[PATCH v2 1/1] newlib01: Check exit procs for global FILE obj
Mon Mar 28 21:13:01 UTC 2022
I don't see anything obviously wrong but I don't have any idea what the
test is actually trying to exercise.
How about some comments and is there a doc file in this test directory that
needs updating?
--joel
On Mon, Mar 28, 2022 at 4:04 AM Matthew Joyce <
matthew.joyce at embedded-brains.de> wrote:
> From: Matt Joyce <matthew.joyce at embedded-brains.de>
>  testsuites/libtests/newlib01/init.c | 110 ++++++++++++++++++++++------
>  1 file changed, 88 insertions(+), 22 deletions(-)
> diff --git a/testsuites/libtests/newlib01/init.c
> b/testsuites/libtests/newlib01/init.c
> index c58154023b..bba187e8e2 100644
> --- a/testsuites/libtests/newlib01/init.c
> +++ b/testsuites/libtests/newlib01/init.c
> @@ -28,6 +28,8 @@ const char rtems_test_name[] = "NEWLIB 1";
>  static const char file_path[] = "/file";
> +static const char file_path2[] = "/file2";
>  typedef enum {
>    INIT,
>    OPEN,
> @@ -39,6 +41,8 @@ typedef struct {
>    rtems_id main_task_id;
>    rtems_id worker_task_id;
>    test_state current;
> +  FILE *glob_file_stream;
> +  int glob_fd;
>  } test_context;
>  static test_context test_instance;
> @@ -59,7 +63,7 @@ static void wait(void)
>    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> -static void worker_task(rtems_task_argument arg)
> +static void thread_specific_worker(rtems_task_argument arg)
>    test_context *ctx = &test_instance;
>    struct _reent *reent = _REENT;
> @@ -90,6 +94,30 @@ static void worker_task(rtems_task_argument arg)
>    rtems_test_assert(0);
> +static void global_file_object_worker(rtems_task_argument arg)
> +  test_context *ctx = &test_instance;
> +  FILE *fp;
> +  char buf[1] = { 'y' };
> +  size_t n;
> +  int fd;
> +  fp = ctx->glob_file_stream = fopen(&file_path2[0], "w");
> +  rtems_test_assert(fp != NULL);
> +  /* Get file descriptor of new global file stream, store it in text
> context */
> +  fd = fileno(fp);
> +  rtems_test_assert(fd != -1);
> +  ctx->glob_fd = fd;
> +  n = fwrite(&buf[0], sizeof(buf), 1, fp);
> +  rtems_test_assert(n == 1);
> +  wake_up_main(ctx);
> +  rtems_test_assert(0);
>  static int handler_open(
>    rtems_libio_t *iop,
>    const char *path,
> @@ -250,9 +278,34 @@ static const IMFS_node_control node_control =
> IMFS_GENERIC_INITIALIZER(
>    IMFS_node_destroy_default
> -static void test_thread_specific_close(test_context *ctx)
> +static void task_create_and_delete_helper(
> +  test_context *ctx,
> +  rtems_task_entry entry
>    rtems_status_code sc;
> +  sc = rtems_task_create(
> +  rtems_build_name('W', 'O', 'R', 'K'),
> +  2,
> +  RTEMS_MINIMUM_STACK_SIZE,
> +  RTEMS_DEFAULT_MODES,
> +  RTEMS_DEFAULT_ATTRIBUTES,
> +  &ctx->worker_task_id
> +  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> +  sc = rtems_task_start(ctx->worker_task_id, entry, 0);
> +  wait();
> +  sc = rtems_task_delete(ctx->worker_task_id);
> +static void test_thread_specific_close(test_context *ctx)
>    int rv;
>    rtems_resource_snapshot snapshot;
> @@ -266,23 +319,7 @@ static void test_thread_specific_close(test_context
> *ctx)
>    rtems_test_assert(rv == 0);
> -  sc = rtems_task_create(
> -    rtems_build_name('W', 'O', 'R', 'K'),
> -    2,
> -    RTEMS_MINIMUM_STACK_SIZE,
> -    RTEMS_DEFAULT_MODES,
> -    RTEMS_DEFAULT_ATTRIBUTES,
> -    &ctx->worker_task_id
> -  rtems_test_assert(sc == RTEMS_SUCCESSFUL);
> -  sc = rtems_task_start(ctx->worker_task_id, worker_task, 0);
> -  wait();
> -  sc = rtems_task_delete(ctx->worker_task_id);
> +  task_create_and_delete_helper(ctx, thread_specific_worker);
>    rv = unlink(&file_path[0]);
> @@ -290,6 +327,11 @@ static void test_thread_specific_close(test_context
> *ctx)
>    rtems_test_assert(rtems_resource_snapshot_check(&snapshot));
> +static void test_global_file_object_close(test_context *ctx)
> +  task_create_and_delete_helper(ctx, global_file_object_worker);
>   * This exit handler will be called last among the functions registered
> with
>   * atexit(). Check that stdio file descriptors are closed. The Newlib
> cleanup
> @@ -298,6 +340,7 @@ static void test_thread_specific_close(test_context
> *ctx)
>  static void check_after_libio_exit(void)
>    struct stat unused;
>    int rv;
> @@ -319,6 +362,11 @@ static void check_after_libio_exit(void)
>    rtems_test_assert(stdin->_flags != 0);
>    rtems_test_assert(stdout->_flags != 0);
>    rtems_test_assert(stderr->_flags != 0);
> +  /* Global file tests. Global fd still open at this point. */
> +  rv = fstat(ctx->glob_fd, &unused);
> +  rtems_test_assert(rv == 0);
> +  rtems_test_assert(ctx->glob_file_stream->_flags != 0);
>  static void register_exit_handler_before_libio_exit(void)
> @@ -342,7 +390,7 @@
> RTEMS_SYSINIT_ITEM(register_exit_handler_before_libio_exit,
>   * cleanup procedures have been called. Therefore, stdio file descriptors
>   * should be open and stdio FILE object flags should be non-zero.
> -static void test_exit_handling(void)
> +static void test_exit_handling(test_context *ctx)
>    struct stat unused;
>    int rv;
> @@ -360,6 +408,14 @@ static void test_exit_handling(void)
> +   * Global file descriptor should still be open; global FILE object flags
> +   * should still be non-zero.
>    /* Run exit handlers and Newlib cleanup procedures */
>    exit(0);
> @@ -380,7 +436,8 @@ static void Init(rtems_task_argument arg)
>    test_thread_specific_close(ctx);
> -  test_exit_handling();
> +  test_global_file_object_close(ctx);
> +  test_exit_handling(ctx);
>  static void fatal_extension(
> @@ -400,6 +457,7 @@ static void fatal_extension(
>      struct stat unused;
>      int rv;
>      errno = 0;
>      rv = fstat(0, &unused);
> @@ -419,6 +477,14 @@ static void fatal_extension(
>      rtems_test_assert(stdin->_flags == 0);
>      rtems_test_assert(stdout->_flags == 0);
>      rtems_test_assert(stderr->_flags == 0);
> +    /* Global file tests */
> +    errno = 0;
> +    rtems_test_assert(rv == -1);
> +    rtems_test_assert(errno == EBADF);
> +    rtems_test_assert(ctx->glob_file_stream->_flags == 0);
>      TEST_END();
> @@ -426,7 +492,7 @@ static void fatal_extension(
>  #define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
>  #define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
> -#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 4
> +#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 5
>  #define CONFIGURE_MAXIMUM_TASKS 2
> 2.31.1
> devel mailing list
> devel at rtems.org
