[PATCH 03/13] bsps/arm/atsamv: Change license to BSD-2
Mon Jun 27 13:53:22 UTC 2022
    Updates #3053.
 bsps/arm/atsam/clock/systick-freq.c           | 25 ++++++++++++++++---
 bsps/arm/atsam/console/console.c              | 25 ++++++++++++++++---
 bsps/arm/atsam/console/debug-console.c        | 25 ++++++++++++++++---
 bsps/arm/atsam/i2c/atsam_i2c_bus.c            | 25 ++++++++++++++++---
 bsps/arm/atsam/i2c/atsam_i2c_init.c           | 25 ++++++++++++++++---
 bsps/arm/atsam/include/bsp.h                  | 25 ++++++++++++++++---
 .../atsam/include/bsp/atsam-clock-config.h    | 25 ++++++++++++++++---
 bsps/arm/atsam/include/bsp/atsam-i2c.h        | 25 ++++++++++++++++---
 bsps/arm/atsam/include/bsp/atsam-spi.h        | 25 ++++++++++++++++---
 bsps/arm/atsam/include/bsp/i2c.h              | 25 ++++++++++++++++---
 bsps/arm/atsam/include/bsp/iocopy.h           | 25 ++++++++++++++++---
 bsps/arm/atsam/include/bsp/irq.h              | 25 ++++++++++++++++---
 bsps/arm/atsam/include/bsp/pin-config.h       | 25 ++++++++++++++++---
 bsps/arm/atsam/include/bsp/power.h            | 25 ++++++++++++++++---
 bsps/arm/atsam/include/bsp/sc16is752.h        | 25 ++++++++++++++++---
 bsps/arm/atsam/include/bsp/spi.h              | 25 ++++++++++++++++---
 bsps/arm/atsam/rtc/rtc-config.c               | 25 ++++++++++++++++---
 bsps/arm/atsam/spi/atsam_spi_init.c           | 25 ++++++++++++++++---
 bsps/arm/atsam/spi/sc16is752.c                | 25 ++++++++++++++++---
 bsps/arm/atsam/start/bspstart.c               | 25 ++++++++++++++++---
 bsps/arm/atsam/start/bspstarthooks.c          | 25 ++++++++++++++++---
 bsps/arm/atsam/start/getentropy-trng.c        | 25 ++++++++++++++++---
 bsps/arm/atsam/start/iocopy.c                 | 25 ++++++++++++++++---
 bsps/arm/atsam/start/pin-config.c             | 25 ++++++++++++++++---
 bsps/arm/atsam/start/pmc-config.c             | 25 ++++++++++++++++---
 bsps/arm/atsam/start/power-clock.c            | 25 ++++++++++++++++---
 bsps/arm/atsam/start/power-rtc.c              | 25 ++++++++++++++++---
 bsps/arm/atsam/start/power.c                  | 25 ++++++++++++++++---
 bsps/arm/atsam/start/restart.c                | 25 ++++++++++++++++---
 bsps/arm/atsam/start/sdram-config.c           | 25 ++++++++++++++++---
 30 files changed, 660 insertions(+), 90 deletions(-)
diff --git a/bsps/arm/atsam/clock/systick-freq.c b/bsps/arm/atsam/clock/systick-freq.c
index f89c66419f..87f6c2df59 100644
--- a/bsps/arm/atsam/clock/systick-freq.c
+++ b/bsps/arm/atsam/clock/systick-freq.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2016 embedded brains GmbH.  All rights reserved.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/atsam/console/console.c b/bsps/arm/atsam/console/console.c
index 7ed41d84b3..189c42e47d 100644
--- a/bsps/arm/atsam/console/console.c
+++ b/bsps/arm/atsam/console/console.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/atsam/console/debug-console.c b/bsps/arm/atsam/console/debug-console.c
index 6501dd571b..f20b35eff7 100644
--- a/bsps/arm/atsam/console/debug-console.c
+++ b/bsps/arm/atsam/console/debug-console.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <rtems/bspIo.h>
diff --git a/bsps/arm/atsam/i2c/atsam_i2c_bus.c b/bsps/arm/atsam/i2c/atsam_i2c_bus.c
index 43f55ec93e..7b77ba70cd 100644
--- a/bsps/arm/atsam/i2c/atsam_i2c_bus.c
+++ b/bsps/arm/atsam/i2c/atsam_i2c_bus.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp/atsam-clock-config.h>
