[PATCH rtems] cpukit/libmisc/monitor/: Manually change to BSD-2 license
Thu Mar 24 17:45:18 UTC 2022
This code did not have any copyrights or licenses and a bit
of archeology was needed to determine authorship.
This code was in the initial import into the RTEMS CVS repository when
it was established in May 1995. There was very little, if any, code not
written by OAR Corporation in that initial import.  After discussion
with Chris Johns, it was determined that this code was from OAR
Corporation and that he had added a few features later. Both
Chris Johns and OAR Corporation have given permission to relicense.
Updates #3053.
 cpukit/libmisc/monitor/mon-command.c   | 31 +++++++++++++++++++++--------
 cpukit/libmisc/monitor/mon-config.c    | 31 +++++++++++++++++++++++++++--
 cpukit/libmisc/monitor/mon-driver.c    | 33 +++++++++++++++++++++++++++++--
 cpukit/libmisc/monitor/mon-editor.c    | 29 +++++++++++++++++++--------
 cpukit/libmisc/monitor/mon-extension.c | 31 ++++++++++++++++++++++++++++-
 cpukit/libmisc/monitor/mon-itask.c     | 31 ++++++++++++++++++++++++++++-
 cpukit/libmisc/monitor/mon-manager.c   | 34 ++++++++++++++++++++++++++++++--
 cpukit/libmisc/monitor/mon-monitor.c   | 32 ++++++++++++++++++++++++++++--
 cpukit/libmisc/monitor/mon-mpci.c      | 31 +++++++++++++++++++++++++++--
 cpukit/libmisc/monitor/mon-object.c    | 33 +++++++++++++++++++++++++++++--
 cpukit/libmisc/monitor/mon-part.c      | 31 ++++++++++++++++++++++++++++-
 cpukit/libmisc/monitor/mon-prmisc.c    | 34 +++++++++++++++++++++++++++++---
 cpukit/libmisc/monitor/mon-queue.c     | 33 +++++++++++++++++++++++++++++++
 cpukit/libmisc/monitor/mon-region.c    | 31 ++++++++++++++++++++++++++++-
 cpukit/libmisc/monitor/mon-sema.c      | 31 ++++++++++++++++++++++++++++-
 cpukit/libmisc/monitor/mon-server.c    | 35 +++++++++++++++++++++++++++++++--
 cpukit/libmisc/monitor/mon-symbols.c   | 36 ++++++++++++++++++++++++++++------
 cpukit/libmisc/monitor/mon-task.c      | 31 ++++++++++++++++++++++++++++-
 cpukit/libmisc/monitor/symbols.h       | 34 +++++++++++++++++++++++++++-----
 19 files changed, 562 insertions(+), 50 deletions(-)
diff --git a/cpukit/libmisc/monitor/mon-command.c b/cpukit/libmisc/monitor/mon-command.c
index 64b102b..9ba78cc 100644
--- a/cpukit/libmisc/monitor/mon-command.c
+++ b/cpukit/libmisc/monitor/mon-command.c
@@ -1,3 +1,5 @@
  * @file
@@ -5,15 +7,28 @@
- * 2001-01-30 KJO (vac4050 at cae597.rsc.raytheon.com):
- *  Fixed rtems_monitor_command_lookup() to accept partial
- *  commands to uniqeness.  Added support for setting
- *  the monitor prompt via an environment variable:
- *  RTEMS_MONITOR_PROMPT
+ * COPYRIGHT (c) 2000 Chris Johns <chrisj at rtems.org>
+ * are met:
- * CCJ: 26-3-2000, adding command history and command line
- * editing. This code is donated from My Right Boot and not
- * covered by GPL, only the RTEMS license.
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/libmisc/monitor/mon-config.c b/cpukit/libmisc/monitor/mon-config.c
index d7728de..0f173bf 100644
--- a/cpukit/libmisc/monitor/mon-config.c
+++ b/cpukit/libmisc/monitor/mon-config.c
@@ -1,7 +1,34 @@
+ * @file
+ * @brief RTEMS Config display support
- * RTEMS Config display support
+ * COPYRIGHT (c) 1989-2022. On-Line Applications Research Corporation (OAR).
