Warnings when building sparc/leon3
Mon Mar 7 18:19:37 UTC 2022
On Mon, Mar 7, 2022 at 11:54 AM Sebastian Huber <
> On 07/03/2022 17:48, Joel Sherrill wrote:
> > This appears to be because
> > rtems_configuration_get_user_multiprocessing_table() always returns a
> > non-NULL value when RTEMS_MULTIPROCESSING is defined. This must be a
> change
> > versus previous behavior.
> > Ryan and I noticed that the specific cases cited here appeared to be
> > wrapped in ifdef RTEMS_MULTIPROCESSING so didn't need to worry about it.
> > But something has changed that impacts public facing behavior.
> I think this is the related ticket:
> https://devel.rtems.org/ticket/3735
OK. But apparently this was used to tell the difference between a
single node system in MP configuration and a node within an
MP configuration.  My grep shows some uses are really dereferencing
the table but others like the one in amba.h:153 to define the clock
index looks wrong. THere is similar code in leon.h:
#if defined(RTEMS_MULTIPROCESSING)
  #define LEON3_CLOCK_INDEX \
   (rtems_configuration_get_user_multiprocessing_table() ? LEON3_Cpu_Index
: 0)
#else
  #define LEON3_CLOCK_INDEX 0
#endif
That's the type of pattern that needs addressing. That test is
asking in multiprocessing is configured in the application not
in the build.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
