[PATCH 11/12] samples/minimum: Prevent a stack overflow
Sebastian Huber
Wed Jun 29 06:30:47 UTC 2022
Prevent a stack overflow if RTEMS_COVERAGE is enabled.
testsuites/samples/minimum/init.c | 5 +++++
1 file changed, 5 insertions(+)
diff --git a/testsuites/samples/minimum/init.c b/testsuites/samples/minimum/init.c
index c988d6d750..4238c47659 100644
--- a/testsuites/samples/minimum/init.c
+++ b/testsuites/samples/minimum/init.c
@@ -81,7 +81,12 @@ static void *Init( uintptr_t ignored )
* demonstrates that the user can specify how small of a minimum
* stack they want.
+#ifdef RTEMS_COVERAGE
+#define CONFIGURE_MINIMUM_TASK_STACK_SIZE \
+ (CPU_STACK_MINIMUM_SIZE - CPU_STACK_ALIGNMENT)
+#else
#define CONFIGURE_MINIMUM_TASK_STACK_SIZE 512
+#endif
* Keep the interrupt/initialization stack as is. Otherwise, the test may fail
2.35.3
