[PATCH 5/7] cpukit/include/pci: Change license to BSD-2
Thu Mar 24 22:06:04 UTC 2022
Updates #3053.
 cpukit/include/pci/access.h         | 36 +++++++++++++++++++++++++----
 cpukit/include/pci/cfg.h            | 32 +++++++++++++++++++++----
 cpukit/include/pci/cfg_auto.h       | 32 +++++++++++++++++++++----
 cpukit/include/pci/cfg_peripheral.h | 32 +++++++++++++++++++++----
 cpukit/include/pci/cfg_read.h       | 35 ++++++++++++++++++++++++----
 cpukit/include/pci/cfg_static.h     | 32 +++++++++++++++++++++----
 cpukit/include/pci/irq.h            | 32 +++++++++++++++++++++----
 7 files changed, 201 insertions(+), 30 deletions(-)
diff --git a/cpukit/include/pci/access.h b/cpukit/include/pci/access.h
index 4337db30c3..361a8bb556 100644
--- a/cpukit/include/pci/access.h
+++ b/cpukit/include/pci/access.h
@@ -1,11 +1,37 @@
-/* Routines to access PCI memory/configuration space and other PCI related
- * functions the PCI Library provides.
+ * @file
+ * @brief PCI Access Methods
+ * Routines to access PCI memory/configuration space and other PCI related
+ * functions the PCI Library provides.
  * COPYRIGHT (c) 2010 Cobham Gaisler AB.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
diff --git a/cpukit/include/pci/cfg.h b/cpukit/include/pci/cfg.h
index 1f55c85971..5d6d1c085c 100644
--- a/cpukit/include/pci/cfg.h
+++ b/cpukit/include/pci/cfg.h
@@ -1,10 +1,34 @@
-/* PCI Configuration Library
+ * @file
+ * @brief PCI Configuration Library
+ * are met:
 /* Four versions of the library exists:
diff --git a/cpukit/include/pci/cfg_auto.h b/cpukit/include/pci/cfg_auto.h
index e374e2e2d4..a9de3684d0 100644
--- a/cpukit/include/pci/cfg_auto.h
+++ b/cpukit/include/pci/cfg_auto.h
@@ -1,10 +1,34 @@
-/* PCI Auto Configuration Library
+ * @file
+ * @brief PCI Auto Configuration Library
+ * are met:
 #ifndef __PCI_CFG_AUTO_H__
diff --git a/cpukit/include/pci/cfg_peripheral.h b/cpukit/include/pci/cfg_peripheral.h
index f05c8257c6..693735ca38 100644
--- a/cpukit/include/pci/cfg_peripheral.h
+++ b/cpukit/include/pci/cfg_peripheral.h
@@ -1,10 +1,34 @@
-/* PCI Peripheral Configuration Library
+ * @file
+ * @brie PCI Peripheral Configuration Libraryf
+ * are met:
 #ifndef __PCI_CFG_PERIPHERAL_H__
diff --git a/cpukit/include/pci/cfg_read.h b/cpukit/include/pci/cfg_read.h
index 3dd7678279..6f40288c14 100644
--- a/cpukit/include/pci/cfg_read.h
+++ b/cpukit/include/pci/cfg_read.h
@@ -1,11 +1,36 @@
-/* PCI Read Configuration Library. Read current config that bootloader/BIOS
- * has setup.
+ * @file
+ * @brief PCI Read Configuration Library
+ * Read current config where bootloader/BIOS has setup.
+ * are met:
diff --git a/cpukit/include/pci/cfg_static.h b/cpukit/include/pci/cfg_static.h
index 62ee0dad7d..f510e35d7e 100644
--- a/cpukit/include/pci/cfg_static.h
+++ b/cpukit/include/pci/cfg_static.h
@@ -1,10 +1,34 @@
-/* Static PCI Auto Configuration Library
+ * @file
+ * @brief Static PCI Auto Configuration Library
+ * are met:
 #ifndef __PCI_CFG_STATIC_H__
diff --git a/cpukit/include/pci/irq.h b/cpukit/include/pci/irq.h
index 7622201fd6..f899374ae7 100644
--- a/cpukit/include/pci/irq.h
+++ b/cpukit/include/pci/irq.h
@@ -1,10 +1,34 @@
-/* PCI IRQ Library
+ * @file
+ * @brief PCI IRQ Library
+ * are met:
 /* IRQ handling does not have so much with PCI to do, this library depends
2.24.4
