AW: AW: AW: Dependencies of PPS API in rtems-libbsd
Sebastian Huber
Thu Mar 31 11:11:40 UTC 2022
On 31/03/2022 12:10, Gabriel.Moyano at dlr.de wrote:
>> On 30/03/2022 15:19, Gabriel.Moyano at dlr.de wrote:
>>>>> Ok, it seems the pps_event() could be called by interrupt service
>>>>> routines. In this case, you cannot use a mutex and condition variables.
>>>>> You have to use a thread queue directly. Use the thread queue ISR
>>>>> lock for mutual exclusion. Use _Thread_queue_Enqueue() to emulate
>>>>> sleep() and
>>>>> _Thread_queue_Flush_critical() to emulate wakeup(). Check all
>>>>> critical sections that they can be protected by an ISR lock (no blocking calls and short).
>>>> Is this even so if pps_event() calls signal or broadcast? Because pps_fetch() is the only function that is waiting (and locking a
>> mutex).
>>> Do you mean something like this?
>>> Unfortunately something should be missing because it doesn't work.
>> In cpukit/score/src/futex.c you have a working example.
>> You would have to replace the mutex with the thread queue lock. I had a look at some FreeBSD drivers which use this stuff and it
>> would not be possible to support them with this approach. You could move the
>> if (abi_aware(pps, 1) && pps->driver_mtx != NULL) {
>> if (pps->flags & PPSFLAG_MTX_SPIN) {
>> err = msleep_spin(pps, pps->driver_mtx,
>> "ppsfch", timo);
>> } else {
>> err = msleep(pps, pps->driver_mtx, PCATCH,
>> "ppsfch", timo);
>> } else {
>> err = tsleep(pps, PCATCH, "ppsfch", timo);
>> and
>> /* Wakeup anyone sleeping in pps_fetch(). */
>> wakeup(pps);
>> blocks into RTEMS-specific sleep/wakeup callouts in struct pps_state.
> Just reading this email a second time, do you mean stop trying the thread queue approach and use another RTEMS-specific solution for waking up tasks which wait in pps_fetch()? For example use RTEMS signals or events?
Yes, I would stop trying the thread queue approach. It is not flexible
enough for libbsd support. With the sleep/wakeup callouts in struct
pps_state, the drivers (for example in libbsd) can use a synchronization
mechanism at their choice.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax: +49-89-18 94 741 - 08
Registernummer: HRB 157899
