[PATCH rtems-source-builder] 6/7: Update AArch64 newlib patch
Kinsey Moore
kinsey.moore at oarcorp.com
Thu Mar 17 21:59:14 UTC 2022
The existing patch fails to build with the latest newlib. This picks up
an updated patch that compiles with both older and newer newlib.
rtems/config/tools/rtems-gcc-10-newlib-head.cfg | 4 ++--
rtems/config/tools/rtems-gcc-head-newlib-head.cfg | 4 ++--
2 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
index cb26aa0..22a88ba 100644
--- a/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-10-newlib-head.cfg
@@ -13,8 +13,8 @@
%patch add gcc -p1 https://devel.rtems.org/raw-attachment/ticket/4215/0001-nios2-Remove-custom-instruction-warnings.patch
%hash sha512 0001-nios2-Remove-custom-instruction-warnings.patch afd8a5e6bdcc5b75d5fbbf558bdf56ccac400521a6eec9d88cc95f6be67c481f2dbf8faa0f6ddc1e4ac7c56a84938714d80e46e9cf80ec4b8fcd739986449881
-%patch add newlib -p1 https://devel.rtems.org/raw-attachment/ticket/4510/0001-aarch64-Add-ILP32-ABI-support-in-assembly.patch
-%hash sha512 0001-aarch64-Add-ILP32-ABI-support-in-assembly.patch BHRMimj6ztKPHQFxypI8RwPmno96B56eVQGx5dtCtcOb+qICMrQC1fa0jP3JrR8RGJI4y61RoYvpnj6EbTmRKA==
+%patch add newlib -p1 https://devel.rtems.org/raw-attachment/ticket/4510/0001-aarch64-Add-ILP32-ABI-support-in-assembly-v2.patch
+%hash sha512 0001-aarch64-Add-ILP32-ABI-support-in-assembly-v2.patch 7ca237eabfd5b382713186e1fc290dfc999a353315795ecb8dd0d22fcd1ab7f5bf31f4329954adab91ad04c100dcac0e86d406fdbce8f82cf9dc23842c88caf6
%define newlib_version 332df71
%define newlib_external 1
diff --git a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
index 6aaad8d..b2bc78f 100644
--- a/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
+++ b/rtems/config/tools/rtems-gcc-head-newlib-head.cfg
@@ -13,8 +13,8 @@
%source set newlib --rsb-file=newlib-%{newlib_version}.tar.gz https://codeload.github.com/RTEMS/sourceware-mirror-newlib-cygwin/tar.gz/%{newlib_version}
%hash sha512 newlib-%{newlib_version}.tar.gz ec6db480d5e21f8de520a3c33a22dc08a2be56a6fb817d31d5f16c2f564df4907c1e3f3e7c1cf2368eed1d93b3811cabc1cdffb922d3df05ba7fe960eabd265b
%define with_threads 1
%define with_plugin 0
2.30.2
