[PATCH 09/11] testsuites/sptests/sp[a-h]*/*.doc: Change license to BSD-2
Joel Sherrill
joel at rtems.org
Thu Mar 31 22:24:42 UTC 2022
Updates #3053.
testsuites/sptests/spassoc01/spassoc01.doc | 25 ++++++++++++++++---
.../sptests/spcbssched01/spcbssched01.doc | 25 ++++++++++++++++---
.../sptests/spcbssched02/spcbssched02.doc | 25 ++++++++++++++++---
.../sptests/spcbssched03/spcbssched03.doc | 25 ++++++++++++++++---
testsuites/sptests/spchain/spchain.doc | 25 ++++++++++++++++---
.../sptests/spclock_err02/spclock_err02.doc | 25 ++++++++++++++++---
testsuites/sptests/spcpuset01/spcpuset01.doc | 25 ++++++++++++++++---
.../sptests/spedfsched01/spedfsched01.doc | 25 ++++++++++++++++---
.../sptests/spedfsched02/spedfsched02.doc | 25 ++++++++++++++++---
.../sptests/spedfsched03/spedfsched03.doc | 25 ++++++++++++++++---
testsuites/sptests/sperror01/sperror01.doc | 25 ++++++++++++++++---
testsuites/sptests/sperror02/sperror02.doc | 25 ++++++++++++++++---
testsuites/sptests/sperror03/sperror03.doc | 25 ++++++++++++++++---
testsuites/sptests/spfatal01/spfatal01.doc | 25 ++++++++++++++++---
testsuites/sptests/spfatal03/spfatal03.doc | 25 ++++++++++++++++---
testsuites/sptests/spfatal04/spfatal04.doc | 25 ++++++++++++++++---
testsuites/sptests/spfatal05/spfatal05.doc | 25 ++++++++++++++++---
testsuites/sptests/spfatal09/spfatal09.doc | 25 ++++++++++++++++---
testsuites/sptests/spfatal10/spfatal10.doc | 25 ++++++++++++++++---
testsuites/sptests/spfatal11/spfatal11.doc | 25 ++++++++++++++++---
testsuites/sptests/spfatal12/spfatal12.doc | 25 ++++++++++++++++---
testsuites/sptests/spfatal14/spfatal14.doc | 25 ++++++++++++++++---
testsuites/sptests/spfatal15/spfatal15.doc | 25 ++++++++++++++++---
testsuites/sptests/spfifo02/spfifo02.doc | 25 ++++++++++++++++---
testsuites/sptests/spfifo03/spfifo03.doc | 25 ++++++++++++++++---
testsuites/sptests/spfifo04/spfifo04.doc | 25 ++++++++++++++++---
testsuites/sptests/spfifo05/spfifo05.doc | 25 ++++++++++++++++---
.../sptests/spfreechain01/spfreechain01.doc | 25 ++++++++++++++++---
testsuites/sptests/spheapprot/spheapprot.doc | 2 ++
29 files changed, 618 insertions(+), 84 deletions(-)
diff --git a/testsuites/sptests/spassoc01/spassoc01.doc b/testsuites/sptests/spassoc01/spassoc01.doc
index 682ef22dab..95a25cec1b 100644
--- a/testsuites/sptests/spassoc01/spassoc01.doc
+++ b/testsuites/sptests/spassoc01/spassoc01.doc
@@ -1,9 +1,28 @@
+# SPDX-License-Identifier: BSD-2-Clause
# COPYRIGHT (c) 1989-2010.
# On-Line Applications Research Corporation (OAR).
-# The license and distribution terms for this file may be
-# found in the file LICENSE in this distribution or at
-# http://www.rtems.org/license/LICENSE.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions
+# are met:
+# 1. Redistributions of source code must retain the above copyright
+# notice, this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright
+# notice, this list of conditions and the following disclaimer in the
+# documentation and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
This file describes the directives and concepts tested by this test set.
diff --git a/testsuites/sptests/spcbssched01/spcbssched01.doc b/testsuites/sptests/spcbssched01/spcbssched01.doc
index 985e11ee43..81087c2cc4 100644
--- a/testsuites/sptests/spcbssched01/spcbssched01.doc
+++ b/testsuites/sptests/spcbssched01/spcbssched01.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-1999.
