[PATCH 7/7] cpukit/include/sys: Change license to BSD-2.
Joel Sherrill
joel at rtems.org
Thu Mar 24 22:06:06 UTC 2022
Updates #3053.
cpukit/include/rtems/bspcmdline.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/btimer.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/chain.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/clockdrv.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/console.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/deviceio.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/devnull.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/dumpbuf.h | 29 +++++++++++++++++++++++-----
cpukit/include/rtems/extensiondata.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/extensionimpl.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/framebuffer.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/fs.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/inttypes.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/ioimpl.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/iosupp.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/libcsupport.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/malloc.h | 29 +++++++++++++++++++++++-----
cpukit/include/rtems/mptables.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/rtc.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/serial_mouse.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/seterr.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/shellconfig.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/spurious.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/stackchk.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/stringto.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/termiostypes.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/userenv.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/vmeintr.h | 25 +++++++++++++++++++++---
cpukit/include/rtems/watchdogdrv.h | 25 +++++++++++++++++++++---
cpukit/include/sys/statvfs.h | 25 +++++++++++++++++++++---
cpukit/include/sys/utsname.h | 25 +++++++++++++++++++++---
31 files changed, 686 insertions(+), 97 deletions(-)
diff --git a/cpukit/include/rtems/bspcmdline.h b/cpukit/include/rtems/bspcmdline.h
index fea73fcc37..29f2cde7d5 100644
--- a/cpukit/include/rtems/bspcmdline.h
+++ b/cpukit/include/rtems/bspcmdline.h
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
* COPYRIGHT (c) 1989-2009.
* On-Line Applications Research Corporation (OAR).
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
- * http://www.rtems.org/license/LICENSE.
+ * are met:
+ * notice, this list of conditions and the following disclaimer.
+ * notice, this list of conditions and the following disclaimer in the
+ * documentation and/or other materials provided with the distribution.
#ifndef __BSP_COMMAND_LINE_h
diff --git a/cpukit/include/rtems/btimer.h b/cpukit/include/rtems/btimer.h
index a2eee251e9..dff726769e 100644
--- a/cpukit/include/rtems/btimer.h
+++ b/cpukit/include/rtems/btimer.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/cpukit/include/rtems/chain.h b/cpukit/include/rtems/chain.h
index 03177834a9..da08ddcfdd 100644
--- a/cpukit/include/rtems/chain.h
+++ b/cpukit/include/rtems/chain.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* COPYRIGHT (c) 1989-2008.
+ * are met:
#ifndef _RTEMS_CHAIN_H
diff --git a/cpukit/include/rtems/clockdrv.h b/cpukit/include/rtems/clockdrv.h
index f3df912e74..3d3a62a63f 100644
--- a/cpukit/include/rtems/clockdrv.h
+++ b/cpukit/include/rtems/clockdrv.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* COPYRIGHT (c) 1989-2011.
+ * are met:
#ifndef _RTEMS_CLOCKDRV_H
diff --git a/cpukit/include/rtems/console.h b/cpukit/include/rtems/console.h
index 522e6fef41..7a7ad7a936 100644
--- a/cpukit/include/rtems/console.h
+++ b/cpukit/include/rtems/console.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_CONSOLE_H
diff --git a/cpukit/include/rtems/deviceio.h b/cpukit/include/rtems/deviceio.h
index a448fc7bb4..d598decb49 100644
--- a/cpukit/include/rtems/deviceio.h
+++ b/cpukit/include/rtems/deviceio.h
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
* COPYRIGHT (c) 1989-2012.
+ * are met:
#ifndef _RTEMS_DEVICEIO_H
diff --git a/cpukit/include/rtems/devnull.h b/cpukit/include/rtems/devnull.h
index cb5d078d52..a6c20b9da3 100644
--- a/cpukit/include/rtems/devnull.h
+++ b/cpukit/include/rtems/devnull.h
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* COPYRIGHT (c) 1989-2000.
+ * are met:
#ifndef _RTEMS_DEVNULL_H
diff --git a/cpukit/include/rtems/dumpbuf.h b/cpukit/include/rtems/dumpbuf.h
index 690ac63341..f3a10733c7 100644
--- a/cpukit/include/rtems/dumpbuf.h
+++ b/cpukit/include/rtems/dumpbuf.h
@@ -1,3 +1,5 @@
* @file
@@ -8,12 +10,29 @@
- * COPYRIGHT (c) 1997-2011.
- * On-Line Applications Research Corporation (OAR).
+ * COPYRIGHT (c) 1997-2011.
