[PATCH 06/26] cpukit/libfs/src/imfs: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Mar 18 16:21:13 UTC 2022
Updates #3053.
cpukit/libfs/src/imfs/deviceio.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_chown.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_config.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_creat.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_dir.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_dir_default.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_dir_minimal.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_eval.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_fchmod.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_fifo.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_fsunmount.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_handlers_device.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_initsupp.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_linfile.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_link.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_load_tar.c | 25 ++++++++++++++++---
.../libfs/src/imfs/imfs_make_generic_node.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_memfile.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_mknod.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_mount.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_node.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_rename.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_rmnod.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_stat.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_stat_file.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_symlink.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/imfs_unmount.c | 25 ++++++++++++++++---
cpukit/libfs/src/imfs/ioman.c | 25 ++++++++++++++++---
28 files changed, 616 insertions(+), 84 deletions(-)
diff --git a/cpukit/libfs/src/imfs/deviceio.c b/cpukit/libfs/src/imfs/deviceio.c
index c1577ed39f..c364751a32 100644
--- a/cpukit/libfs/src/imfs/deviceio.c
+++ b/cpukit/libfs/src/imfs/deviceio.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2012.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
diff --git a/cpukit/libfs/src/imfs/imfs_chown.c b/cpukit/libfs/src/imfs/imfs_chown.c
index 268ed0fc56..5a0049ba2d 100644
--- a/cpukit/libfs/src/imfs/imfs_chown.c
+++ b/cpukit/libfs/src/imfs/imfs_chown.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_config.c b/cpukit/libfs/src/imfs/imfs_config.c
index 72aa9424f9..9b4fe77f53 100644
--- a/cpukit/libfs/src/imfs/imfs_config.c
+++ b/cpukit/libfs/src/imfs/imfs_config.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_creat.c b/cpukit/libfs/src/imfs/imfs_creat.c
index 3a609e160d..8a6e3a3567 100644
--- a/cpukit/libfs/src/imfs/imfs_creat.c
+++ b/cpukit/libfs/src/imfs/imfs_creat.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* COPYRIGHT (c) 1989-2010.
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_dir.c b/cpukit/libfs/src/imfs/imfs_dir.c
index f4b18b499c..2b2b2d35b1 100644
--- a/cpukit/libfs/src/imfs/imfs_dir.c
+++ b/cpukit/libfs/src/imfs/imfs_dir.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_dir_default.c b/cpukit/libfs/src/imfs/imfs_dir_default.c
index a58f0d79b1..44702103c3 100644
--- a/cpukit/libfs/src/imfs/imfs_dir_default.c
+++ b/cpukit/libfs/src/imfs/imfs_dir_default.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_dir_minimal.c b/cpukit/libfs/src/imfs/imfs_dir_minimal.c
index 25e585e82b..3a73071744 100644
--- a/cpukit/libfs/src/imfs/imfs_dir_minimal.c
+++ b/cpukit/libfs/src/imfs/imfs_dir_minimal.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_eval.c b/cpukit/libfs/src/imfs/imfs_eval.c
index 5f84e03153..bb71fe1a3b 100644
--- a/cpukit/libfs/src/imfs/imfs_eval.c
+++ b/cpukit/libfs/src/imfs/imfs_eval.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* Modifications to support reference counting in the file system are
* Copyright (c) 2012 embedded brains GmbH.