+# are met:
diff --git a/testsuites/sptests/spcbssched02/spcbssched02.doc b/testsuites/sptests/spcbssched02/spcbssched02.doc
index df5b989538..cf63640eee 100644
--- a/testsuites/sptests/spcbssched02/spcbssched02.doc
+++ b/testsuites/sptests/spcbssched02/spcbssched02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spcbssched03/spcbssched03.doc b/testsuites/sptests/spcbssched03/spcbssched03.doc
index a558870ee5..a67998be88 100644
--- a/testsuites/sptests/spcbssched03/spcbssched03.doc
+++ b/testsuites/sptests/spcbssched03/spcbssched03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spchain/spchain.doc b/testsuites/sptests/spchain/spchain.doc
index 4962426083..87ff973c1b 100644
--- a/testsuites/sptests/spchain/spchain.doc
+++ b/testsuites/sptests/spchain/spchain.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-2009.
+# are met:
diff --git a/testsuites/sptests/spclock_err02/spclock_err02.doc b/testsuites/sptests/spclock_err02/spclock_err02.doc
index 2f660b8e43..04e300f164 100644
--- a/testsuites/sptests/spclock_err02/spclock_err02.doc
+++ b/testsuites/sptests/spclock_err02/spclock_err02.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 2013.
+# are met:
diff --git a/testsuites/sptests/spcpuset01/spcpuset01.doc b/testsuites/sptests/spcpuset01/spcpuset01.doc
index 7477cc7cd3..2c97626e62 100644
--- a/testsuites/sptests/spcpuset01/spcpuset01.doc
+++ b/testsuites/sptests/spcpuset01/spcpuset01.doc
@@ -1,9 +1,28 @@
# COPYRIGHT (c) 1989-2013.
+# are met:
This is a set of simple tests that verify that the fixed size
diff --git a/testsuites/sptests/spedfsched01/spedfsched01.doc b/testsuites/sptests/spedfsched01/spedfsched01.doc
index 6913870723..81160dc56b 100644
--- a/testsuites/sptests/spedfsched01/spedfsched01.doc
+++ b/testsuites/sptests/spedfsched01/spedfsched01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spedfsched02/spedfsched02.doc b/testsuites/sptests/spedfsched02/spedfsched02.doc
index dc52f1f8db..721309ee1f 100644
--- a/testsuites/sptests/spedfsched02/spedfsched02.doc
+++ b/testsuites/sptests/spedfsched02/spedfsched02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spedfsched03/spedfsched03.doc b/testsuites/sptests/spedfsched03/spedfsched03.doc
index 31e78d1ca0..ef940999ec 100644
--- a/testsuites/sptests/spedfsched03/spedfsched03.doc
+++ b/testsuites/sptests/spedfsched03/spedfsched03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/sperror01/sperror01.doc b/testsuites/sptests/sperror01/sperror01.doc
index 2a0d7e834a..de75698f50 100644
--- a/testsuites/sptests/sperror01/sperror01.doc
+++ b/testsuites/sptests/sperror01/sperror01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/sperror02/sperror02.doc b/testsuites/sptests/sperror02/sperror02.doc
index 8595438065..18ce266fa5 100644
--- a/testsuites/sptests/sperror02/sperror02.doc
+++ b/testsuites/sptests/sperror02/sperror02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/sperror03/sperror03.doc b/testsuites/sptests/sperror03/sperror03.doc
index eaea83ffe3..6b22759ac5 100644
--- a/testsuites/sptests/sperror03/sperror03.doc
+++ b/testsuites/sptests/sperror03/sperror03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfatal01/spfatal01.doc b/testsuites/sptests/spfatal01/spfatal01.doc
index 7fed165afa..12395b1b2d 100644
--- a/testsuites/sptests/spfatal01/spfatal01.doc
+++ b/testsuites/sptests/spfatal01/spfatal01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfatal03/spfatal03.doc b/testsuites/sptests/spfatal03/spfatal03.doc
index 5d643cc0dc..c42993319f 100644
--- a/testsuites/sptests/spfatal03/spfatal03.doc
