[PATCH 2/3] unit: Add test for misaligned builtin memcpy()
    Sebastian Huber
    Wed Mar 30 07:13:44 UTC 2022
 .../build/testsuites/unit/unit-no-clock-0.yml |  1 +
 .../unit/tc-misaligned-builtin-memcpy.c       | 51 +++++++++++++++++++
 2 files changed, 52 insertions(+)
 create mode 100644 testsuites/unit/tc-misaligned-builtin-memcpy.c
diff --git a/spec/build/testsuites/unit/unit-no-clock-0.yml b/spec/build/testsuites/unit/unit-no-clock-0.yml
index 55cd0abc54..e742bd11f3 100644
--- a/spec/build/testsuites/unit/unit-no-clock-0.yml
+++ b/spec/build/testsuites/unit/unit-no-clock-0.yml
@@ -11,6 +11,7 @@ includes: []
 ldflags: []
 links: []
 source:
+- testsuites/unit/tc-misaligned-builtin-memcpy.c
 - testsuites/unit/ts-unit-no-clock-0.c
 stlib: []
 target: testsuites/unit/ts-unit-no-clock-0.exe
diff --git a/testsuites/unit/tc-misaligned-builtin-memcpy.c b/testsuites/unit/tc-misaligned-builtin-memcpy.c
new file mode 100644
index 0000000000..2021a68551
--- /dev/null
+++ b/testsuites/unit/tc-misaligned-builtin-memcpy.c
@@ -0,0 +1,51 @@
+ * Copyright (C) 2019 embedded brains GmbH (http://www.embedded-brains.de)
+ * are met:
+#include <string.h>
+#include <rtems.h>
+#include <rtems/test.h>
+T_TEST_CASE(MisalignedBuiltinMemcpy)
+	double a;
+	double b;
+	char buf[2 * sizeof(double)];
+	void *p;
+	p = &buf[0];
+	p = (void *)((uintptr_t)p | 1);
+	RTEMS_OBFUSCATE_VARIABLE(p);
+	a = 123e4;
+	RTEMS_OBFUSCATE_VARIABLE(a);
+	a *= a;
+	memcpy(p, &a, sizeof(a));
+	memcpy(&b, p, sizeof(b));
+	T_eq(a, b, "%f == %f", a, b);
2.34.1
