[tools] tester: Normalize JSON and YAML reports
Sebastian Huber
Thu Jun 30 05:58:27 UTC 2022
On 29/06/2022 17:54, Kinsey Moore wrote:
> On 6/29/2022 04:34, Sebastian Huber wrote:
>> On 29/06/2022 11:20, Chris Johns wrote:
>>>> On 29 Jun 2022, at 4:42 pm, Sebastian Huber
>>>> <sebastian.huber at embedded-brains.de> wrote:
>>>> On 29/06/2022 08:40, Sebastian Huber wrote:
>>>>> Report the same data in JSON and YAML reports. Do not report
>>>>> redundant
>>>>> information.
>>>>> Update 4671.
>>>> This patch changes the JSON reports. Are there already consumers for
>>>> the JSON reports so that we have to be backward compatible?
>>> Could compatibility be added back in if this proves to be an issue?
>>> I am wondering if that could be considered if comparability becomes
>>> an issue.
>> The JSON report was added by:
>> commit 5fcaf843bdb491e2da14dc1af61806ac6d20bae5
>> Author: Kinsey Moore <kinsey.moore at oarcorp.com>
>> Date: Wed Aug 21 16:34:12 2019 +0000
>> Add JSON log generation
>> Add log formatter hooks and JSON log formatter to the test
>> infrastructure
>> for consumption by automated processes or report generators.
>> I am not sure if these automated processes or report generators
>> already exist.
>> The existing attribute names are quite inconsistent, for example
>> "Command Line", "passed_count", "wrong-version_count". I would use
>> lower case only with "-" as a separator. The JSON report should
>> contain all information of a test run.
>> The new report looks like this:
>> "command-line": [
>> "/opt/rtems/6/bin/rtems-test",
>> "--rtems-bsp=xilinx_zynq_a9_qemu",
>> "--report-format=json",
>> "--report-path=report",
>> "build/arm/xilinx_zynq_a9_qemu/testsuites/samples/"
>> "end-time": "2022-06-28T14:08:47.595131",
>> "host": "Linux-5.3.18-150300.59.76-default-x86_64-with-glibc2.3.4
>> (Linux lupus 5.3.18-150300.59.76-default #1 SMP Thu Jun 16 04:23:47
>> UTC 2022 (2cc2ade) x86_64 x86_64)",
>> "python": "3.6.15 (default, Sep 23 2021, 15:41:43) [GCC]",
>> "reports": [
>> "arch": "arm",
>> "bsp": "xilinx_zynq_a9_qemu",
>> "command-line": "qemu-system-arm -no-reboot -nographic
>> -net none -serial null -serial mon:stdio -M xilinx-zynq-a9 -m 256M
>> -kernel build/arm/xilinx_zynq_a9_qemu/testsuites/samples/cdtest.exe",
>> "end-time": "2022-06-28T12:08:48.161691+00:00",
>> "executable":
>> "build/arm/xilinx_zynq_a9_qemu/testsuites/samples/cdtest.exe",
>> "executable-sha512":
>> "413bc8a506053c95a0e1d93942cce9fd0d653f7b3cde42623085ce147aea324f4baeff7ce0102008322fb1341bc2b38defd3925a64144e47e13cc5f32185bf78",
>> "output": [
>> "qemu-system-arm: warning: nic cadence_gem.0 has no
>> peer",
>> "qemu-system-arm: warning: nic cadence_gem.1 has no
>> peer",
>> "*** BEGIN OF TEST CONSTRUCTOR/DESTRUCTOR ***",
>> "*** TEST VERSION:
>> 6.0.0.3302b72754df5f37214e86dd68522189857772c7",
>> "*** TEST STATE: EXPECTED_PASS",
>> "*** TEST BUILD: RTEMS_DEBUG RTEMS_POSIX_API",
>> "*** TEST TOOLS: 12.1.1 20220622 (RTEMS 6, RSB
>> bf3f66c29a046ec1c5029e4f919b525947df6245, Newlib e7ffbdb)",
>> "GLOBAL: Hey I'm in base class constructor number 1
>> for 0x214474.",
>> "GLOBAL: Hey I'm in base class constructor number 2
>> for 0x214480.",
>> "GLOBAL: Hey I'm in derived class constructor number 3
>> for 0x214480.",
>> "LOCAL: Hey I'm in base class constructor number 4 for
>> 0x228864.",
>> "WRoZqtoO3A8AAAABDAAAAJkUSmRGNOBaaHW1UwAAoQGQ////AAAAAQwAAABck8Bx+K/znDWWTEcA",
>> "AKEB2P///wAAAAEMAAAAVP6TRqQZY+4+srvAAAChAfD///8AAAABDAAAAMXOxS0Rhzqx6Old2wAA",
>> "oQH4////AAAAAQwAAADJyx1ZCnZ4l+m/XkMAAKEB0P///wAAAAEMAAAAN3+9YAwMW8gTHIoPAACh",
>> "Adj///8AAAABDAAAABtxsj3zXZF/+UqzfAAAoQHw////AAAAAQwAAAAwMDMeE7mphT6yu8AAAKEB",
>> "8P///wAAAAEMAAAAr2rLCcwzVnf5SrN8AAChAfD///8AAAAA",
>> "*** END OF GCOV INFO BASE64 ***",
>> "result": "passed",
>> "start-time": "2022-06-28T12:08:47.721822+00:00"
>> "start-time": "2022-06-28T14:08:47.595131"
> There are no publicly available report generators for the existing
> format, but I do have one I use to generate STR documents for delivery
> using mustache templates and further processing. The existing format was
> designed to be easily consumable by that and other simple templating
> mechanisms by providing structure (test subsets) and precalculating
> values that would otherwise be implicit in the data. Changes to the
> names of various fields should be easy to accommodate, but a more
> significant restructure is going to present problems continuing with any
> simple templating mechanism and would instead require a more
> comprehensive document generator for all cases.
> I'm not necessarily opposed to this change as it significantly
> simplifies the report generation code, but it will definitely require
> some rework in my processes. I can't speak for any users of the YAML
> report format, but it was committed over a year and a half ago.
Ok, I will bring back the redundant data and use a consistent naming.
The YAML format was added for the RTEMS pre-qualification project,
however, it is pretty useless since the YAML processing is very slow in
Python. Also the test report generators need to be rewritten. This patch
is a part of this work.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
