout, const sigset_t *set)
+	struct thread *td;
+	int error;
+	if (set != NULL) {
+		rtems_set_errno_and_return_minus_one(ENOSYS);
+	td = rtems_bsd_get_curthread_or_null();
+	if (td != NULL) {
+		struct timeval tv;
+		struct timeval *tvp;
+		if (timeout != NULL) {
+			TIMESPEC_TO_TIMEVAL(&tv, timeout);
+			tvp = &tv;
+		} else {
+			tvp = NULL;
+		    tvp, NFDBITS);
+	} else {
+		error = ENOMEM;
+	if (error == 0) {
+	} else {
  * Convert a select bit set to poll flags.
@@ -1404,6 +1476,12 @@ selscan(struct thread *td, fd_mask **ibits, fd_mask **obits, int nfd)
 	return (0);
+#ifdef __rtems__
+static int kern_poll(struct thread *td, struct pollfd *fds, u_int nfds,
+    struct timespec *tsp, sigset_t *uset);
+static
 int
 sys_poll(struct thread *td, struct poll_args *uap)
@@ -1522,6 +1600,31 @@ out:
 		free(bits, M_TEMP);
 	return (error);
+#ifdef __rtems__
+int
+poll(struct pollfd fds[], nfds_t nfds, int timeout)
+	struct poll_args ua = {
+		.fds = &fds[0],
+		.nfds = nfds,
+		.timeout = timeout
+	int error;
+	if (td != NULL) {
+		error = sys_poll(td, &ua);
+	} else {
+		error = ENOMEM;
+	if (error == 0) {
+	} else {
 #ifndef __rtems__
 int
diff --git a/freebsd/sys/sys/sysproto.h b/freebsd/sys/sys/sysproto.h
index 8e915185..8d72d52b 100644
--- a/freebsd/sys/sys/sysproto.h
+++ b/freebsd/sys/sys/sysproto.h
@@ -1975,8 +1975,8 @@ int	sys_getitimer(struct thread *, struct getitimer_args *);
 int	sys_getdtablesize(struct thread *, struct getdtablesize_args *);
 int	sys_dup2(struct thread *, struct dup2_args *);
 int	sys_fcntl(struct thread *, struct fcntl_args *);
 int	sys_select(struct thread *, struct select_args *);
 int	sys_fsync(struct thread *, struct fsync_args *);
 #ifndef __rtems__
 int	sys_setpriority(struct thread *, struct setpriority_args *);
@@ -2042,9 +2042,7 @@ int	sys_munlock(struct thread *, struct munlock_args *);
 int	sys_undelete(struct thread *, struct undelete_args *);
 int	sys_futimes(struct thread *, struct futimes_args *);
 int	sys_getpgid(struct thread *, struct getpgid_args *);
 int	sys_poll(struct thread *, struct poll_args *);
-#ifndef __rtems__
 int	sys_semget(struct thread *, struct semget_args *);
 int	sys_semop(struct thread *, struct semop_args *);
 int	sys_msgget(struct thread *, struct msgget_args *);
diff --git a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
index dc19c7c2..6f28fea4 100644
--- a/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
+++ b/rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h
@@ -5840,8 +5840,6 @@
 #define	sys_open _bsd_sys_open
 #define	sys_openat _bsd_sys_openat
 #define	sys_pipe2 _bsd_sys_pipe2
-#define	sys_poll _bsd_sys_poll
-#define	sys_pselect _bsd_sys_pselect
 #define	sys_read _bsd_sys_read
 #define	sys_readlink _bsd_sys_readlink
 #define	sys_readlinkat _bsd_sys_readlinkat
@@ -5851,7 +5849,6 @@
 #define	sys_rename _bsd_sys_rename
 #define	sys_renameat _bsd_sys_renameat
 #define	sys_rmdir _bsd_sys_rmdir
-#define	sys_select _bsd_sys_select
 #define	sys_sendmsg _bsd_sys_sendmsg
 #define	sys_sendto _bsd_sys_sendto
 #define	sys_setsockopt _bsd_sys_setsockopt
diff --git a/rtemsbsd/rtems/rtems-bsd-syscall-api.c b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
index 8a60afc1..0ab85bbf 100644
--- a/rtemsbsd/rtems/rtems-bsd-syscall-api.c
+++ b/rtemsbsd/rtems/rtems-bsd-syscall-api.c
@@ -401,68 +401,6 @@ listen(int socket, int backlog)
 	return rtems_bsd_error_to_status_and_errno(error);
-int
-poll(struct pollfd fds[], nfds_t nfds, int timeout)
-	struct thread *td = rtems_bsd_get_curthread_or_null();
-	struct poll_args ua;
-	int error;
-	if (RTEMS_BSD_SYSCALL_TRACE) {
-		printf("bsd: sys: poll: %d\n", nfds);
-	if (td == NULL) {
-		return rtems_bsd_error_to_status_and_errno(ENOMEM);
-	 * Pass libio descriptors through as libio and bsd descriptors
-	 * can be in the list at the same time.
-	ua.fds = &fds[0];
-	ua.nfds = nfds;
-	ua.timeout = timeout;
-	error = sys_poll(td, &ua);
-	if (error != 0) {
-		return rtems_bsd_error_to_status_and_errno(error);
-	return td->td_retval[0];
-int
-pselect(int nfds, fd_set *readfds, fd_set *writefds, fd_set *errorfds,
-    const struct timespec *timeout, const sigset_t *set)
-	struct thread *td;
-	struct timeval tv;
-	struct timeval *tvp;
-	int error;
-		printf("bsd: sys: pselect: %d\n", nfds);
-	if (set != NULL) {
-		return rtems_bsd_error_to_status_and_errno(ENOSYS);
-	td = rtems_bsd_get_curthread_or_null();
-	if (td == NULL) {
-	if (timeout != NULL) {
-		TIMESPEC_TO_TIMEVAL(&tv, timeout);
-		tvp = &tv;
-	} else {
-		tvp = NULL;
-	error = kern_select(
-	    td, nfds, readfds, writefds, errorfds, tvp, NFDBITS);
-	if (error != 0) {
 ssize_t
 recvfrom(int socket, void *__restrict buffer, size_t length, int flags,
     struct sockaddr *__restrict address, socklen_t *__restrict address_len)
@@ -511,30 +449,6 @@ recvmsg(int socket, struct msghdr *message, int flags)
-int
-select(int nfds, fd_set *readfds, fd_set *writefds, fd_set *errorfds,
-    struct timeval *timeout)
-	int error;
-		printf("bsd: sys: select: %d\n", nfds);
-	if (td == NULL) {
-	    td, nfds, readfds, writefds, errorfds, timeout, NFDBITS);
-	if (error != 0) {
 ssize_t
 sendto(int socket, const void *message, size_t length, int flags,
     const struct sockaddr *dest_addr, socklen_t dest_len)
2.35.3
