[PATCH 03/40] testsuites/fstests/fsdosfsname01/create_files.cs: Convert to UNIX CR/LF.
Christian Mauderer
christian.mauderer at embedded-brains.de
Mon Mar 7 13:23:01 UTC 2022
This file had a mix of both DOS and UNIX CR/LF.
Updates #4625.
.../fstests/fsdosfsname01/create_files.cs | 242 +++++++++---------
1 file changed, 121 insertions(+), 121 deletions(-)
diff --git a/testsuites/fstests/fsdosfsname01/create_files.cs b/testsuites/fstests/fsdosfsname01/create_files.cs
index 3cb7604687..1340f27288 100644
--- a/testsuites/fstests/fsdosfsname01/create_files.cs
+++ b/testsuites/fstests/fsdosfsname01/create_files.cs
@@ -1,4 +1,4 @@
* @file Create_Files.cs
* @brief Format a USB memory stick and create files on the stick
@@ -9,8 +9,8 @@
* whith files with exotic multibyte filenames. The image will get
* mounted under RTEMS for testing the mutibyte/UTF-8 feature of the
* RTEMS FAT file system and the compatibility to MS Windows.
* Copyright (c) 2013 embedded brains GmbH. All rights reserved.
@@ -23,21 +23,21 @@
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
* http://www.rtems.org/license/LICENSE.
-using System;
-using System.Collections.Generic;
-using System.IO;
-using System.Diagnostics;
-using System.Threading;
-using System.Text;
-namespace Create_Files
- public static class Create_Files
- // Strings for file names and file contents
- public static string[] Strings = new string[] {
- "this is a long filename",
+using System;
+using System.Collections.Generic;
+using System.IO;
+using System.Diagnostics;
+using System.Threading;
+using System.Text;
+namespace Create_Files
+ public static class Create_Files
+ // Strings for file names and file contents
+ public static string[] Strings = new string[] {
+ "this is a long filename",
"đây là một tên tập tin dài",
"Bu uzun bir dosya adı",
"هذا هو اسم ملف طويل",
@@ -45,106 +45,106 @@ namespace Create_Files
"это длинное имя",
"гэта доўгае імя",
"това е дълго име на файла",
- "这是一个长文件名",
- "মেৰিকা মহাদেশ, উত্তৰ আমেৰিকা আৰু দক্ষিণ আমেৰিকা মহাদেশক লৈ গঠিত এক",
- "آمریکا قاره یکته قارهٰ زمینˇ قارهٰنˇ مئن ایسسه کی زمینˇ هنهشر (مساحت)ˇ جی ۳۸٪ و زمینˇ خوشکیئنˇ جی ۴۲۸٪ ای قاره شی ایسسه",
- "Manâhestôtse 910,720,588 (July 2008 est.)",
- "Elle s'étend depuis l'océan Arctique au nord jusqu'au cap Horn dans le passage de Drake au sud, à la confluence des océans",
- "ཨ་མེ་རི་ཀ, ཨ་མེ་རི་ཁ, མེ་གླིང་",
- "е су земље западне хемисфере или Новог света које се састоје од континената Северна Америка",
- "This is a filename with with 255 characters. The following numbers are aligned in that way, that the character 0 is the mentioned one. xx140xxxxxxx150xxxxxxx160xxxxxxx170xxxxxxx180xxxxxxx190xxxxxxx200xxxxxxx210xxxxxxx220xxxxxxx230xxxxxxx240xxxxxxx250xxxxx",
- "Bu gezegen Roma mitolojisindeki savaş ilahı Mars'a",
- "Amerike su zemlje zapadne hemisfere ili Novog svijeta koje se sastoje od kontinenata Sjeverna Amerika i Južna Amerika sa svim pridruženim otocima i regijama.",
- "იანებს ორ კონტინენტს, სამხრეთ და ჩრდილოეთ ამერიკას ახლომდებარე კუნძულებთან ერ",
- " Є то єдиный контінент, котрого цїла теріторія лежыть на Западній півкулї тай разом"
- // Use the features of MS Windows to format the USB memory stick. We want a genuine Microsoft FAT file system
- public static void FormatDrive(string driveLetter)
- ProcessStartInfo StartInfo = new ProcessStartInfo();
- StartInfo.FileName = Environment.SystemDirectory + "\\cmd.exe";