+ * are met:
- * TODO
diff --git a/cpukit/libmisc/monitor/mon-driver.c b/cpukit/libmisc/monitor/mon-driver.c
index e2e95ff..38c04c5 100644
--- a/cpukit/libmisc/monitor/mon-driver.c
+++ b/cpukit/libmisc/monitor/mon-driver.c
@@ -1,5 +1,9 @@
- * RTEMS monitor IO (device drivers) support
+ * @file
+ * @brief RTEMS monitor IO (device drivers) support
  * There are 2 "driver" things the monitor knows about.
@@ -17,6 +21,31 @@
  *  Names are displayed with 'name' command.
+ * are met:
 #include "config.h"
 #endif
diff --git a/cpukit/libmisc/monitor/mon-editor.c b/cpukit/libmisc/monitor/mon-editor.c
index 6957fee..4bc5064 100644
--- a/cpukit/libmisc/monitor/mon-editor.c
+++ b/cpukit/libmisc/monitor/mon-editor.c
@@ -5,15 +5,28 @@
+ * are met:
diff --git a/cpukit/libmisc/monitor/mon-extension.c b/cpukit/libmisc/monitor/mon-extension.c
index 029d26c..53bfe32 100644
--- a/cpukit/libmisc/monitor/mon-extension.c
+++ b/cpukit/libmisc/monitor/mon-extension.c
@@ -1,5 +1,34 @@
+ * @file
+ * @brief RTEMS Monitor extension support
- * RTEMS Monitor extension support
+ * are met:
diff --git a/cpukit/libmisc/monitor/mon-itask.c b/cpukit/libmisc/monitor/mon-itask.c
index f4d3aea..262fc07 100644
--- a/cpukit/libmisc/monitor/mon-itask.c
+++ b/cpukit/libmisc/monitor/mon-itask.c
@@ -1,5 +1,34 @@
+ * @file
+ * @brief RTEMS Monitor init task support
- * RTEMS Monitor init task support
+ * are met:
diff --git a/cpukit/libmisc/monitor/mon-manager.c b/cpukit/libmisc/monitor/mon-manager.c
index d165c4f..1e2cc2f 100644
--- a/cpukit/libmisc/monitor/mon-manager.c
+++ b/cpukit/libmisc/monitor/mon-manager.c
@@ -1,8 +1,38 @@
- * RTEMS Monitor "manager" support.
+ * @file
+ * @brief RTEMS Monitor "manager" support.
  * Used to traverse object (chain) lists and print them out.
+ * are met:
 #include "config.h"
 #endif
diff --git a/cpukit/libmisc/monitor/mon-monitor.c b/cpukit/libmisc/monitor/mon-monitor.c
index 9c099dc..0d5337f 100644
--- a/cpukit/libmisc/monitor/mon-monitor.c
+++ b/cpukit/libmisc/monitor/mon-monitor.c
@@ -1,5 +1,9 @@
- * RTEMS monitor main body
+ * @file
+ * @brief RTEMS monitor main body
  *  TODO:
  *      add stuff to RTEMS api
@@ -20,6 +24,30 @@
  *           interrupt config stuff
+ * are met:
 #include "config.h"
 #endif
diff --git a/cpukit/libmisc/monitor/mon-mpci.c b/cpukit/libmisc/monitor/mon-mpci.c
index f6914aa..033a997 100644
--- a/cpukit/libmisc/monitor/mon-mpci.c
+++ b/cpukit/libmisc/monitor/mon-mpci.c
@@ -1,7 +1,34 @@
+ * @file
+ * @brief RTEMS MPCI Config display support
- * RTEMS MPCI Config display support
+ * are met:
- * TODO
diff --git a/cpukit/libmisc/monitor/mon-object.c b/cpukit/libmisc/monitor/mon-object.c
index 039d11f..fecf900 100644
--- a/cpukit/libmisc/monitor/mon-object.c
+++ b/cpukit/libmisc/monitor/mon-object.c
@@ -1,5 +1,9 @@
- * RTEMS Monitor "object" support.
+ * @file
+ * @brief RTEMS Monitor "object" support.
  * Used to traverse object lists and print them out.
  * An object can be an RTEMS object (chain based stuff) or
@@ -13,6 +17,31 @@
  *     should allow for non-numeric id's???
