[tools] tester: Normalize JSON and YAML reports
Sebastian Huber
Wed Jun 29 09:34:25 UTC 2022
On 29/06/2022 11:20, Chris Johns wrote:
>> On 29 Jun 2022, at 4:42 pm, Sebastian Huber <sebastian.huber at embedded-brains.de> wrote:
>> On 29/06/2022 08:40, Sebastian Huber wrote:
>>> Report the same data in JSON and YAML reports. Do not report redundant
>>> information.
>>> Update 4671.
>> This patch changes the JSON reports. Are there already consumers for the JSON reports so that we have to be backward compatible?
> Could compatibility be added back in if this proves to be an issue?
> I am wondering if that could be considered if comparability becomes an issue.
The JSON report was added by:
commit 5fcaf843bdb491e2da14dc1af61806ac6d20bae5
Author: Kinsey Moore <kinsey.moore at oarcorp.com>
Date: Wed Aug 21 16:34:12 2019 +0000
Add JSON log generation
Add log formatter hooks and JSON log formatter to the test
infrastructure
for consumption by automated processes or report generators.
I am not sure if these automated processes or report generators already
exist.
The existing attribute names are quite inconsistent, for example
"Command Line", "passed_count", "wrong-version_count". I would use lower
case only with "-" as a separator. The JSON report should contain all
information of a test run.
The new report looks like this:
"command-line": [
"/opt/rtems/6/bin/rtems-test",
"--rtems-bsp=xilinx_zynq_a9_qemu",
"--report-format=json",
"--report-path=report",
"build/arm/xilinx_zynq_a9_qemu/testsuites/samples/"
"end-time": "2022-06-28T14:08:47.595131",
"host": "Linux-5.3.18-150300.59.76-default-x86_64-with-glibc2.3.4
(Linux lupus 5.3.18-150300.59.76-default #1 SMP Thu Jun 16 04:23:47 UTC
2022 (2cc2ade) x86_64 x86_64)",
"python": "3.6.15 (default, Sep 23 2021, 15:41:43) [GCC]",
"reports": [
"arch": "arm",
"bsp": "xilinx_zynq_a9_qemu",
"command-line": "qemu-system-arm -no-reboot -nographic -net
none -serial null -serial mon:stdio -M xilinx-zynq-a9 -m 256M -kernel
build/arm/xilinx_zynq_a9_qemu/testsuites/samples/cdtest.exe",
"end-time": "2022-06-28T12:08:48.161691+00:00",
"executable":
"build/arm/xilinx_zynq_a9_qemu/testsuites/samples/cdtest.exe",
"executable-sha512":
"413bc8a506053c95a0e1d93942cce9fd0d653f7b3cde42623085ce147aea324f4baeff7ce0102008322fb1341bc2b38defd3925a64144e47e13cc5f32185bf78",
"output": [
"qemu-system-arm: warning: nic cadence_gem.0 has no peer",
"qemu-system-arm: warning: nic cadence_gem.1 has no peer",
"*** BEGIN OF TEST CONSTRUCTOR/DESTRUCTOR ***",
"*** TEST VERSION:
6.0.0.3302b72754df5f37214e86dd68522189857772c7",
"*** TEST STATE: EXPECTED_PASS",
"*** TEST BUILD: RTEMS_DEBUG RTEMS_POSIX_API",
"*** TEST TOOLS: 12.1.1 20220622 (RTEMS 6, RSB
bf3f66c29a046ec1c5029e4f919b525947df6245, Newlib e7ffbdb)",
"GLOBAL: Hey I'm in base class constructor number 1 for
0x214474.",
"GLOBAL: Hey I'm in base class constructor number 2 for
0x214480.",
"GLOBAL: Hey I'm in derived class constructor number 3
for 0x214480.",
"LOCAL: Hey I'm in base class constructor number 4 for
0x228864.",
"WRoZqtoO3A8AAAABDAAAAJkUSmRGNOBaaHW1UwAAoQGQ////AAAAAQwAAABck8Bx+K/znDWWTEcA",
"AKEB2P///wAAAAEMAAAAVP6TRqQZY+4+srvAAAChAfD///8AAAABDAAAAMXOxS0Rhzqx6Old2wAA",
"oQH4////AAAAAQwAAADJyx1ZCnZ4l+m/XkMAAKEB0P///wAAAAEMAAAAN3+9YAwMW8gTHIoPAACh",
"Adj///8AAAABDAAAABtxsj3zXZF/+UqzfAAAoQHw////AAAAAQwAAAAwMDMeE7mphT6yu8AAAKEB",
"8P///wAAAAEMAAAAr2rLCcwzVnf5SrN8AAChAfD///8AAAAA",
"*** END OF GCOV INFO BASE64 ***",
"result": "passed",
"start-time": "2022-06-28T12:08:47.721822+00:00"
"start-time": "2022-06-28T14:08:47.595131"
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
