Store test reports?
Chris Johns
chrisj at rtems.org
Wed Mar 23 22:47:19 UTC 2022
On 24/3/2022 3:38 am, Sebastian Huber wrote:
> I plan to commit the new validation tests tomorrow. Then I will make some test
> runs. The test reports sent to build at rtems.org have only limited value to track
> performance regressions for example.
The test reports sent to that list are archived and could be post processed as a
batch. A procmail filter could then be used to then maintain any batch generated
data. So there is some flexibility with its data.
A mailing list is nice because it is cheap and easy to create tools to send reports.
> Would it make sense to store the full test
> reports in YAML format in an RTEMS repository (for example
> rtems-central/test-reports/arch/bsp/yyyy-mm-dd-commit.yml)?
It would be ideal having in a release the YAML and human digestible reports for
all tier 1 archs. I am not sure that can be achieved because the release's hash
and the tested hash may differ and we do not have a central hardware lab we can
access and use to create the reports when creating the release.
I am not a fan of adding dated files like this to repos. Every time I have done
this I have come to regret it. What about a path on ftp.rtems.org, for example
pub/rtems/reports/validation/6/arch/bsp/yyyy-mm-dd-commit.[yml,pdf] ?
What archs will be supported?
Is there a PDF type report?
