[PATCH] Proposal for new GPIO API and example implementation for STM32F4 BSP
    Karel Gardas
    karel at functional.vision
    Sat Jun 25 19:46:39 UTC 2022
Hello Duc,
one reminder, your API should be more or less portable. That means the
example which you produce as a testing example should be API-wise
portable between various BSPs. Is that clear?
I know, I know, sometimes user led 1 on F4 is on different port/pin on
F7 and then on H7 you get it on even different port/pin, but!
 > stm32f4_gpio_get_ctrl(GPIOD, &ctrl);
do you expect this to be called from app running on RPi4 for example? Or
on beagle bone white? Or on stm32h757i-eval board?
Please generalize and make that bit portable too.
Thanks,
Karel
On 6/25/22 15:00, Duc Doan wrote:
> Hello Christian,
> I forgot to send the sample code. Here it a code to turn on an LED:
> // Obtain the pointer to the instance (port D)
> rtems_gpio_ctrl_t *ctrl;
> // enable clocks for port D
> rtems_gpio_initialize(ctrl);
> // configure the pin
> rtems_gpio_set_pin_mode(ctrl, &LED_PIN, RTEMS_GPIO_PINMODE_OUTPUT_PP);
> rtems_gpio_set_pull(ctrl, &LED_PIN, RTEMS_GPIO_PULLUP);
> // output to LED
> rtems_gpio_write(ctrl, &LED_PIN, RTEMS_GPIO_PIN_SET);
> Best,
> Duc Doan
> devel mailing list
> devel at rtems.org