+ * On-Line Applications Research Corporation (OAR).
+ * are met:
- * The license and distribution terms for this file may in
- * the file LICENSE in this distribution or at
#ifndef __DUMP_BUFFER_h
diff --git a/cpukit/include/rtems/extensiondata.h b/cpukit/include/rtems/extensiondata.h
index 8872e2c569..776ea9f696 100644
--- a/cpukit/include/rtems/extensiondata.h
+++ b/cpukit/include/rtems/extensiondata.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_EXTENSIONDATA_H
diff --git a/cpukit/include/rtems/extensionimpl.h b/cpukit/include/rtems/extensionimpl.h
index 502aac87ca..f90d1df5f4 100644
--- a/cpukit/include/rtems/extensionimpl.h
+++ b/cpukit/include/rtems/extensionimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
#ifndef _RTEMS_EXTENSIONIMPL_H
diff --git a/cpukit/include/rtems/framebuffer.h b/cpukit/include/rtems/framebuffer.h
index 7828be1cf8..6a9a9e4e26 100644
--- a/cpukit/include/rtems/framebuffer.h
+++ b/cpukit/include/rtems/framebuffer.h
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
#ifndef __RTEMS_FRAMEBUFFER_h__
diff --git a/cpukit/include/rtems/fs.h b/cpukit/include/rtems/fs.h
index 90e9eb8dd6..b52f675828 100644
--- a/cpukit/include/rtems/fs.h
+++ b/cpukit/include/rtems/fs.h
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
* Modifications to support reference counting in the file system are
* Copyright (c) 2012 embedded brains GmbH.
+ * are met:
#ifndef _RTEMS_FS_H
diff --git a/cpukit/include/rtems/inttypes.h b/cpukit/include/rtems/inttypes.h
index 4914629234..463b1e948a 100644
--- a/cpukit/include/rtems/inttypes.h
+++ b/cpukit/include/rtems/inttypes.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* COPYRIGHT (c) 2017 On-Line Applications Research Corporation.
+ * are met:
#ifndef _RTEMS_INTTYPES_H
diff --git a/cpukit/include/rtems/ioimpl.h b/cpukit/include/rtems/ioimpl.h
index df2cc8d43e..dff474dcac 100644
--- a/cpukit/include/rtems/ioimpl.h
+++ b/cpukit/include/rtems/ioimpl.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_IOIMPL_H
diff --git a/cpukit/include/rtems/iosupp.h b/cpukit/include/rtems/iosupp.h
index 84ede0bd74..efdba124cb 100644
--- a/cpukit/include/rtems/iosupp.h
+++ b/cpukit/include/rtems/iosupp.h
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
#ifndef _RTEMS_IOSUPP_H
diff --git a/cpukit/include/rtems/libcsupport.h b/cpukit/include/rtems/libcsupport.h
index f4be4cfc9a..212eb16e59 100644
--- a/cpukit/include/rtems/libcsupport.h
+++ b/cpukit/include/rtems/libcsupport.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
+ * are met:
#ifndef _RTEMS_RTEMS_LIBCSUPPORT_H
diff --git a/cpukit/include/rtems/malloc.h b/cpukit/include/rtems/malloc.h
index c0d15fbf72..7d7f8fa677 100644
--- a/cpukit/include/rtems/malloc.h
+++ b/cpukit/include/rtems/malloc.h
@@ -1,3 +1,5 @@
* @file
@@ -5,12 +7,29 @@
- * COPYRIGHT (c) 1989-2011.
+ * COPYRIGHT (c) 1989-2011.
+ * are met:
#ifndef _RTEMS_MALLOC_H
diff --git a/cpukit/include/rtems/mptables.h b/cpukit/include/rtems/mptables.h
index 01e5b653b4..2f67000d2a 100644
--- a/cpukit/include/rtems/mptables.h
+++ b/cpukit/include/rtems/mptables.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
#ifndef _RTEMS_MPTABLES_H
diff --git a/cpukit/include/rtems/rtc.h b/cpukit/include/rtems/rtc.h
index 9906acd425..5d37ea4289 100644
--- a/cpukit/include/rtems/rtc.h
+++ b/cpukit/include/rtems/rtc.h
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
* COPYRIGHT (c) 1989-2001.
