[PATCH 13/13] bsps: Add gicv3_get_attributes()
Fri Mar 18 07:19:15 UTC 2022
 bsps/include/dev/irq/arm-gicv3.h | 32 ++++++++++++++++++++++++++++++++
 bsps/shared/dev/irq/arm-gicv3.c  | 27 +--------------------------
 2 files changed, 33 insertions(+), 26 deletions(-)
diff --git a/bsps/include/dev/irq/arm-gicv3.h b/bsps/include/dev/irq/arm-gicv3.h
index 6a716894b4..0d3ef9a1c1 100644
--- a/bsps/include/dev/irq/arm-gicv3.h
+++ b/bsps/include/dev/irq/arm-gicv3.h
@@ -327,6 +327,38 @@ static void gicv3_init_cpu_interface(uint32_t cpu_index)
   WRITE_SR(ICC_CTLR, 0x0);
+static inline void gicv3_get_attributes(
+  rtems_vector_number         vector,
+  rtems_interrupt_attributes *attributes
+  attributes->is_maskable = true;
+  attributes->maybe_enable = true;
+  attributes->maybe_disable = true;
+  attributes->can_raise = true;
+  if ( vector <= ARM_GIC_IRQ_SGI_LAST ) {
+     * It is implementation-defined whether implemented SGIs are permanently
+     * enabled, or can be enabled and disabled by writes to GICD_ISENABLER0 and
+     * GICD_ICENABLER0.
+    attributes->can_raise_on = true;
+    attributes->cleared_by_acknowledge = true;
+    attributes->trigger_signal = RTEMS_INTERRUPT_NO_SIGNAL;
+  } else {
+    attributes->can_disable = true;
+    attributes->can_clear = true;
+    attributes->trigger_signal = RTEMS_INTERRUPT_UNSPECIFIED_SIGNAL;
+    if ( vector > ARM_GIC_IRQ_PPI_LAST ) {
+      /* SPI */
+      attributes->can_get_affinity = true;
+      attributes->can_set_affinity = true;
 #ifdef __cplusplus
 #endif
diff --git a/bsps/shared/dev/irq/arm-gicv3.c b/bsps/shared/dev/irq/arm-gicv3.c
index d81f3b50c1..4772ff5db4 100644
--- a/bsps/shared/dev/irq/arm-gicv3.c
+++ b/bsps/shared/dev/irq/arm-gicv3.c
@@ -49,32 +49,7 @@ rtems_status_code bsp_interrupt_get_attributes(
-  attributes->is_maskable = true;
-  attributes->maybe_enable = true;
-  attributes->maybe_disable = true;
-  attributes->can_raise = true;
-  if ( vector <= ARM_GIC_IRQ_SGI_LAST ) {
-     * It is implementation-defined whether implemented SGIs are permanently
-     * enabled, or can be enabled and disabled by writes to GICD_ISENABLER0 and
-     * GICD_ICENABLER0.
-    attributes->can_raise_on = true;
-    attributes->cleared_by_acknowledge = true;
-    attributes->trigger_signal = RTEMS_INTERRUPT_NO_SIGNAL;
-  } else {
-    attributes->can_disable = true;
-    attributes->can_clear = true;
-    attributes->trigger_signal = RTEMS_INTERRUPT_UNSPECIFIED_SIGNAL;
-    if ( vector > ARM_GIC_IRQ_PPI_LAST ) {
-      /* SPI */
-      attributes->can_get_affinity = true;
-      attributes->can_set_affinity = true;
+  gicv3_get_attributes(vector, attributes);
   return RTEMS_SUCCESSFUL;
2.34.1
