[PATCH] smp: Add fatal error
Sebastian Huber
Thu Mar 10 13:48:20 UTC 2022
Add SMP-specifc SMP_FATAL_MULTITASKING_START_ON_NOT_ONLINE_PROCESSOR
fatal error. This fatal error helps to diagnose a broken SMP startup
sequence. Without this error a context switch using the NULL pointer
for the thread control block happens which may be difficult to debug.
cpukit/include/rtems/score/smpimpl.h | 3 +-
cpukit/score/src/smp.c | 5 +
.../fatal-start-on-not-online-processor.yml | 21 +++
spec/build/testsuites/validation/grp.yml | 2 +
.../tr-fatal-start-on-not-online-processor.c | 167 ++++++++++++++++++
.../tr-fatal-start-on-not-online-processor.h | 84 +++++++++
.../ts-fatal-start-on-not-online-processor.c | 82 +++++++++
7 files changed, 363 insertions(+), 1 deletion(-)
create mode 100644 spec/build/testsuites/validation/fatal-start-on-not-online-processor.yml
create mode 100644 testsuites/validation/tr-fatal-start-on-not-online-processor.c
create mode 100644 testsuites/validation/tr-fatal-start-on-not-online-processor.h
create mode 100644 testsuites/validation/ts-fatal-start-on-not-online-processor.c
diff --git a/cpukit/include/rtems/score/smpimpl.h b/cpukit/include/rtems/score/smpimpl.h
index e67c0953e6..8e965968a1 100644
--- a/cpukit/include/rtems/score/smpimpl.h
+++ b/cpukit/include/rtems/score/smpimpl.h
@@ -92,7 +92,8 @@ typedef enum {
SMP_FATAL_START_OF_MANDATORY_PROCESSOR_FAILED,
SMP_FATAL_SCHEDULER_PIN_OR_UNPIN_NOT_SUPPORTED,
SMP_FATAL_WRONG_CPU_STATE_TO_PERFORM_JOBS,
- SMP_FATAL_SCHEDULER_REQUIRES_EXACTLY_ONE_PROCESSOR
+ SMP_FATAL_SCHEDULER_REQUIRES_EXACTLY_ONE_PROCESSOR,
+ SMP_FATAL_MULTITASKING_START_ON_NOT_ONLINE_PROCESSOR
} SMP_Fatal_code;
diff --git a/cpukit/score/src/smp.c b/cpukit/score/src/smp.c
index 0dc8830c46..7c068f3c51 100644
--- a/cpukit/score/src/smp.c
+++ b/cpukit/score/src/smp.c
@@ -269,6 +269,11 @@ void _SMP_Start_multitasking_on_secondary_processor(
_Per_CPU_Set_state( cpu_self, PER_CPU_STATE_READY_TO_START_MULTITASKING );
_SMP_Wait_for_start_multitasking( cpu_self );
+ if ( !_Per_CPU_Is_processor_online( cpu_self ) ) {
+ _SMP_Fatal( SMP_FATAL_MULTITASKING_START_ON_NOT_ONLINE_PROCESSOR );
_Thread_Start_multitasking();
diff --git a/spec/build/testsuites/validation/fatal-start-on-not-online-processor.yml b/spec/build/testsuites/validation/fatal-start-on-not-online-processor.yml
new file mode 100644
index 0000000000..7858041843
--- /dev/null
+++ b/spec/build/testsuites/validation/fatal-start-on-not-online-processor.yml
@@ -0,0 +1,21 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+cppflags: []
+cxxflags: []
+enabled-by: RTEMS_SMP
+features: c cprogram
+includes: []
+ldflags:
+- -Wl,-wrap=_CPU_SMP_Start_processor
+links: []
+source:
+- testsuites/validation/tr-fatal-start-on-not-online-processor.c
+- testsuites/validation/ts-fatal-start-on-not-online-processor.c
+stlib: []
+target: testsuites/validation/ts-fatal-start-on-not-online-processor.exe
+type: build
+use-after: []
+use-before: []
diff --git a/spec/build/testsuites/validation/grp.yml b/spec/build/testsuites/validation/grp.yml
index c26d5ac9e7..c1ccd4c697 100644
--- a/spec/build/testsuites/validation/grp.yml
+++ b/spec/build/testsuites/validation/grp.yml
@@ -38,6 +38,8 @@ links:
uid: fatal-smp
- role: build-dependency
uid: fatal-start-of-mandatory-processor-failed
+- role: build-dependency
+ uid: fatal-start-on-not-online-processor
uid: fatal-too-large-tls-size
diff --git a/testsuites/validation/tr-fatal-start-on-not-online-processor.c b/testsuites/validation/tr-fatal-start-on-not-online-processor.c
index 0000000000..55081bc25d
--- /dev/null
+++ b/testsuites/validation/tr-fatal-start-on-not-online-processor.c
@@ -0,0 +1,167 @@
+ * @file
+ * @ingroup RTEMSTestCaseScoreSmpValFatalStartOnNotOnlineProcessor
+ * Copyright (C) 2022 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
+ * This file is part of the RTEMS quality process and was automatically
+ * generated. If you find something that needs to be fixed or
+ * worded better please post a report or patch to an RTEMS mailing list
+ * or raise a bug report:
+ * https://www.rtems.org/bugs.html
+ * For information on updating and regenerating please refer to the How-To
+ * section in the Software Requirements Engineering chapter of the
+ * RTEMS Software Engineering manual. The manual is provided as a part of
+ * a release. For development sources please refer to the online
+ * documentation at:
+ * https://docs.rtems.org
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/score/smpimpl.h>
+#include "tr-fatal-start-on-not-online-processor.h"
+#include <rtems/test.h>
+ * @defgroup RTEMSTestCaseScoreSmpValFatalStartOnNotOnlineProcessor \
+ * spec:/score/smp/val/fatal-start-on-not-online-processor
+ * @ingroup RTEMSTestSuiteTestsuitesFatalStartOnNotOnlineProcessor
+ * @brief Tests a fatal error.
