GSoC: Hello World Patch
Tue Mar 29 20:03:03 UTC 2022
On Tue, Mar 29, 2022 at 2:59 PM Kamlesh Bharodiya <brkamleshg678 at gmail.com>
wrote:
> Hi Joel,
> I had tried to run the program using integrated simulator with gdb. That
> didn't work for me (need to figure out).
Hmm.. sis as integrated with gdb was disabled in favor of the more powerful
standalone newer versions of sis. This happened before COVID if I
remember correctly.
Where did you find the instructions? We had a lot of instructions built up
around using sis for the erc32 as built into gdb. You may have stumbled
across a place we have missed updating.
> However, I could run it with remote target SIS connected with GDB as well
> as with Emulator. I am attaching the screenshots.
That is what is intended. Looks great. Make sure you are in the table in
the wiki I cited.
And start looking at projects and asking questions.
--joel
> Regards,
> Kamlesh
> On Tue, Mar 29, 2022 at 12:21 AM Joel Sherrill <joel at rtems.org> wrote:
>> Looks good. Email (or send it to me on Discord) a screenshot in gdb with
>> that program.
>> Then add yourself  to https://devel.rtems.org/wiki/GSoC/2022
>> Feel free to discuss any projects you are interested in here or Discord.
>> On Mon, Mar 28, 2022 at 1:10 PM Kamlesh Bharodiya <
>> brkamleshg678 at gmail.com> wrote:
>>> Hi,
>>> I would like to participate in the GSoC 2022 Program. I have built and
>>> run
>>> the Hello World Program. Please find below: (also attaching the patch)
>>> commit bdd1ae76926135fbadc7920eefe6a303342e4a19 (HEAD -> master)
>>> Author: Kamlesh_Bharodiya <brkamleshg678 at gmail.com>
>>> Date:   Sun Mar 27 22:22:47 2022 +0530
>>> [GSoC Entry] Modified Hello World Test
>>> diff --git a/testsuites/samples/hello/init.c
>>> b/testsuites/samples/hello/init.c
>>> index 34ded37c55..f4288833f9 100644
>>> --- a/testsuites/samples/hello/init.c
>>> +++ b/testsuites/samples/hello/init.c
>>> @@ -22,7 +22,7 @@ static rtems_task Init(
>>>    rtems_print_printer_fprintf_putc(&rtems_test_printer);
>>>    TEST_BEGIN();
>>> -  printf( "Hello World\n" );
>>> +  printf( "Hello to the World of RTEMS\n" );
>>>    TEST_END();
>>>    rtems_test_exit( 0 );
>>> Regards,
>>> Kamlesh
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