diff --git a/bsps/arm/atsam/i2c/atsam_i2c_init.c b/bsps/arm/atsam/i2c/atsam_i2c_init.c
index 967caab122..80e0cf2b56 100644
--- a/bsps/arm/atsam/i2c/atsam_i2c_init.c
+++ b/bsps/arm/atsam/i2c/atsam_i2c_init.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp/atsam-i2c.h>
diff --git a/bsps/arm/atsam/include/bsp.h b/bsps/arm/atsam/include/bsp.h
index 26b675980a..8fe98be364 100644
--- a/bsps/arm/atsam/include/bsp.h
+++ b/bsps/arm/atsam/include/bsp.h
@@ -1,3 +1,5 @@
  * @file
@@ -7,9 +9,26 @@
+ * are met:
 #ifndef LIBBSP_ARM_ATSAM_BSP_H
diff --git a/bsps/arm/atsam/include/bsp/atsam-clock-config.h b/bsps/arm/atsam/include/bsp/atsam-clock-config.h
index 2e9309631d..25addc1b42 100644
--- a/bsps/arm/atsam/include/bsp/atsam-clock-config.h
+++ b/bsps/arm/atsam/include/bsp/atsam-clock-config.h
@@ -1,9 +1,28 @@
  * Copyright (c) 2017 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef ATSAM_CLOCK_CONFIG_H
diff --git a/bsps/arm/atsam/include/bsp/atsam-i2c.h b/bsps/arm/atsam/include/bsp/atsam-i2c.h
index 28cd59c6d0..980872e26d 100644
--- a/bsps/arm/atsam/include/bsp/atsam-i2c.h
+++ b/bsps/arm/atsam/include/bsp/atsam-i2c.h
@@ -1,9 +1,28 @@
+ * are met:
 #ifndef LIBBSP_ARM_ATSAM_ATSAM_I2C_H
diff --git a/bsps/arm/atsam/include/bsp/atsam-spi.h b/bsps/arm/atsam/include/bsp/atsam-spi.h
index 5086405529..795cf3eb47 100644
--- a/bsps/arm/atsam/include/bsp/atsam-spi.h
+++ b/bsps/arm/atsam/include/bsp/atsam-spi.h
@@ -1,9 +1,28 @@
+ * are met:
 #ifndef LIBBSP_ARM_ATSAM_ATSAM_SPI_H
diff --git a/bsps/arm/atsam/include/bsp/i2c.h b/bsps/arm/atsam/include/bsp/i2c.h
index 868fb708f7..19eeb60ac0 100644
--- a/bsps/arm/atsam/include/bsp/i2c.h
+++ b/bsps/arm/atsam/include/bsp/i2c.h
@@ -1,9 +1,28 @@
+ * are met:
 #ifndef LIBBSP_ARM_ATSAM_I2C_H
diff --git a/bsps/arm/atsam/include/bsp/iocopy.h b/bsps/arm/atsam/include/bsp/iocopy.h
index 1e77613c43..5e57529f9d 100644
--- a/bsps/arm/atsam/include/bsp/iocopy.h
+++ b/bsps/arm/atsam/include/bsp/iocopy.h
@@ -1,9 +1,28 @@
  * Copyright (c) 2018 embedded brains GmbH.  All rights reserved.
+ * are met:
 #ifndef ATSAM_IOCOPY_H
diff --git a/bsps/arm/atsam/include/bsp/irq.h b/bsps/arm/atsam/include/bsp/irq.h
index d966002adb..473f172b38 100644
--- a/bsps/arm/atsam/include/bsp/irq.h
+++ b/bsps/arm/atsam/include/bsp/irq.h
@@ -1,9 +1,28 @@
+ * are met:
 #ifndef LIBBSP_ARM_ATSAM_ESV_70_IRQ_H
diff --git a/bsps/arm/atsam/include/bsp/pin-config.h b/bsps/arm/atsam/include/bsp/pin-config.h
index 7bab3a91cc..0412e0d5e8 100644
--- a/bsps/arm/atsam/include/bsp/pin-config.h
+++ b/bsps/arm/atsam/include/bsp/pin-config.h
@@ -1,9 +1,28 @@
+ * are met:
 #ifndef LIBBSP_ARM_ATSAM_PIN_CONFIG_H
diff --git a/bsps/arm/atsam/include/bsp/power.h b/bsps/arm/atsam/include/bsp/power.h
index e26644aee3..bf8259ee2b 100644
--- a/bsps/arm/atsam/include/bsp/power.h
+++ b/bsps/arm/atsam/include/bsp/power.h
@@ -1,9 +1,28 @@
+ * are met:
 #ifndef LIBBSP_ARM_ATSAM_POWER_H
diff --git a/bsps/arm/atsam/include/bsp/sc16is752.h b/bsps/arm/atsam/include/bsp/sc16is752.h
index 2846f61a2f..934b410885 100644
--- a/bsps/arm/atsam/include/bsp/sc16is752.h
+++ b/bsps/arm/atsam/include/bsp/sc16is752.h
@@ -1,9 +1,28 @@
+ * are met:
 #ifndef LIBBSP_ARM_ATSAM_SC16IS752_H
diff --git a/bsps/arm/atsam/include/bsp/spi.h b/bsps/arm/atsam/include/bsp/spi.h
index b1ba82ac1b..99063bde4c 100644
--- a/bsps/arm/atsam/include/bsp/spi.h
+++ b/bsps/arm/atsam/include/bsp/spi.h
@@ -1,9 +1,28 @@
+ * are met:
 #ifndef LIBBSP_ARM_ATSAM_SPI_H
diff --git a/bsps/arm/atsam/rtc/rtc-config.c b/bsps/arm/atsam/rtc/rtc-config.c