- StartInfo.Arguments = "/C \"format " + driveLetter + " /FS:FAT\"";
- StartInfo.UseShellExecute = false;
- StartInfo.RedirectStandardInput = true;
- Process Process = Process.Start(StartInfo);
- //Thread.Sleep(1000);
- Process.StandardInput.WriteLine();
- Process.WaitForExit();
- // Format a USB meory stick and create files on the new volume
- // args[0] The drive to be formatted. E.g. "e:"
- public static void Main(string[] args)
- // Display help text on the console
- if ((args.Length <= 0) || (args[0].Equals("-h", StringComparison.InvariantCultureIgnoreCase) || args[0].Equals("-help", StringComparison.InvariantCultureIgnoreCase)))
- Console.WriteLine("create_files.bat <DRIVE>");
- Console.WriteLine("Will format DRIVE and create files on the new formated drive.");
- else
- // Show a warning
- Console.WriteLine(args[0] + " will get formated!");
- while (true)
- Console.WriteLine("Press y to continue or press n to abort. [y\\n]");
- string Input = Console.ReadLine();
- if (Input[0].Equals('y') || Input[0].Equals('Y'))
- break;
- else if (Input[0].Equals('n') || Input[0].Equals('N'))
- return;
- // Format the USB memory stick
- FormatDrive(args[0]);
- // Create the files and write their own file names into them
- for (int i = 0; i < Strings.GetLength(0); i++)
- File.WriteAllText(Path.Combine(args[0], Strings[i]), Strings[i], Encoding.UTF8);
- Console.WriteLine("The file \"" + Strings[i] + "\" created.");
- // Create a c header file which contains an array with the strings and a #define
- // for the number of strings
- string HeaderPath = Path.Combine(args[0]/*Environment.CurrentDirectory*/, "files.h");
- Console.WriteLine("The header \"" + HeaderPath + "\" will write.");
- StreamWriter HeaderStream = new StreamWriter(HeaderPath);
- HeaderStream.Write("\n" +
- "/*\n" +
- " * Array with files, that were created in the FAT-filesystem image.bin.\n" +
- " *\n" +
- " * WARNING: Automatically generated by Create_Files.cs -- do not edit!\n" +
- " */\n" +
- "\n" +
- "#ifndef __FILE_H__\n" +
- "#define __FILE_H__\n" +
- "\n" +
- "#ifdef __cplusplus\n" +
- "extern C {\n" +
- "#endif\n" +
- "\n" +
- "static const char *const filenames[] = {\n");
- HeaderStream.WriteLine(" \"" + Strings[i] + ((i == (Strings.GetLength(0) - 1)) ? "\"" : "\","));
- string NumberOfFilesStr = Strings.GetLength(0).ToString(System.Globalization.CultureInfo.InvariantCulture);
- HeaderStream.Write("};\n" +
- "#define FILES_FILENAMES_NUMBER_OF " + NumberOfFilesStr + "\n" +
- "\n" +
- "}\n" +
- "#endif\n" +
- "\n" +
- "#endif /* __FILE_H__ */\n" +
- "\n");
- // Finalize
- HeaderStream.Flush();
- HeaderStream.Close();
- HeaderStream.Dispose();
+ "这是一个长文件名",
+ "মেৰিকা মহাদেশ, উত্তৰ আমেৰিকা আৰু দক্ষিণ আমেৰিকা মহাদেশক লৈ গঠিত এক",
+ "آمریکا قاره یکته قارهٰ زمینˇ قارهٰنˇ مئن ایسسه کی زمینˇ هنهشر (مساحت)ˇ جی ۳۸٪ و زمینˇ خوشکیئنˇ جی ۴۲۸٪ ای قاره شی ایسسه",
+ "Manâhestôtse 910,720,588 (July 2008 est.)",
+ "Elle s'étend depuis l'océan Arctique au nord jusqu'au cap Horn dans le passage de Drake au sud, à la confluence des océans",
+ "ཨ་མེ་རི་ཀ, ཨ་མེ་རི་ཁ, མེ་གླིང་",
+ "е су земље западне хемисфере или Новог света које се састоје од континената Северна Америка",
+ "This is a filename with with 255 characters. The following numbers are aligned in that way, that the character 0 is the mentioned one. xx140xxxxxxx150xxxxxxx160xxxxxxx170xxxxxxx180xxxxxxx190xxxxxxx200xxxxxxx210xxxxxxx220xxxxxxx230xxxxxxx240xxxxxxx250xxxxx",
