[PATCH 1/7] cpukit/score/cpu/moxie: Change license to BSD-2
Wed Mar 30 22:45:24 UTC 2022
    Permission received from Anthony Green.
Updates #3053.
 cpukit/score/cpu/moxie/cpu.c                  | 25 ++++++++++++++++---
 cpukit/score/cpu/moxie/cpu_asm.S              | 25 ++++++++++++++++---
 cpukit/score/cpu/moxie/include/rtems/asm.h    | 25 ++++++++++++++++---
 .../score/cpu/moxie/include/rtems/score/cpu.h | 25 ++++++++++++++++---
 .../cpu/moxie/include/rtems/score/cpuatomic.h | 25 ++++++++++++++++---
 .../cpu/moxie/include/rtems/score/cpuimpl.h   | 25 ++++++++++++++++---
 .../cpu/moxie/include/rtems/score/moxie.h     | 25 ++++++++++++++++---
 .../cpu/moxie/moxie-exception-frame-print.c   | 25 ++++++++++++++++---
 8 files changed, 176 insertions(+), 24 deletions(-)
diff --git a/cpukit/score/cpu/moxie/cpu.c b/cpukit/score/cpu/moxie/cpu.c
index abebad9d29..a3d1005ad8 100644
--- a/cpukit/score/cpu/moxie/cpu.c
+++ b/cpukit/score/cpu/moxie/cpu.c
@@ -1,3 +1,5 @@
  *  Moxie CPU Dependent Source
@@ -8,9 +10,26 @@
  *  COPYRIGHT (c) 1989-1999, 2010.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
 #ifdef HAVE_CONFIG_H
diff --git a/cpukit/score/cpu/moxie/cpu_asm.S b/cpukit/score/cpu/moxie/cpu_asm.S
index 20842149ca..bcf0394475 100644
--- a/cpukit/score/cpu/moxie/cpu_asm.S
+++ b/cpukit/score/cpu/moxie/cpu_asm.S
@@ -1,3 +1,5 @@
  * Moxie CPU functions
  *   Copyright (C) 2011 Anthony Green
@@ -7,9 +9,26 @@
  *  COPYRIGHT (c) 1989-1999.
+ * are met:
diff --git a/cpukit/score/cpu/moxie/include/rtems/asm.h b/cpukit/score/cpu/moxie/include/rtems/asm.h
index f328c1ce33..79e07b19cf 100644
--- a/cpukit/score/cpu/moxie/include/rtems/asm.h
+++ b/cpukit/score/cpu/moxie/include/rtems/asm.h
@@ -1,3 +1,5 @@
  * @file
@@ -25,9 +27,26 @@
+ * are met:
  *  $Id: asm.h,v 1.9 2010/06/29 00:31:09 joel Exp $
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
index a3991016f1..18329a5b3d 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpu.h
@@ -1,3 +1,5 @@
  * @file
@@ -14,9 +16,26 @@
  *  COPYRIGHT (c) 1989-2006, 2010.
+ * are met:
 #ifndef _RTEMS_SCORE_CPU_H
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h b/cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h
index 598ee76b20..01bb99cda3 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpuatomic.h
@@ -1,9 +1,28 @@
  * COPYRIGHT (c) 2012-2013 Deng Hengyi.
+ * are met:
 #ifndef _RTEMS_SCORE_ATOMIC_CPU_H
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
index 76068fe8b8..038a1326cc 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/cpuimpl.h
@@ -1,3 +1,5 @@
  * @file
@@ -7,9 +9,26 @@
  * Copyright (c) 2013 embedded brains GmbH
+ * are met:
 #ifndef _RTEMS_SCORE_CPUIMPL_H
diff --git a/cpukit/score/cpu/moxie/include/rtems/score/moxie.h b/cpukit/score/cpu/moxie/include/rtems/score/moxie.h
index 992f599033..34a6187ed6 100644
--- a/cpukit/score/cpu/moxie/include/rtems/score/moxie.h
+++ b/cpukit/score/cpu/moxie/include/rtems/score/moxie.h
@@ -1,3 +1,5 @@
  * @file
@@ -12,9 +14,26 @@
+ * are met:
 #ifndef _RTEMS_SCORE_MOXIE_H
diff --git a/cpukit/score/cpu/moxie/moxie-exception-frame-print.c b/cpukit/score/cpu/moxie/moxie-exception-frame-print.c
index 4dac3f8c91..67a7496b72 100644
--- a/cpukit/score/cpu/moxie/moxie-exception-frame-print.c
+++ b/cpukit/score/cpu/moxie/moxie-exception-frame-print.c
@@ -1,9 +1,28 @@
  * Copyright (c) 2013  Anthony Green
+ * are met:
2.24.4
