[PATCH 1/2] cpukit/aarch64: Keep state across context switch
Sebastian Huber
Tue Mar 8 08:52:04 UTC 2022
On 28/02/2022 20:18, Kinsey Moore wrote:
> On 2/28/2022 12:19, Sebastian Huber wrote:
>> On 26/02/2022 08:03, Kinsey Moore wrote:
>>> On 2/26/2022 00:53, Sebastian Huber wrote:
>>>> On 26/02/2022 00:41, Kinsey Moore wrote:
>>>>> This may also be an issue for ARM, RISC-V and others as it doesn't
>>>>> appear that ARM saves CPSR during context switch and I couldn't
>>>>> tell that RISC-V does this either, though I'm less familiar with it.
>>>> This doesn't look like the right way to fix this issue.
>>>> There is currently the assumption that all processors start
>>>> multitasking with a context switch to _Thread_Handler() which sets
>>>> the interrupt level. It is possible to construct a scenario in which
>>>> we start multitasking with a migration of a thread which already
>>>> executed the _Thread_Handler() prologue. This would result in an
>>>> execution with disabled interrupts. I think the proper fix for this
>>>> scenario is to enable interrupts in
>>>> _CPU_SMP_Prepare_start_multitasking().
>>>> Doing a context switch with interrupts disabled is a fatal
>>>> application error on all architectures with
>>>> #define CPU_ENABLE_ROBUST_THREAD_DISPATCH TRUE
>>>> or enabled SMP support.
>>> Ok, great. I was wondering if that was the case and this is
>>> definitely the kind of feedback I was looking for. I'll adjust the
>>> patch set to reflect that. I still wonder if this is an issue on
>>> other SMP CPU ports, though, since most of them don't implement that
>>> hook, either.
>> I would like to have a closer look at this next week then I am back
>> from holidays.
>> Enabling interrupts in _CPU_SMP_Prepare_start_multitasking() would not
>> work since we use the interrupt stack at this point. We should add a
>> ticket and a test case for this (I can do this next week). How did you
>> observe this bug?
> I was only able to observe this bug once the 2/2 patch is applied and
> that optimization opens a race condition (adding a few no-ops to the
> Per_CPU_Control accessor prevents it from appearing) in the
> sppercpudata01 test on SMP configurations since the task is migrating
> across CPUs as CPUs are coming online. The race condition resolves
> nominally in 90% of cases so while it's not a frequent failure it is
> reproducible.
I added a ticket and a test case:
http://devel.rtems.org/ticket/4627
Could you please check if the test case fails currently on your aarch64
target?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
