[PATCH 05/13] bsps/arm/csb337: Change license to BSD-2
Mon Jun 27 13:53:24 UTC 2022
    Updates #3053.
 bsps/arm/csb337/console/fbcons.c     | 25 ++++++++++++++++++++++---
 bsps/arm/csb337/include/sed1356.h    | 25 ++++++++++++++++++++++---
 bsps/arm/csb337/start/umonsupp.c     | 25 ++++++++++++++++++++++---
 bsps/arm/csb337/umon/tfsDriver.c     | 25 ++++++++++++++++++++++---
 bsps/arm/csb337/umon/umoncons.c      | 25 ++++++++++++++++++++++---
 bsps/arm/csb337/umon/umonrtemsglue.c | 25 ++++++++++++++++++++++---
 6 files changed, 132 insertions(+), 18 deletions(-)
diff --git a/bsps/arm/csb337/console/fbcons.c b/bsps/arm/csb337/console/fbcons.c
index 62e840938d..b53307436a 100644
--- a/bsps/arm/csb337/console/fbcons.c
+++ b/bsps/arm/csb337/console/fbcons.c
@@ -1,3 +1,5 @@
  *  LCD Console Output Driver for CSBx37
@@ -9,9 +11,26 @@
  *  Modified by Fernando Nicodemos <fgnicodemos at terra.com.br>
  *  from NCB - Sistemas Embarcados Ltda. (Brazil)
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/csb337/include/sed1356.h b/bsps/arm/csb337/include/sed1356.h
index 583a2a3a77..54ec2dfeee 100644
--- a/bsps/arm/csb337/include/sed1356.h
+++ b/bsps/arm/csb337/include/sed1356.h
@@ -1,3 +1,5 @@
  * @file
@@ -23,9 +25,26 @@
+ * are met:
 #ifndef __SED1356_h
diff --git a/bsps/arm/csb337/start/umonsupp.c b/bsps/arm/csb337/start/umonsupp.c
index d4bf731c5d..0f0ebafcc9 100644
--- a/bsps/arm/csb337/start/umonsupp.c
+++ b/bsps/arm/csb337/start/umonsupp.c
@@ -1,3 +1,5 @@
  *  COPYRIGHT (c) 1989-2009.
  *  On-Line Applications Research Corporation (OAR).
@@ -5,9 +7,26 @@
+ * are met:
 #include <bsp.h>
diff --git a/bsps/arm/csb337/umon/tfsDriver.c b/bsps/arm/csb337/umon/tfsDriver.c
index 8481c07daf..20c03c3966 100644
--- a/bsps/arm/csb337/umon/tfsDriver.c
+++ b/bsps/arm/csb337/umon/tfsDriver.c
@@ -1,3 +1,5 @@
  * @file
@@ -18,9 +20,26 @@
  *  Embarcados Ltda. (Brazil) to be more compliant with RTEMS coding
  *  standards and to eliminate C++ style comments.
+ * are met:
diff --git a/bsps/arm/csb337/umon/umoncons.c b/bsps/arm/csb337/umon/umoncons.c
index ef49585ef8..11d8f23764 100644
--- a/bsps/arm/csb337/umon/umoncons.c
+++ b/bsps/arm/csb337/umon/umoncons.c
@@ -1,3 +1,5 @@
  * uMon Support Output Driver
@@ -7,9 +9,26 @@
+ * are met:
 #include <rtems/umon.h>
diff --git a/bsps/arm/csb337/umon/umonrtemsglue.c b/bsps/arm/csb337/umon/umonrtemsglue.c
index 54d210c34f..41b8e13ea5 100644
--- a/bsps/arm/csb337/umon/umonrtemsglue.c
+++ b/bsps/arm/csb337/umon/umonrtemsglue.c
@@ -1,3 +1,5 @@
@@ -5,9 +7,26 @@
+ * are met:
2.24.4
