[PATCH] libcsupport: Use _fwalk_reent()
Sebastian Huber
Thu Mar 31 06:23:25 UTC 2022
Use _fwalk_reent() instead of _fwalk(), since _fwalk() was removed from Newlib.
Include <sys/reent.h> and remove local declarations.
cpukit/libcsupport/src/sync.c | 29 ++++++++++-------------------
1 file changed, 10 insertions(+), 19 deletions(-)
diff --git a/cpukit/libcsupport/src/sync.c b/cpukit/libcsupport/src/sync.c
index 265c6f07c9..b9d1dcdcc5 100644
--- a/cpukit/libcsupport/src/sync.c
+++ b/cpukit/libcsupport/src/sync.c
@@ -18,13 +18,7 @@
#include "config.h"
#endif
-/* Since we compile with strict ANSI we need to undef it to get
- * prototypes for extensions
-#undef __STRICT_ANSI__
-int fdatasync(int); /* still not always prototyped */
+#include <sys/reent.h>
#include <unistd.h>
@@ -32,19 +26,22 @@ int fdatasync(int); /* still not always prototyped */
-/* XXX check standards -- Linux version appears to be void */
-void _fwalk(struct _reent *, void *);
+/* In Newlib this function is declared in a private header file */
+int _fwalk_reent (struct _reent *, int (*)(struct _reent *, FILE *));
-static void sync_wrapper(FILE *f)
+static int sync_wrapper(struct _reent *reent, FILE *f)
int fn = fileno(f);
+ (void) reent;
* There is no way to report errors here. So this is a best-effort approach.
(void) fsync(fn);
(void) fdatasync(fn);
+ return 0;
/* iterate over all FILE *'s for this thread */
@@ -62,19 +59,13 @@ static bool sync_per_thread(Thread_Control *t, void *arg)
Thread_Control *executing = _Thread_Get_executing();
current_reent = executing->libc_reent;
executing->libc_reent = this_reent;
- _fwalk (t->libc_reent, sync_wrapper);
+ _fwalk_reent (this_reent, sync_wrapper);
executing->libc_reent = current_reent;
return false;
- * _global_impure_ptr is not prototyped in any .h files.
- * We have to extern it here.
-extern struct _reent * const _global_impure_ptr __ATTRIBUTE_IMPURE_PTR__;
* This function operates by as follows:
* for all threads
@@ -88,7 +79,7 @@ void sync(void)
* Walk the one used initially by RTEMS.
- _fwalk(_global_impure_ptr, sync_wrapper);
+ _fwalk_reent(_GLOBAL_REENT, sync_wrapper);
* XXX Do we walk the one used globally by newlib?
2.34.1
