arm (bsp=xilinx_zynq_a9_qemu ) task in 'testsuites/fstests/fsdosfsname01.exe' failed
Sebastian Huber
Tue Mar 22 20:30:29 UTC 2022
Hello Heinz,
On 19/03/2022 16:54, Heinz Junkes wrote:
> Waf: Leaving directory `/home/rtems/ARM_TST/kernel/build/arm/xilinx_zynq_a9_qemu'
> Build failed
> -> task in 'testsuites/fstests/fsdosfsname01.exe' failed with exit status 1 (run with -v to display more information)
> [1714/4241] Linking build/arm/xilinx_zynq_a9_qemu/testsuites/fstests/mimfs_fspermission.exe
> [1715/4241] Linking build/arm/xilinx_zynq_a9_qemu/testsuites/fstests/mdosfs_fsrdwr.exe
> /home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/bin/ld: /home/rtems/ARM_WORK/rtems/6/lib/gcc/arm-rtems6/10.3.1/../../../../arm-rtems6/lib/thumb/armv7-a+simd/hard/libc.a(libc_a-ucsconv.o): in function `ucs_based_conversion_open':
this should be fixed in the latest RSB. The update of the Newlib build
system should be complete now.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