+++ b/testsuites/sptests/spfatal03/spfatal03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfatal04/spfatal04.doc b/testsuites/sptests/spfatal04/spfatal04.doc
index 67413fe952..8a861c4d1a 100644
--- a/testsuites/sptests/spfatal04/spfatal04.doc
+++ b/testsuites/sptests/spfatal04/spfatal04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfatal05/spfatal05.doc b/testsuites/sptests/spfatal05/spfatal05.doc
index 354673d308..79f56937ac 100644
--- a/testsuites/sptests/spfatal05/spfatal05.doc
+++ b/testsuites/sptests/spfatal05/spfatal05.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfatal09/spfatal09.doc b/testsuites/sptests/spfatal09/spfatal09.doc
index 5459523f7c..f6521d688b 100644
--- a/testsuites/sptests/spfatal09/spfatal09.doc
+++ b/testsuites/sptests/spfatal09/spfatal09.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfatal10/spfatal10.doc b/testsuites/sptests/spfatal10/spfatal10.doc
index d13f410e4a..a92c9535e6 100644
--- a/testsuites/sptests/spfatal10/spfatal10.doc
+++ b/testsuites/sptests/spfatal10/spfatal10.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfatal11/spfatal11.doc b/testsuites/sptests/spfatal11/spfatal11.doc
index 5527c917e4..1e76abd6b6 100644
--- a/testsuites/sptests/spfatal11/spfatal11.doc
+++ b/testsuites/sptests/spfatal11/spfatal11.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfatal12/spfatal12.doc b/testsuites/sptests/spfatal12/spfatal12.doc
index dda170f4a0..28f7bcf44f 100644
--- a/testsuites/sptests/spfatal12/spfatal12.doc
+++ b/testsuites/sptests/spfatal12/spfatal12.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfatal14/spfatal14.doc b/testsuites/sptests/spfatal14/spfatal14.doc
index f9c49af47e..b844551c0a 100644
--- a/testsuites/sptests/spfatal14/spfatal14.doc
+++ b/testsuites/sptests/spfatal14/spfatal14.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfatal15/spfatal15.doc b/testsuites/sptests/spfatal15/spfatal15.doc
index abeeb77eae..f1b7b894c7 100644
--- a/testsuites/sptests/spfatal15/spfatal15.doc
+++ b/testsuites/sptests/spfatal15/spfatal15.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfifo02/spfifo02.doc b/testsuites/sptests/spfifo02/spfifo02.doc
index b8d66acbd9..f3717b86d7 100644
--- a/testsuites/sptests/spfifo02/spfifo02.doc
+++ b/testsuites/sptests/spfifo02/spfifo02.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfifo03/spfifo03.doc b/testsuites/sptests/spfifo03/spfifo03.doc
index c23437da0a..be8b7f3e1a 100644
--- a/testsuites/sptests/spfifo03/spfifo03.doc
+++ b/testsuites/sptests/spfifo03/spfifo03.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfifo04/spfifo04.doc b/testsuites/sptests/spfifo04/spfifo04.doc
index f7d263adf5..92a65413af 100644
--- a/testsuites/sptests/spfifo04/spfifo04.doc
+++ b/testsuites/sptests/spfifo04/spfifo04.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfifo05/spfifo05.doc b/testsuites/sptests/spfifo05/spfifo05.doc
index 5df605d87d..3646389c28 100644
--- a/testsuites/sptests/spfifo05/spfifo05.doc
+++ b/testsuites/sptests/spfifo05/spfifo05.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spfreechain01/spfreechain01.doc b/testsuites/sptests/spfreechain01/spfreechain01.doc
index 7e58ea3cdc..2d53e5fbe9 100644
--- a/testsuites/sptests/spfreechain01/spfreechain01.doc
+++ b/testsuites/sptests/spfreechain01/spfreechain01.doc
@@ -1,9 +1,28 @@
+# are met:
diff --git a/testsuites/sptests/spheapprot/spheapprot.doc b/testsuites/sptests/spheapprot/spheapprot.doc
index d53ad5b9ec..9d01a7b005 100644
--- a/testsuites/sptests/spheapprot/spheapprot.doc
+++ b/testsuites/sptests/spheapprot/spheapprot.doc
@@ -1,3 +1,5 @@
# Copyright (c) 2010 embedded brains GmbH. All rights reserved.
2.24.4
