[rtems-libbsd commit] if_xae: Port to RTEMS
Sebastian Huber
Wed Mar 9 15:11:14 UTC 2022
On 07/03/2022 23:54, Joel Sherrill wrote:
> Module: rtems-libbsd
> Branch: 6-freebsd-12
> Commit: 40b9c6ce6343cea5ca51ca9831d381886583a508
> Changeset: http://git.rtems.org/rtems-libbsd/commit/?id=40b9c6ce6343cea5ca51ca9831d381886583a508
> Author: Alex White <alex.white at oarcorp.com>
> Date: Sun Feb 6 21:12:31 2022 -0600
This broke the powerpc/beatnik build for example:
[1815/2059] Compiling freebsd/sys/dev/xilinx/axidma.c
../../freebsd/sys/dev/xilinx/axidma.c:130:31: error: array type has
incomplete element type 'struct ofw_compat_data'
130 | static struct ofw_compat_data compat_data[] = {
In file included from
../../rtemsbsd/include/machine/rtems-bsd-kernel-space.h:119,
from ../../freebsd/sys/dev/xilinx/axidma.c:1:
../../freebsd/sys/dev/xilinx/axidma.c: In function 'axidma_probe':
../../rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h:3767:29:
warning: implicit declaration of function '_bsd_ofw_bus_status_okay';
did you mean 'ofw_bus_status_okay'? [-Wimplicit-function-declaration]
3767 | #define ofw_bus_status_okay _bsd_ofw_bus_status_okay
../../freebsd/sys/dev/xilinx/axidma.c:263:7: note: in expansion of macro
263 | if (!ofw_bus_status_okay(dev))
../../rtemsbsd/include/machine/rtems-bsd-kernel-namespace.h:3764:35:
'_bsd_ofw_bus_search_compatible'; did you mean
'ofw_bus_search_compatible'? [-Wimplicit-function-declaration]
3764 | #define ofw_bus_search_compatible _bsd_ofw_bus_search_compatible
../../freebsd/sys/dev/xilinx/axidma.c:266:11: note: in expansion of
macro 'ofw_bus_search_compatible'
266 | hwtype = ofw_bus_search_compatible(dev, compat_data)->ocd_data;
../../freebsd/sys/dev/xilinx/axidma.c: In function 'axidma_attach':
../../freebsd/sys/dev/xilinx/axidma.c:310:9: warning: implicit
declaration of function 'ofw_bus_get_node'; did you mean
'ofw_bus_gen_get_node'? [-Wimplicit-function-declaration]
310 | node = ofw_bus_get_node(dev);
../../freebsd/sys/dev/xilinx/axidma.c: In function 'axidma_desc_alloc':
../../freebsd/sys/dev/xilinx/axidma.c:384:18: warning: assignment to
'vm_offset_t' {aka 'unsigned int'} from 'void *' makes integer from
pointer without a cast [-Wint-conversion]
384 | chan->mem_vaddr = calloc(1, chan->mem_size +
AXIDMA_DESCRIPTOR_ALIGNMENT - 1);
../../freebsd/sys/dev/xilinx/axidma.c:394:20: warning: cast to pointer
from integer of different size [-Wint-to-pointer-cast]
394 | chan->descs[i] = (struct axidma_desc *)
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