index 62d03b9631..0e908885c7 100644
--- a/bsps/arm/atsam/rtc/rtc-config.c
+++ b/bsps/arm/atsam/rtc/rtc-config.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <libchip/chip.h>
diff --git a/bsps/arm/atsam/spi/atsam_spi_init.c b/bsps/arm/atsam/spi/atsam_spi_init.c
index ec9e7c488f..665e93b829 100644
--- a/bsps/arm/atsam/spi/atsam_spi_init.c
+++ b/bsps/arm/atsam/spi/atsam_spi_init.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp/atsam-spi.h>
diff --git a/bsps/arm/atsam/spi/sc16is752.c b/bsps/arm/atsam/spi/sc16is752.c
index d53861264b..0bfbc57a13 100644
--- a/bsps/arm/atsam/spi/sc16is752.c
+++ b/bsps/arm/atsam/spi/sc16is752.c
@@ -1,10 +1,29 @@
+ * are met:
 #include <bsp/sc16is752.h>
diff --git a/bsps/arm/atsam/start/bspstart.c b/bsps/arm/atsam/start/bspstart.c
index 8876e4a030..3c726eebaa 100644
--- a/bsps/arm/atsam/start/bspstart.c
+++ b/bsps/arm/atsam/start/bspstart.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/atsam/start/bspstarthooks.c b/bsps/arm/atsam/start/bspstarthooks.c
index bf9b62a303..516b86228d 100644
--- a/bsps/arm/atsam/start/bspstarthooks.c
+++ b/bsps/arm/atsam/start/bspstarthooks.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2016 embedded brains GmbH Huber.  All rights reserved.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/atsam/start/getentropy-trng.c b/bsps/arm/atsam/start/getentropy-trng.c
index ed65f3cd89..ccc47d645b 100644
--- a/bsps/arm/atsam/start/getentropy-trng.c
+++ b/bsps/arm/atsam/start/getentropy-trng.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/bsps/arm/atsam/start/iocopy.c b/bsps/arm/atsam/start/iocopy.c
index 53ef606cd9..e01d75e047 100644
--- a/bsps/arm/atsam/start/iocopy.c
+++ b/bsps/arm/atsam/start/iocopy.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp/iocopy.h>
diff --git a/bsps/arm/atsam/start/pin-config.c b/bsps/arm/atsam/start/pin-config.c
index 3c7f3965a2..a57f53e76a 100644
--- a/bsps/arm/atsam/start/pin-config.c
+++ b/bsps/arm/atsam/start/pin-config.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp/pin-config.h>
diff --git a/bsps/arm/atsam/start/pmc-config.c b/bsps/arm/atsam/start/pmc-config.c
index 5945f39e98..110b3c857d 100644
--- a/bsps/arm/atsam/start/pmc-config.c
+++ b/bsps/arm/atsam/start/pmc-config.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/bsps/arm/atsam/start/power-clock.c b/bsps/arm/atsam/start/power-clock.c
index 0ab000cba9..70fe43e6c6 100644
--- a/bsps/arm/atsam/start/power-clock.c
+++ b/bsps/arm/atsam/start/power-clock.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/atsam/start/power-rtc.c b/bsps/arm/atsam/start/power-rtc.c
index 5d964aeb45..336ccaea6f 100644
--- a/bsps/arm/atsam/start/power-rtc.c
+++ b/bsps/arm/atsam/start/power-rtc.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/atsam/start/power.c b/bsps/arm/atsam/start/power.c
index b84a956eb4..8debd817f7 100644
--- a/bsps/arm/atsam/start/power.c
+++ b/bsps/arm/atsam/start/power.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/atsam/start/restart.c b/bsps/arm/atsam/start/restart.c
index 8799df32e4..77520b9a22 100644
--- a/bsps/arm/atsam/start/restart.c
+++ b/bsps/arm/atsam/start/restart.c
@@ -1,9 +1,28 @@
+ * are met:
diff --git a/bsps/arm/atsam/start/sdram-config.c b/bsps/arm/atsam/start/sdram-config.c
index 181e9915ba..87e52ebed0 100644
--- a/bsps/arm/atsam/start/sdram-config.c
+++ b/bsps/arm/atsam/start/sdram-config.c
@@ -1,9 +1,28 @@
+ * are met:
 #include <bspopts.h>
2.24.4
