[PATCH 30/40] bsps/powerpc: Manual file header clean up
Christian Mauderer christian.mauderer at embedded-brains.de
Mon Mar 7 13:23:28 UTC 2022
Updates #4625.
 bsps/powerpc/mpc55xxevb/i2c/i2c_init.c      | 31 +++++++---------
 bsps/powerpc/qemuppc/irq/irq_init.c         | 31 +++++++---------
 bsps/powerpc/tqm8xx/include/bsp/8xx_immap.h | 40 +++++++++------------
 bsps/powerpc/virtex4/include/bsp/irq.h      | 32 ++++++++---------
 bsps/powerpc/virtex4/irq/irq_init.c         | 35 ++++++++----------
 5 files changed, 71 insertions(+), 98 deletions(-)
diff --git a/bsps/powerpc/mpc55xxevb/i2c/i2c_init.c b/bsps/powerpc/mpc55xxevb/i2c/i2c_init.c
index dfcc621a31..d414fe61f0 100644
--- a/bsps/powerpc/mpc55xxevb/i2c/i2c_init.c
+++ b/bsps/powerpc/mpc55xxevb/i2c/i2c_init.c
@@ -1,21 +1,16 @@
-| Project: RTEMS support for GWLCFM                               |
-|                    Copyright (c) 2010                           |
-|                    embedded brains GmbH                         |
-|                    Obere Lagerstr. 30                           |
-|                    82178 Puchheim                             |
-|                    Germany                                      |
-|                    rtems at embedded-brains.de                     |
-| The license and distribution terms for this file may be         |
-| found in the file LICENSE in this distribution or at            |
-| http://www.rtems.org/license/LICENSE.                           |
-| this file contains the low level MPC5516 I2C driver parameters  |
+ * RTEMS support for GWLCFM
+ * This file contains the low level MPC5516 I2C driver parameters.
+ * Copyright (c) 2010 embedded brains GmbH. All rights reserved.
 #include <libchip/i2c-2b-eeprom.h>
diff --git a/bsps/powerpc/qemuppc/irq/irq_init.c b/bsps/powerpc/qemuppc/irq/irq_init.c
index 2171a8d8dd..c3e0aca915 100644
--- a/bsps/powerpc/qemuppc/irq/irq_init.c
+++ b/bsps/powerpc/qemuppc/irq/irq_init.c
@@ -1,21 +1,16 @@
-| Project: RTEMS generic MPC83xx BSP                              |
-|                    Copyright (c) 2007                           |
-|                    82178 Puchheim                             |
-|                    Germany                                      |
-| this file integrates the IPIC irq controller                    |
+ * RTEMS generic MPC83xx BSP
+ * This file integrates the IPIC irq controller.
+ * Copyright (c) 2007 embedded brains GmbH. All rights reserved.
diff --git a/bsps/powerpc/tqm8xx/include/bsp/8xx_immap.h b/bsps/powerpc/tqm8xx/include/bsp/8xx_immap.h
index a352d2c2a7..e6347ea0c6 100644
--- a/bsps/powerpc/tqm8xx/include/bsp/8xx_immap.h
+++ b/bsps/powerpc/tqm8xx/include/bsp/8xx_immap.h
@@ -1,30 +1,24 @@
-| Project: RTEMS BSP support for TQ modules                       |
-| Partially based on the code references which are named below.   |
-| Adaptions, modifications, enhancements and any recent parts of  |
-| the code are:                                                   |
-|                    82178 Puchheim                             |
-|                    Germany                                      |
-| this file contains definitions to interact with TQC's           |
-|  processor modules                                              |
-/* derived from mbx8xx BSP */
+ * RTEMS BSP support for TQ modules
+ * This file contains definitions to interact with TQC's
+ * processor modules.
+ * derived from mbx8xx BSP
  * MPC8xx Internal Memory Map
  * Copyright (c) 1997 Dan Malek (dmalek at jlc.net)
  * The I/O on the MPC860 is comprised of blocks of special registers
  * and the dual port ram for the Communication Processor Module.
  * Within this space are functional units such as the SIU, memory
diff --git a/bsps/powerpc/virtex4/include/bsp/irq.h b/bsps/powerpc/virtex4/include/bsp/irq.h
index 588a1e9c18..d992812648 100644
--- a/bsps/powerpc/virtex4/include/bsp/irq.h
+++ b/bsps/powerpc/virtex4/include/bsp/irq.h
@@ -1,21 +1,17 @@
-| Project: RTEMS virtex BSP                                       |
-|                    82178 Puchheim                             |
-|                    Germany                                      |
-| this file declares constants of the interrupt controller        |
+ * RTEMS virtex BSP
+ * This file declares constants of the interrupt controller.
 #ifndef VIRTEX4_IRQ_IRQ_H
 #define VIRTEX4_IRQ_IRQ_H
diff --git a/bsps/powerpc/virtex4/irq/irq_init.c b/bsps/powerpc/virtex4/irq/irq_init.c
index 95c07d668a..7aef395083 100644
--- a/bsps/powerpc/virtex4/irq/irq_init.c
+++ b/bsps/powerpc/virtex4/irq/irq_init.c
@@ -1,24 +1,17 @@
-| the code are:                                                   |
-|                    82178 Puchheim                             |
-|                    Germany                                      |
-| this file contains the irq controller handler                   |
+ * This file contains the irq controller handler.
 #include <libcpu/spr.h>
 #include <bsp/irq.h>
 #include <bsp.h>
2.34.1
