[PATCH 09/12] gcov: Add wrapper to dump the gcov info
Sebastian Huber
Wed Jun 29 06:30:45 UTC 2022
Update #4670.
cpukit/libtest/testgcovbspreset.c | 54 +++++++++++++++++++++++++++
cpukit/libtest/testgcovcpufatalhalt.c | 54 +++++++++++++++++++++++++++
spec/build/cpukit/librtemstest.yml | 2 +
3 files changed, 110 insertions(+)
create mode 100644 cpukit/libtest/testgcovbspreset.c
create mode 100644 cpukit/libtest/testgcovcpufatalhalt.c
diff --git a/cpukit/libtest/testgcovbspreset.c b/cpukit/libtest/testgcovbspreset.c
new file mode 100644
index 0000000000..6e10615f8c
--- /dev/null
+++ b/cpukit/libtest/testgcovbspreset.c
@@ -0,0 +1,54 @@
+ * @file
+ * @ingroup RTEMSTest
+ * @brief This source file contains the implementation of a wrapper for
+ * bsp_reset() which dumps the gcov information using
+ * rtems_test_gcov_dump_info() before the real bsp_reset() is called.
+ * Copyright (C) 2021, 2022 embedded brains GmbH
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/test-info.h>
+#include <rtems/score/cpu.h>
+void __real_bsp_reset( void );
+void __wrap_bsp_reset( void );
+ rtems_test_gcov_dump_info();
+ __real_bsp_reset();
diff --git a/cpukit/libtest/testgcovcpufatalhalt.c b/cpukit/libtest/testgcovcpufatalhalt.c
index 0000000000..dd8f10149c
--- /dev/null
+++ b/cpukit/libtest/testgcovcpufatalhalt.c
@@ -0,0 +1,54 @@
+ * @file
+ * _CPU_Fatal_halt() which dumps the gcov information using
+ * rtems_test_gcov_dump_info() before the real _CPU_Fatal_halt() is called.
+ * are met:
+#endif
+void __real__CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error );
+void __wrap__CPU_Fatal_halt( uint32_t source, CPU_Uint32ptr error );
+ __real__CPU_Fatal_halt( source, error );
diff --git a/spec/build/cpukit/librtemstest.yml b/spec/build/cpukit/librtemstest.yml
index cb04690066..ddbf6e3e76 100644
--- a/spec/build/cpukit/librtemstest.yml
+++ b/spec/build/cpukit/librtemstest.yml
@@ -38,6 +38,8 @@ source:
- cpukit/libtest/testbeginend.c
- cpukit/libtest/testbusy.c
- cpukit/libtest/testextension.c
+- cpukit/libtest/testgcovcpufatalhalt.c
+- cpukit/libtest/testgcovbspreset.c
- cpukit/libtest/testgcovdumpinfo.c
- cpukit/libtest/testparallel.c
- cpukit/libtest/testrun.c
2.35.3
