NTP client recommendation for RTEMS?
Chris Johns
chrisj at rtems.org
Sun Mar 20 22:08:47 UTC 2022
On 24/2/2022 2:03 am, Sebastian Huber wrote:
> On 22/02/2022 21:25, Joel Sherrill wrote:
>> On Tue, Feb 22, 2022, 1:45 PM Sebastian Huber
>> <sebastian.huber at embedded-brains.de
>> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>> On 22/02/2022 20:30, Joel Sherrill wrote:
>> > On Tue, Feb 22, 2022 at 1:21 PM Sebastian Huber
>> >> On 22/02/2022 19:22, Joel Sherrill wrote:
>> >>> Are you planning to get the NTP server side of the freebsd-org
>> code working?
>> >>> Or get it building but not testing it?
>> >>> Or just focusing on building and testing JUST the client part.
>> >> I ported the ntpd from FreeBSD to an older version of the
>> libbsd. I only
>> >> tested the client part and this seems to work fine after some
>> basic tests.
>> > OK. That matches what I expected. Is the libbsd version to old to
>> merge
>> > against? Any plans to merge this?
>> > Alternatively, is your work available to be used as the basis for
>> updating
>> > to 6-freebsd-12?
>> I have a very long TODO list. Actually, I started with the current
>> 6-freebsd-12 branch, but it didn't work, so in principle generating
>> patches for this branch should be easy.
>> Thanks. If we end up working on this, we will sync with you to help and avoid
>> duplicate work.
> I pushed the NTP work to my github repository:
> https://github.com/sebhub/rtems-libbsd/tree/6-freebsd-12-ntpd
> I think we have to revert some changes done for the NFS support.
Please do not. I would prefer the problem be discussed and understood first and
alternatives considered.
> For example, I don't know why the system call support for kqueue and the sockets> moved to a separate file and was changed to use the FreeBSD file descriptors.
The change lets us use FreeBSD fd support and after this work I think the change
is major improvement over the implementation I had to work with. Using RTEMS
direct fd support in mixed ways with VFS in LibBSD would only make things confusing.