+ * are met:
 #include "config.h"
 #endif
diff --git a/cpukit/libmisc/monitor/mon-part.c b/cpukit/libmisc/monitor/mon-part.c
index 654700e..e049f4a 100644
--- a/cpukit/libmisc/monitor/mon-part.c
+++ b/cpukit/libmisc/monitor/mon-part.c
@@ -1,5 +1,34 @@
+ * @file
+ * @brief RTEMS Monitor partition support
- * RTEMS Monitor partition support
+ * are met:
diff --git a/cpukit/libmisc/monitor/mon-prmisc.c b/cpukit/libmisc/monitor/mon-prmisc.c
index 97862ff..d7b3627 100644
--- a/cpukit/libmisc/monitor/mon-prmisc.c
+++ b/cpukit/libmisc/monitor/mon-prmisc.c
@@ -1,8 +1,36 @@
- * Print misc stuff for the monitor dump routines
+ * @file
+ * @brief Print misc stuff for the monitor dump routines
  * Each routine returns the number of characters it output.
+ * are met:
- * TODO:
diff --git a/cpukit/libmisc/monitor/mon-queue.c b/cpukit/libmisc/monitor/mon-queue.c
index aadfcd3..374ce52 100644
--- a/cpukit/libmisc/monitor/mon-queue.c
+++ b/cpukit/libmisc/monitor/mon-queue.c
@@ -1,3 +1,36 @@
+ * @file
+ * @brief Monitor Support for Message Queues
+ * are met:
 #include "config.h"
 #endif
diff --git a/cpukit/libmisc/monitor/mon-region.c b/cpukit/libmisc/monitor/mon-region.c
index ece6a6a..4b894ae 100644
--- a/cpukit/libmisc/monitor/mon-region.c
+++ b/cpukit/libmisc/monitor/mon-region.c
@@ -1,5 +1,34 @@
+ * @file
+ * @brief RTEMS Monitor region support
- * RTEMS Monitor region support
+ * are met:
diff --git a/cpukit/libmisc/monitor/mon-sema.c b/cpukit/libmisc/monitor/mon-sema.c
index fabc3c9..58eab14 100644
--- a/cpukit/libmisc/monitor/mon-sema.c
+++ b/cpukit/libmisc/monitor/mon-sema.c
@@ -1,5 +1,34 @@
+ * @file
+ * @brief RTEMS Monitor semaphore support
- * RTEMS Monitor semaphore support
+ * are met:
diff --git a/cpukit/libmisc/monitor/mon-server.c b/cpukit/libmisc/monitor/mon-server.c
index d8a1687..579fc77 100644
--- a/cpukit/libmisc/monitor/mon-server.c
+++ b/cpukit/libmisc/monitor/mon-server.c
@@ -1,6 +1,37 @@
+ * @file
+ * @brief RTEMS monitor server
+ * This handles requests for info from RTEMS monitors running on
+ * other nodes.
- * RTEMS monitor server (handles requests for info from RTEMS monitors
- *             running on other nodes)
+ * are met:
diff --git a/cpukit/libmisc/monitor/mon-symbols.c b/cpukit/libmisc/monitor/mon-symbols.c
index d3f0bef..1f59493 100644
--- a/cpukit/libmisc/monitor/mon-symbols.c
+++ b/cpukit/libmisc/monitor/mon-symbols.c
@@ -1,12 +1,36 @@
- *  File: symbols.c
+ * @file
+ * @brief Symbol table manager for the RTEMS monitor
- *  Description:
- *    Symbol table manager for the RTEMS monitor.
- *    These routines may be used by other system resources also.
+ * These routines may be used by other system resources also.
+ * are met:
- *  TODO:
diff --git a/cpukit/libmisc/monitor/mon-task.c b/cpukit/libmisc/monitor/mon-task.c
index bb2c49e..0e925a1 100644
--- a/cpukit/libmisc/monitor/mon-task.c
+++ b/cpukit/libmisc/monitor/mon-task.c
@@ -1,5 +1,34 @@
+ * @file
+ * @brief RTEMS Monitor task support
- * RTEMS Monitor task support
+ * are met:
diff --git a/cpukit/libmisc/monitor/symbols.h b/cpukit/libmisc/monitor/symbols.h
index 1455edb..7d330ba 100644
--- a/cpukit/libmisc/monitor/symbols.h
+++ b/cpukit/libmisc/monitor/symbols.h
@@ -1,12 +1,36 @@
- *  RTEMS monitor symbol table functions
+ * @file
- *  Description:
- *      Entry points for symbol table routines.
+ * @brief RTEMS monitor symbol table functions
+ * Entry points for symbol table routines.
+ * are met:
- *  TODO:
 #ifndef _INCLUDE_SYMBOLS_H
1.8.3.1