+ "Bu gezegen Roma mitolojisindeki savaş ilahı Mars'a",
+ "Amerike su zemlje zapadne hemisfere ili Novog svijeta koje se sastoje od kontinenata Sjeverna Amerika i Južna Amerika sa svim pridruženim otocima i regijama.",
+ "იანებს ორ კონტინენტს, სამხრეთ და ჩრდილოეთ ამერიკას ახლომდებარე კუნძულებთან ერ",
+ " Є то єдиный контінент, котрого цїла теріторія лежыть на Западній півкулї тай разом"
+ // Use the features of MS Windows to format the USB memory stick. We want a genuine Microsoft FAT file system
+ public static void FormatDrive(string driveLetter)
+ ProcessStartInfo StartInfo = new ProcessStartInfo();
+ StartInfo.FileName = Environment.SystemDirectory + "\\cmd.exe";
+ StartInfo.Arguments = "/C \"format " + driveLetter + " /FS:FAT\"";
+ StartInfo.UseShellExecute = false;
+ StartInfo.RedirectStandardInput = true;
+ Process Process = Process.Start(StartInfo);
+ //Thread.Sleep(1000);
+ Process.StandardInput.WriteLine();
+ Process.WaitForExit();
+ // Format a USB meory stick and create files on the new volume
+ // args[0] The drive to be formatted. E.g. "e:"
+ public static void Main(string[] args)
+ // Display help text on the console
+ if ((args.Length <= 0) || (args[0].Equals("-h", StringComparison.InvariantCultureIgnoreCase) || args[0].Equals("-help", StringComparison.InvariantCultureIgnoreCase)))
+ Console.WriteLine("create_files.bat <DRIVE>");
+ Console.WriteLine("Will format DRIVE and create files on the new formated drive.");
+ else
+ // Show a warning
+ Console.WriteLine(args[0] + " will get formated!");
+ while (true)
+ Console.WriteLine("Press y to continue or press n to abort. [y\\n]");
+ string Input = Console.ReadLine();
+ if (Input[0].Equals('y') || Input[0].Equals('Y'))
+ break;
+ else if (Input[0].Equals('n') || Input[0].Equals('N'))
+ return;
+ // Format the USB memory stick
+ FormatDrive(args[0]);
+ // Create the files and write their own file names into them
+ for (int i = 0; i < Strings.GetLength(0); i++)
+ File.WriteAllText(Path.Combine(args[0], Strings[i]), Strings[i], Encoding.UTF8);
+ Console.WriteLine("The file \"" + Strings[i] + "\" created.");
+ // Create a c header file which contains an array with the strings and a #define
+ // for the number of strings
+ string HeaderPath = Path.Combine(args[0]/*Environment.CurrentDirectory*/, "files.h");
+ Console.WriteLine("The header \"" + HeaderPath + "\" will write.");
+ StreamWriter HeaderStream = new StreamWriter(HeaderPath);
+ HeaderStream.Write("\n" +
+ "/*\n" +
+ " * Array with files, that were created in the FAT-filesystem image.bin.\n" +
+ " *\n" +
+ " * WARNING: Automatically generated by Create_Files.cs -- do not edit!\n" +
+ " */\n" +
+ "\n" +
+ "#ifndef __FILE_H__\n" +
+ "#define __FILE_H__\n" +
+ "\n" +
+ "#ifdef __cplusplus\n" +
+ "extern C {\n" +
+ "#endif\n" +
+ "\n" +
+ "static const char *const filenames[] = {\n");
+ HeaderStream.WriteLine(" \"" + Strings[i] + ((i == (Strings.GetLength(0) - 1)) ? "\"" : "\","));
+ string NumberOfFilesStr = Strings.GetLength(0).ToString(System.Globalization.CultureInfo.InvariantCulture);
+ HeaderStream.Write("};\n" +
+ "#define FILES_FILENAMES_NUMBER_OF " + NumberOfFilesStr + "\n" +
+ "\n" +
+ "}\n" +
+ "#endif\n" +
+ "\n" +
+ "#endif /* __FILE_H__ */\n" +
+ "\n");
+ // Finalize
+ HeaderStream.Flush();
+ HeaderStream.Close();
+ HeaderStream.Dispose();
2.34.1
