[PATCH 01/13] bsps/arm/shared: Change license to BSD-2
Mon Jun 27 13:53:20 UTC 2022
    Updates #3053.
 bsps/arm/shared/cache/cache-cp15.c            | 25 ++++++++++++++++---
 bsps/arm/shared/cache/cache-cp15.h            | 25 ++++++++++++++++---
 bsps/arm/shared/cache/cache-v7m.c             | 25 ++++++++++++++++---
 bsps/arm/shared/clock/clock-a9mpcore.c        | 25 ++++++++++++++++---
 bsps/arm/shared/clock/clock-nxp-lpc.c         | 25 ++++++++++++++++---
 .../cp15/arm-cp15-set-exception-handler.c     | 25 ++++++++++++++++---
 .../shared/cp15/arm-cp15-set-ttb-entries.c    | 25 ++++++++++++++++---
 .../arm/shared/cpucounter/cpucounter-armv7m.c | 25 ++++++++++++++++---
 bsps/arm/shared/fb/arm-pl111.c                | 25 ++++++++++++++++---
 bsps/arm/shared/serial/arm-pl050.c            | 25 ++++++++++++++++---
 bsps/arm/shared/start/arm-a9mpcore-smp.c      | 25 ++++++++++++++++---
 bsps/arm/shared/start/bsp-start-memcpy.S      | 25 ++++++++++++++++---
 bsps/arm/shared/start/bspreset-armv7m.c       | 25 ++++++++++++++++---
 13 files changed, 286 insertions(+), 39 deletions(-)
diff --git a/bsps/arm/shared/cache/cache-cp15.c b/bsps/arm/shared/cache/cache-cp15.c
index 9a58146277..4ad9965529 100644
--- a/bsps/arm/shared/cache/cache-cp15.c
+++ b/bsps/arm/shared/cache/cache-cp15.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (C) 2009, 2018 embedded brains GmbH
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <libcpu/arm-cp15.h>
diff --git a/bsps/arm/shared/cache/cache-cp15.h b/bsps/arm/shared/cache/cache-cp15.h
index 8d2d2c9fe2..0e1297a84d 100644
--- a/bsps/arm/shared/cache/cache-cp15.h
+++ b/bsps/arm/shared/cache/cache-cp15.h
@@ -1,3 +1,5 @@
  * @ingroup RTEMSBSPsARMShared
@@ -9,9 +11,26 @@
  * Copyright (c) 2014 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef LIBBSP_ARM_SHARED_CACHE_L1_H
diff --git a/bsps/arm/shared/cache/cache-v7m.c b/bsps/arm/shared/cache/cache-v7m.c
index f5a9e208e5..ee68e7f9db 100644
--- a/bsps/arm/shared/cache/cache-v7m.c
+++ b/bsps/arm/shared/cache/cache-v7m.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/bsps/arm/shared/clock/clock-a9mpcore.c b/bsps/arm/shared/clock/clock-a9mpcore.c
index b3dc30eab4..d4c374d4e2 100644
--- a/bsps/arm/shared/clock/clock-a9mpcore.c
+++ b/bsps/arm/shared/clock/clock-a9mpcore.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2013, 2016 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/shared/clock/clock-nxp-lpc.c b/bsps/arm/shared/clock/clock-nxp-lpc.c
index 4ba5f83907..1490699ec5 100644
--- a/bsps/arm/shared/clock/clock-nxp-lpc.c
+++ b/bsps/arm/shared/clock/clock-nxp-lpc.c
@@ -1,3 +1,5 @@
  * @file
@@ -9,9 +11,26 @@
  * Copyright (c) 2009-2015 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c b/bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
index 5d478f2054..f15ed02612 100644
--- a/bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
+++ b/bsps/arm/shared/cp15/arm-cp15-set-exception-handler.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2013 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c b/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
index b09f18d8bf..db00fd6c26 100644
--- a/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
+++ b/bsps/arm/shared/cp15/arm-cp15-set-ttb-entries.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2010-2019 embedded brains GmbH.  All rights reserved.
+ * are met:
diff --git a/bsps/arm/shared/cpucounter/cpucounter-armv7m.c b/bsps/arm/shared/cpucounter/cpucounter-armv7m.c
index c4281594a1..3bdf90c29f 100644
--- a/bsps/arm/shared/cpucounter/cpucounter-armv7m.c
+++ b/bsps/arm/shared/cpucounter/cpucounter-armv7m.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2016, 2018 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <bsp/clock-armv7m.h>
diff --git a/bsps/arm/shared/fb/arm-pl111.c b/bsps/arm/shared/fb/arm-pl111.c
index 7d57efb47f..00779971b0 100644
--- a/bsps/arm/shared/fb/arm-pl111.c
+++ b/bsps/arm/shared/fb/arm-pl111.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/bsps/arm/shared/serial/arm-pl050.c b/bsps/arm/shared/serial/arm-pl050.c
index 954db691c5..0a4e9493b4 100644
--- a/bsps/arm/shared/serial/arm-pl050.c
+++ b/bsps/arm/shared/serial/arm-pl050.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2013-2014 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <assert.h>
diff --git a/bsps/arm/shared/start/arm-a9mpcore-smp.c b/bsps/arm/shared/start/arm-a9mpcore-smp.c
index a9970b952c..c30e099a84 100644
--- a/bsps/arm/shared/start/arm-a9mpcore-smp.c
+++ b/bsps/arm/shared/start/arm-a9mpcore-smp.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2013, 2018 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <rtems/score/smpimpl.h>
diff --git a/bsps/arm/shared/start/bsp-start-memcpy.S b/bsps/arm/shared/start/bsp-start-memcpy.S
index 8a7632821c..b20324c4d4 100644
--- a/bsps/arm/shared/start/bsp-start-memcpy.S
+++ b/bsps/arm/shared/start/bsp-start-memcpy.S
@@ -1,3 +1,5 @@
  * @file
@@ -7,9 +9,26 @@
  * Copyright (c) 2008-2011 embedded brains GmbH.  All rights reserved.
+ * are met:
 #include <rtems/asm.h>
diff --git a/bsps/arm/shared/start/bspreset-armv7m.c b/bsps/arm/shared/start/bspreset-armv7m.c
index 3afc0b6b69..c5e348b6fa 100644
--- a/bsps/arm/shared/start/bspreset-armv7m.c
+++ b/bsps/arm/shared/start/bspreset-armv7m.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+ * are met:
