[PATCH 17/26] cpukit/libmisc/dummy: Change license to BSD-2.
Joel Sherrill
joel at rtems.org
Fri Mar 18 16:21:24 UTC 2022
Updates #3053.
cpukit/libmisc/dummy/default-configuration.c | 25 +++++++++++++++++---
1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/cpukit/libmisc/dummy/default-configuration.c b/cpukit/libmisc/dummy/default-configuration.c
index 9c30b270c2..62c6e98de7 100644
--- a/cpukit/libmisc/dummy/default-configuration.c
+++ b/cpukit/libmisc/dummy/default-configuration.c
@@ -1,12 +1,31 @@
* Default configuration file
* COPYRIGHT (c) 1989-2008.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifdef HAVE_CONFIG_H
2.24.4
