[PATCH] shell: Avoid potential stack corruption
Tue Mar 15 06:27:21 UTC 2022
The rtems_shell_init() passed the address of a stack variable
(exit_code) to rtems_shell_run().  If wait == false, then the stack
variable goes out of scope but may be accessed by the created shell
thread.
The rtems_shell_script() was affected by the same problem.
Close #4629.
 cpukit/libmisc/shell/shell.c | 8 +-------
 1 file changed, 1 insertion(+), 7 deletions(-)
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index 1e5962b1e3..3268bfe4f5 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -1149,7 +1149,6 @@ static rtems_status_code rtems_shell_run (
   const char *output,
   bool output_append,
   rtems_id wake_on_end,
-  int *exit_code,
   bool echo,
   rtems_shell_login_check_t login_check
@@ -1202,7 +1201,6 @@ static rtems_status_code rtems_shell_run (
   shell_env->parent_stdout = stdout;
   shell_env->parent_stderr = stderr;
   shell_env->wake_on_end   = wake_on_end;
-  shell_env->exit_code     = exit_code;
   shell_env->login_check   = login_check;
   shell_env->uid           = getuid();
   shell_env->gid           = getgid();
@@ -1229,7 +1227,7 @@ static rtems_status_code rtems_shell_run (
     sc = rtems_event_receive (RTEMS_EVENT_1, RTEMS_WAIT, 0, &out);
-  shell_std_debug("run: end: sc:%d ec:%d\n", sc, *exit_code);
+  shell_std_debug("run: end: sc:%d\n", sc);
   return sc;
@@ -1245,7 +1243,6 @@ rtems_status_code rtems_shell_init(
   rtems_id to_wake = RTEMS_ID_NONE;
-  int exit_code = 0;
   if ( wait )
     to_wake = rtems_task_self();
@@ -1261,7 +1258,6 @@ rtems_status_code rtems_shell_init(
     "stdout",                /* output */
     false,                   /* output_append */
     to_wake,                 /* wake_on_end */
-    &exit_code,              /* exit code of command */
     false,                   /* echo */
     login_check              /* login check */
@@ -1279,7 +1275,6 @@ rtems_status_code rtems_shell_script (
   rtems_status_code sc;
   shell_std_debug("script: in: %s out: %s\n", input, output);
@@ -1298,7 +1293,6 @@ rtems_status_code rtems_shell_script (
     output,          /* output */
     output_append,   /* output_append */
-    &exit_code,      /* exit_code */
     echo,            /* echo */
     NULL             /* login check */
2.34.1
