[PATCH 01/40] testsuites/.../*doc: Manual cleanup of embedded brains File Headers
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Mar 7 13:22:59 UTC 2022
There were not a lot of these and they did not match the patterns
of the C.
Updates #4625.
 testsuites/libtests/block01/block01.doc        |  7 +------
 testsuites/libtests/block02/block02.doc        |  7 +------
 testsuites/libtests/block03/block03.doc        |  7 +------
 testsuites/libtests/block04/block04.doc        |  7 +------
 testsuites/libtests/block05/block05.doc        |  7 +------
 testsuites/libtests/block07/block07.doc        |  7 +------
 testsuites/libtests/block09/block09.doc        |  7 +------
 testsuites/libtests/block10/block10.doc        |  7 +------
 testsuites/sptests/spheapprot/spheapprot.doc   |  7 -------
 testsuites/sptests/spnsext01/spnsext01.doc     |  7 -------
 .../sptimecounter01/sptimecounter01.doc        | 18 +++++-------------
 11 files changed, 13 insertions(+), 75 deletions(-)
diff --git a/testsuites/libtests/block01/block01.doc b/testsuites/libtests/block01/block01.doc
index 49bf1a132b..781244053c 100644
--- a/testsuites/libtests/block01/block01.doc
+++ b/testsuites/libtests/block01/block01.doc
@@ -1,9 +1,4 @@
-# Copyright (c) 2009
-# embedded brains GmbH
-# Obere Lagerstr. 30
-# D-82178 Puchheim
-# Germany
-# <rtems at embedded-brains.de>
+# Copyright (c) 2009 embedded brains GmbH.  All rights reserved.
 # The license and distribution terms for this file may be
 # found in the file LICENSE in this distribution or at
diff --git a/testsuites/libtests/block02/block02.doc b/testsuites/libtests/block02/block02.doc
index e92ae57578..c8c7d15c40 100644
--- a/testsuites/libtests/block02/block02.doc
+++ b/testsuites/libtests/block02/block02.doc
@@ -1,9 +1,4 @@
-# D-82178 Puchheim
-# Germany
diff --git a/testsuites/libtests/block03/block03.doc b/testsuites/libtests/block03/block03.doc
index 0106172d60..3ada8a2614 100644
--- a/testsuites/libtests/block03/block03.doc
+++ b/testsuites/libtests/block03/block03.doc
@@ -1,9 +1,4 @@
-# D-82178 Puchheim
-# Germany
diff --git a/testsuites/libtests/block04/block04.doc b/testsuites/libtests/block04/block04.doc
index 6449183ca0..a7c59939f7 100644
--- a/testsuites/libtests/block04/block04.doc
+++ b/testsuites/libtests/block04/block04.doc
@@ -1,9 +1,4 @@
-# D-82178 Puchheim
-# Germany
diff --git a/testsuites/libtests/block05/block05.doc b/testsuites/libtests/block05/block05.doc
index f0c47453a4..cb34ab672d 100644
--- a/testsuites/libtests/block05/block05.doc
+++ b/testsuites/libtests/block05/block05.doc
@@ -1,9 +1,4 @@
-# Copyright (c) 2009, 2010
-# D-82178 Puchheim
-# Germany
+# Copyright (c) 2009, 2010 embedded brains GmbH.  All rights reserved.
diff --git a/testsuites/libtests/block07/block07.doc b/testsuites/libtests/block07/block07.doc
index f37e942dc7..7b39c08090 100644
--- a/testsuites/libtests/block07/block07.doc
+++ b/testsuites/libtests/block07/block07.doc
@@ -1,9 +1,4 @@
-# D-82178 Puchheim
-# Germany
diff --git a/testsuites/libtests/block09/block09.doc b/testsuites/libtests/block09/block09.doc
index debfb93ad9..bb015a6dc5 100644
--- a/testsuites/libtests/block09/block09.doc
+++ b/testsuites/libtests/block09/block09.doc
@@ -1,9 +1,4 @@
-# Copyright (c) 2010
-# D-82178 Puchheim
-# Germany
+# Copyright (c) 2010 embedded brains GmbH.  All rights reserved.
diff --git a/testsuites/libtests/block10/block10.doc b/testsuites/libtests/block10/block10.doc
index 3199ed5596..90b2b3f864 100644
--- a/testsuites/libtests/block10/block10.doc
+++ b/testsuites/libtests/block10/block10.doc
@@ -1,9 +1,4 @@
-# D-82178 Puchheim
-# Germany
diff --git a/testsuites/sptests/spheapprot/spheapprot.doc b/testsuites/sptests/spheapprot/spheapprot.doc
index 5b4ca4da25..d53ad5b9ec 100644
--- a/testsuites/sptests/spheapprot/spheapprot.doc
+++ b/testsuites/sptests/spheapprot/spheapprot.doc
@@ -1,12 +1,5 @@
-#  82178 Puchheim
-#  Germany
 # http://www.rtems.org/license/LICENSE.
diff --git a/testsuites/sptests/spnsext01/spnsext01.doc b/testsuites/sptests/spnsext01/spnsext01.doc
index 5830dade7c..c5383c9359 100644
--- a/testsuites/sptests/spnsext01/spnsext01.doc
+++ b/testsuites/sptests/spnsext01/spnsext01.doc
@@ -1,12 +1,5 @@
 # Copyright (c) 2011 embedded brains GmbH.  All rights reserved.
-#  82178 Puchheim
-#  Germany
diff --git a/testsuites/sptests/sptimecounter01/sptimecounter01.doc b/testsuites/sptests/sptimecounter01/sptimecounter01.doc
index 4a7442c2e6..aca9851aa1 100644
--- a/testsuites/sptests/sptimecounter01/sptimecounter01.doc
+++ b/testsuites/sptests/sptimecounter01/sptimecounter01.doc
@@ -1,16 +1,8 @@
- * Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
- *  embedded brains GmbH
- *  Dornierstr. 4
- *  82178 Puchheim
- *  Germany
- *  <rtems at embedded-brains.de>
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+# Copyright (c) 2015 embedded brains GmbH.  All rights reserved.
+# The license and distribution terms for this file may be
+# found in the file LICENSE in this distribution or at
+# http://www.rtems.org/license/LICENSE.
 This file describes the directives and concepts tested by this test set.
2.34.1