+ * This test case performs the following actions:
+ * - The test action is carried out by the wrapped _CPU_SMP_Start_processor().
+ * - Check that the expected fatal source is present.
+ * - Check that the expected fatal code is present.
+ * @brief Test context for
+ * spec:/score/smp/val/fatal-start-on-not-online-processor test case.
+typedef struct {
+ * @brief This member contains a copy of the corresponding
+ * ScoreSmpValFatalStartOnNotOnlineProcessor_Run() parameter.
+ rtems_fatal_source source;
+ rtems_fatal_code code;
+} ScoreSmpValFatalStartOnNotOnlineProcessor_Context;
+static ScoreSmpValFatalStartOnNotOnlineProcessor_Context
+ ScoreSmpValFatalStartOnNotOnlineProcessor_Instance;
+bool __real__CPU_SMP_Start_processor( uint32_t cpu_index );
+bool __wrap__CPU_SMP_Start_processor( uint32_t cpu_index );
+ (void) __real__CPU_SMP_Start_processor( cpu_index );
+ return false;
+static T_fixture ScoreSmpValFatalStartOnNotOnlineProcessor_Fixture = {
+ .setup = NULL,
+ .stop = NULL,
+ .teardown = NULL,
+ .scope = NULL,
+ .initial_context = &ScoreSmpValFatalStartOnNotOnlineProcessor_Instance
+ * @brief The test action is carried out by the wrapped
+ * _CPU_SMP_Start_processor().
+static void ScoreSmpValFatalStartOnNotOnlineProcessor_Action_0(
+ ScoreSmpValFatalStartOnNotOnlineProcessor_Context *ctx
+ /* Nothing to do */
+ * Check that the expected fatal source is present.
+ T_step_eq_int( 0, ctx->source, RTEMS_FATAL_SOURCE_SMP );
+ * Check that the expected fatal code is present.
+ T_step_eq_ulong(
+ 1,
+ ctx->code,
+void ScoreSmpValFatalStartOnNotOnlineProcessor_Run(
+ rtems_fatal_source source,
+ ScoreSmpValFatalStartOnNotOnlineProcessor_Context *ctx;
+ ctx = &ScoreSmpValFatalStartOnNotOnlineProcessor_Instance;
+ ctx->source = source;
+ ctx->code = code;
+ ctx = T_case_begin(
+ "ScoreSmpValFatalStartOnNotOnlineProcessor",
+ &ScoreSmpValFatalStartOnNotOnlineProcessor_Fixture
+ T_plan( 2 );
+ ScoreSmpValFatalStartOnNotOnlineProcessor_Action_0( ctx );
+ T_case_end();
diff --git a/testsuites/validation/tr-fatal-start-on-not-online-processor.h b/testsuites/validation/tr-fatal-start-on-not-online-processor.h
index 0000000000..65a8a308f7
--- /dev/null
+++ b/testsuites/validation/tr-fatal-start-on-not-online-processor.h
@@ -0,0 +1,84 @@
+ * @file
+ * are met:
+#ifndef _TR_FATAL_START_ON_NOT_ONLINE_PROCESSOR_H
+#define _TR_FATAL_START_ON_NOT_ONLINE_PROCESSOR_H
+#include <rtems.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @addtogroup RTEMSTestCaseScoreSmpValFatalStartOnNotOnlineProcessor
+ * @brief Runs the parameterized test case.
+ * @param source is fatal source.
+ * @param code is fatal code.
+#ifdef __cplusplus
+#endif
+#endif /* _TR_FATAL_START_ON_NOT_ONLINE_PROCESSOR_H */
diff --git a/testsuites/validation/ts-fatal-start-on-not-online-processor.c b/testsuites/validation/ts-fatal-start-on-not-online-processor.c
index 0000000000..9e046bbde1
--- /dev/null
+++ b/testsuites/validation/ts-fatal-start-on-not-online-processor.c
@@ -0,0 +1,82 @@
+ * @file
+ * are met:
+#endif
+#include "ts-config.h"
+ * @defgroup RTEMSTestSuiteTestsuitesFatalStartOnNotOnlineProcessor \
+ * spec:/testsuites/fatal-start-on-not-online-processor
+ * @ingroup RTEMSTestSuites
+ * @brief This validation test suite contains a test case which triggers a
+ * fatal error during system initialization.
+const char rtems_test_name[] = "FatalStartOnNotOnlineProcessor";
+#define FATAL_SYSINIT_RUN ScoreSmpValFatalStartOnNotOnlineProcessor_Run
+#define CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+#define CONFIGURE_MAXIMUM_PROCESSORS 2
+#include "ts-fatal-sysinit.h"
2.34.1