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_fchmod.c b/cpukit/libfs/src/imfs/imfs_fchmod.c
index e8814f73f7..7f885a1987 100644
--- a/cpukit/libfs/src/imfs/imfs_fchmod.c
+++ b/cpukit/libfs/src/imfs/imfs_fchmod.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_fifo.c b/cpukit/libfs/src/imfs/imfs_fifo.c
index 1973801cb6..a3154e18bd 100644
--- a/cpukit/libfs/src/imfs/imfs_fifo.c
+++ b/cpukit/libfs/src/imfs/imfs_fifo.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Author: Wei Shen <cquark at gmail.com>
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_fsunmount.c b/cpukit/libfs/src/imfs/imfs_fsunmount.c
index 4d29c400ef..1855da2e3a 100644
--- a/cpukit/libfs/src/imfs/imfs_fsunmount.c
+++ b/cpukit/libfs/src/imfs/imfs_fsunmount.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_handlers_device.c b/cpukit/libfs/src/imfs/imfs_handlers_device.c
index ab32ce4b73..9e6a744553 100644
--- a/cpukit/libfs/src/imfs/imfs_handlers_device.c
+++ b/cpukit/libfs/src/imfs/imfs_handlers_device.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_initsupp.c b/cpukit/libfs/src/imfs/imfs_initsupp.c
index 4c09cf750e..b3dccf37e0 100644
--- a/cpukit/libfs/src/imfs/imfs_initsupp.c
+++ b/cpukit/libfs/src/imfs/imfs_initsupp.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_linfile.c b/cpukit/libfs/src/imfs/imfs_linfile.c
index be9dea693b..4f961d19e8 100644
--- a/cpukit/libfs/src/imfs/imfs_linfile.c
+++ b/cpukit/libfs/src/imfs/imfs_linfile.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_link.c b/cpukit/libfs/src/imfs/imfs_link.c
index 16ad862a50..301a280211 100644
--- a/cpukit/libfs/src/imfs/imfs_link.c
+++ b/cpukit/libfs/src/imfs/imfs_link.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_load_tar.c b/cpukit/libfs/src/imfs/imfs_load_tar.c
index a0cc115be4..ec651d820a 100644
--- a/cpukit/libfs/src/imfs/imfs_load_tar.c
+++ b/cpukit/libfs/src/imfs/imfs_load_tar.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_make_generic_node.c b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
index ac94e45dad..abecf5ec53 100644
--- a/cpukit/libfs/src/imfs/imfs_make_generic_node.c
+++ b/cpukit/libfs/src/imfs/imfs_make_generic_node.c
@@ -1,3 +1,5 @@
* @file
@@ -9,9 +11,26 @@
* Copyright (c) 2012 embedded brains GmbH. All rights reserved.
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_memfile.c b/cpukit/libfs/src/imfs/imfs_memfile.c
index 0f19859fac..23c7192717 100644
--- a/cpukit/libfs/src/imfs/imfs_memfile.c
+++ b/cpukit/libfs/src/imfs/imfs_memfile.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_mknod.c b/cpukit/libfs/src/imfs/imfs_mknod.c
index 8d23f12f55..17aa1d3802 100644
--- a/cpukit/libfs/src/imfs/imfs_mknod.c
+++ b/cpukit/libfs/src/imfs/imfs_mknod.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_mount.c b/cpukit/libfs/src/imfs/imfs_mount.c
index 371e88e106..ba4e258f7a 100644
--- a/cpukit/libfs/src/imfs/imfs_mount.c
+++ b/cpukit/libfs/src/imfs/imfs_mount.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_node.c b/cpukit/libfs/src/imfs/imfs_node.c
index a89298ffc2..91bd89d66c 100644
--- a/cpukit/libfs/src/imfs/imfs_node.c
+++ b/cpukit/libfs/src/imfs/imfs_node.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_rename.c b/cpukit/libfs/src/imfs/imfs_rename.c
index 701500872d..d925591b32 100644
--- a/cpukit/libfs/src/imfs/imfs_rename.c
+++ b/cpukit/libfs/src/imfs/imfs_rename.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_rmnod.c b/cpukit/libfs/src/imfs/imfs_rmnod.c
index 0aaadb7ebe..121283cdd9 100644
--- a/cpukit/libfs/src/imfs/imfs_rmnod.c
+++ b/cpukit/libfs/src/imfs/imfs_rmnod.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_stat.c b/cpukit/libfs/src/imfs/imfs_stat.c
index bbca49f8ef..260f0ade02 100644
--- a/cpukit/libfs/src/imfs/imfs_stat.c
+++ b/cpukit/libfs/src/imfs/imfs_stat.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_stat_file.c b/cpukit/libfs/src/imfs/imfs_stat_file.c
index 20d538f692..7624d03376 100644
--- a/cpukit/libfs/src/imfs/imfs_stat_file.c
+++ b/cpukit/libfs/src/imfs/imfs_stat_file.c
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_symlink.c b/cpukit/libfs/src/imfs/imfs_symlink.c
index 7323cc0241..108f41b01b 100644
--- a/cpukit/libfs/src/imfs/imfs_symlink.c
+++ b/cpukit/libfs/src/imfs/imfs_symlink.c
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2009.
+ * are met:
diff --git a/cpukit/libfs/src/imfs/imfs_unmount.c b/cpukit/libfs/src/imfs/imfs_unmount.c
index 0e9f5eee84..448573b63a 100644
--- a/cpukit/libfs/src/imfs/imfs_unmount.c
+++ b/cpukit/libfs/src/imfs/imfs_unmount.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
diff --git a/cpukit/libfs/src/imfs/ioman.c b/cpukit/libfs/src/imfs/ioman.c
index 55fb1728b5..a9958b5c82 100644
--- a/cpukit/libfs/src/imfs/ioman.c
+++ b/cpukit/libfs/src/imfs/ioman.c
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
2.24.4
