[PATCH] Proposal for new GPIO API and example implementation for STM32F4 BSP
oss at c-mauderer.de oss at c-mauderer.de
Sun Jun 26 08:02:59 UTC 2022
Hello Karel and Duc,
Am 26.06.22 um 09:24 schrieb Duc Doan:
> Hello Karel,
> I came up with this solution: making a macro that returns a function
> depending on driver/BSP name.
>    * @brief Get an GPIO control object.
>    * This macro requires BSPs/drivers to correctly implement
>    * function <driver_name>_gpio_get_ctrl(void *arg,
>    * rtems_gpio_ctrl_t **out).
>    * @param _driver is the name of the BSP/GPIO driver
>    * @param[in] _arg is the void pointer to an argument type
>    *        defined by BSP/driver
>    * @param[out] _out is the pointer to the pointer to where
>    *             the output object will be stored
> #define rtems_gpio_get_ctrl(_driver, _arg, _out) \
>      _driver##_gpio_get_ctrl( _arg , _out )
> In the application code:
> rtems_gpio_get_ctrl(stm32f4, GPIOD, &led_ctrl);
> rtems_gpio_get_ctrl(stm32f4, GPIOA, &button_ctrl);
It's only a different method of writing the same. It won't solve Karels
problem because it still wouldn't compile on another BSP.
> What do you think about this?
> Best,
> Duc Doan
> On Sat, 2022-06-25 at 21:46 +0200, Karel Gardas wrote:
>> Hello Duc,
>> one reminder, your API should be more or less portable. That means
>> the
>> example which you produce as a testing example should be API-wise
>> portable between various BSPs. Is that clear?
>> I know, I know, sometimes user led 1 on F4 is on different port/pin
>> on
>> F7 and then on H7 you get it on even different port/pin, but!
>>   > stm32f4_gpio_get_ctrl(GPIOD, &ctrl);
>> do you expect this to be called from app running on RPi4 for example?
>> Or
>> on beagle bone white? Or on stm32h757i-eval board?
>> Please generalize and make that bit portable too.
I think that approach is due to my suggestion to have a low overhead and
use the pointers more or less directly. A really portable method would
be to use for example device files. But for GPIO that would add a lot of
overhead which isn't good for a fast interface like that.
Another problem that I added for Duc is that I told that I might want to
register I2C GPIO expanders during the application startup.
A possibility could be to have some general bsp_gpio_get_ctrl(...)
function that returns the controllers for the integrated GPIOs of a chip
regardless of the chip. If you have an extra I2C expander, that will be
a separate function.
Best regards
Christian
>> Thanks,
>> Karel
>> On 6/25/22 15:00, Duc Doan wrote:
>>> Hello Christian,
>>> I forgot to send the sample code. Here it a code to turn on an LED:
>>> // Obtain the pointer to the instance (port D)
>>> rtems_gpio_ctrl_t *ctrl;
>>> // enable clocks for port D
>>> rtems_gpio_initialize(ctrl);
>>> // configure the pin
>>> rtems_gpio_set_pin_mode(ctrl, &LED_PIN,
>>> RTEMS_GPIO_PINMODE_OUTPUT_PP);
>>> rtems_gpio_set_pull(ctrl, &LED_PIN, RTEMS_GPIO_PULLUP);
>>> // output to LED
>>> rtems_gpio_write(ctrl, &LED_PIN, RTEMS_GPIO_PIN_SET);
>>> Best,
>>> Duc Doan
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