+ * are met:
#ifndef _RTEMS_RTC_H
diff --git a/cpukit/include/rtems/serial_mouse.h b/cpukit/include/rtems/serial_mouse.h
index 174fcfb909..9765b5af3d 100644
--- a/cpukit/include/rtems/serial_mouse.h
+++ b/cpukit/include/rtems/serial_mouse.h
@@ -1,3 +1,5 @@
* @file
@@ -16,9 +18,26 @@
+ * are met:
#ifndef __SERIAL_MOUSE_h__
diff --git a/cpukit/include/rtems/seterr.h b/cpukit/include/rtems/seterr.h
index adce762dc9..6fec3be369 100644
--- a/cpukit/include/rtems/seterr.h
+++ b/cpukit/include/rtems/seterr.h
@@ -1,3 +1,5 @@
* @file
@@ -11,9 +13,26 @@
* COPYRIGHT (c) 1989-2006.
+ * are met:
#ifndef _RTEMS_SETERR_H
diff --git a/cpukit/include/rtems/shellconfig.h b/cpukit/include/rtems/shellconfig.h
index c5fcf4a45e..b09d5ae1d3 100644
--- a/cpukit/include/rtems/shellconfig.h
+++ b/cpukit/include/rtems/shellconfig.h
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
#ifndef _RTEMS_SHELL_CONFIG_h
diff --git a/cpukit/include/rtems/spurious.h b/cpukit/include/rtems/spurious.h
index 2bddeeb3c8..e866098df2 100644
--- a/cpukit/include/rtems/spurious.h
+++ b/cpukit/include/rtems/spurious.h
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
#ifndef _RTEMS_SPURIOUS_H
diff --git a/cpukit/include/rtems/stackchk.h b/cpukit/include/rtems/stackchk.h
index b600bae3a7..22d48c9d2b 100644
--- a/cpukit/include/rtems/stackchk.h
+++ b/cpukit/include/rtems/stackchk.h
@@ -1,3 +1,5 @@
* @file
@@ -13,9 +15,26 @@
+ * are met:
#ifndef _RTEMS_STACKCHK_H
diff --git a/cpukit/include/rtems/stringto.h b/cpukit/include/rtems/stringto.h
index 8389219fe8..0f98710946 100644
--- a/cpukit/include/rtems/stringto.h
+++ b/cpukit/include/rtems/stringto.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* COPYRIGHT (c) 2009-2011.
+ * are met:
#ifndef _RTEMS_STRINGTO_H
diff --git a/cpukit/include/rtems/termiostypes.h b/cpukit/include/rtems/termiostypes.h
index 5821d52775..33fcf4b2da 100644
--- a/cpukit/include/rtems/termiostypes.h
+++ b/cpukit/include/rtems/termiostypes.h
@@ -1,3 +1,5 @@
* @file
@@ -8,9 +10,26 @@
+ * are met:
#ifndef __TERMIOSTYPES_H
diff --git a/cpukit/include/rtems/userenv.h b/cpukit/include/rtems/userenv.h
index 2b66ee0951..0161d6a554 100644
--- a/cpukit/include/rtems/userenv.h
+++ b/cpukit/include/rtems/userenv.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
#ifndef _RTEMS_USERENV_H
diff --git a/cpukit/include/rtems/vmeintr.h b/cpukit/include/rtems/vmeintr.h
index 74bda9bf08..0c9f94ac2f 100644
--- a/cpukit/include/rtems/vmeintr.h
+++ b/cpukit/include/rtems/vmeintr.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
#ifndef _RTEMS_VMEINTR_H
diff --git a/cpukit/include/rtems/watchdogdrv.h b/cpukit/include/rtems/watchdogdrv.h
index f05ea80938..c30e764969 100644
--- a/cpukit/include/rtems/watchdogdrv.h
+++ b/cpukit/include/rtems/watchdogdrv.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
+ * are met:
#ifndef _RTEMS_WATCHDOGDRV_H
diff --git a/cpukit/include/sys/statvfs.h b/cpukit/include/sys/statvfs.h
index e065a1b46e..52d8e9d3fa 100644
--- a/cpukit/include/sys/statvfs.h
+++ b/cpukit/include/sys/statvfs.h
@@ -1,3 +1,5 @@
* @file
@@ -12,9 +14,26 @@
* COPYRIGHT (c) 2009 Chris Johns <chrisj at rtems.org>
+ * are met:
diff --git a/cpukit/include/sys/utsname.h b/cpukit/include/sys/utsname.h
index ddeb0e90c2..1df27d1992 100644
--- a/cpukit/include/sys/utsname.h
+++ b/cpukit/include/sys/utsname.h
@@ -1,3 +1,5 @@
* @file
@@ -10,9 +12,26 @@
+ * are met:
#ifndef __POSIX_SYS_UTSNAME_h
2.24.4
