[PATCH 22/26] cpukit/libmisc/redirector: Manually change license to BSD-2
Joel Sherrill
joel at rtems.org
Fri Mar 18 16:21:29 UTC 2022
Updates #3053.
cpukit/libmisc/redirector/stdio-redirect.c | 33 ++++++++++++++++------
1 file changed, 25 insertions(+), 8 deletions(-)
diff --git a/cpukit/libmisc/redirector/stdio-redirect.c b/cpukit/libmisc/redirector/stdio-redirect.c
index 7f3e9138a7..712968ac2d 100644
--- a/cpukit/libmisc/redirector/stdio-redirect.c
+++ b/cpukit/libmisc/redirector/stdio-redirect.c
@@ -1,16 +1,33 @@
- * Copyright (C) 2014 Chris Johns (chrisj at rtems.org)
+ * @file
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution.
- * This software with is provided ``as is'' and with NO WARRANTY.
+ * @brief RTEMS std redirector.
- * RTEMS std redirector.
+ * Copyright (C) 2014 Chris Johns (chrisj at rtems.org)
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
